KarlLe
06.08.2021 22:00:56
Arvuti crashib osades mängudes(Dump faili lugemisoskust vaja) |
link :: Artifacts
Tere.
Enamasti arvuti töötab ilusti, pole crashe ega midagi. Aga näiteks F1 2021 tööle pannes ilmuvad ekraanidele imelikud graafilised artifaktid ja arvuti teeb resa. Vahetevahel crashib mõne muu mängu peale ka, aga 100% crashib selle peale. Windows, driverid uuendatud. Muudes mängudes/benchmarkides töötab ilusti, memtest86 vigu ei leidnud. Oleks väga tänulik kui keegi oskaks aidata!
CPU: Ryzen 5 5600x
MOBO: Asus x570 gaming e
GPU: Asus strix 3080 OC
RAM: 32GB g.skill tridentZ neo 3600Mhz cl 16
850w PSU
Dump fail annab sellise teate:
0: kd> !analyze -v
* Bugcheck Analysis *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the WHEA_ERROR_RECORD structure to get more details.
Arguments:
Arg1: 0000000000000010, Error Source Type
Arg2: ffffbf04ccf08028
Arg3: ffffbf04b9c7e92c
Arg4: ffffbf04b9db51a0
Debugging Details:
*** WARNING: Unable to verify checksum for win32k.sys
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 4359
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 42115
Key : Analysis.Init.CPU.mSec
Value: 405
Key : Analysis.Init.Elapsed.mSec
Value: 25275
Key : Analysis.Memory.CommitPeak.Mb
Value: 90
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Timestamp
Value: 2019-12-06T14:06:00Z
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: 124
BUGCHECK_P1: 10
BUGCHECK_P2: ffffbf04ccf08028
BUGCHECK_P3: ffffbf04b9c7e92c
BUGCHECK_P4: ffffbf04b9db51a0
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
ffffb906`203b7448 fffff806`389b5cdc : 00000000`00000124 00000000`00000010 ffffbf04`ccf08028 ffffbf04`b9c7e92c : nt!KeBugCheckEx
ffffb906`203b7450 fffff806`389b6839 : ffffbf04`d27cb690 ffffbf04`d27cb690 ffffbf04`b9c7e900 ffffbf04`cfaba338 : nt!WheaReportHwError+0x3ec
ffffb906`203b7530 fffff806`389b6955 : 00000000`00000000 00000000`00000062 ffffbf04`d27cb690 00000000`00000000 : nt!WheaHwErrorReportSubmitDeviceDriver+0xe9
ffffb906`203b7560 fffff806`3a842365 : 00000000`00000000 ffffb906`203b7780 ffffbf04`b9db51a0 ffffb906`203b79ff : nt!WheaReportFatalHwErrorDeviceDriverEx+0xf5
ffffb906`203b75c0 fffff806`3a83b7f0 : 00000000`00000000 ffffbf04`b9db51a0 ffffbf04`b9dba1a0 00000000`00000000 : storport!StorPortWriteRegisterUshort+0x9295
ffffb906`203b7650 fffff806`3a821f6c : 00000000`00000000 fffff806`3a868000 00000000`00000000 ffffbf04`b9d8f020 : storport!StorPortWriteRegisterUshort+0x2720
ffffb906`203b78e0 fffff806`3a77a00d : 00000000`00000000 ffffbf04`b9d8f020 00000000`00000000 00000000`00000000 : storport!memset+0x61ac
ffffb906`203b79b0 fffff806`3a77d192 : ffffbf04`c1000002 00000000`00000000 ffffbf04`b9d8f020 00000000`00000003 : stornvme!ControllerReset+0x1a1
ffffb906`203b7a30 fffff806`3a77c10f : ffffbf04`b9d8f020 ffffbf04`b9db5050 ffffbf04`ce68a270 80000000`00002000 : stornvme!NVMeControllerReset+0x10a
ffffb906`203b7a60 fffff806`3a838f40 : ffffbf04`ce68a270 ffffbf04`b9db5050 ffffbf04`b9c79080 ffffbf04`b84a6ca0 : stornvme!NVMeControllerAsyncResetWorker+0x3f
ffffb906`203b7a90 fffff806`38674995 : ffffbf04`cd9cce50 ffffbf04`cd9cce50 ffffbf04`b9db5050 fffff806`45f35440 : storport!StorPortValidateRange+0x50
ffffb906`203b7ac0 fffff806`386b8515 : ffffbf04`ceaf7040 ffffbf04`ceaf7040 fffff806`38674860 00000000`00000000 : nt!IopProcessWorkItem+0x135
ffffb906`203b7b30 fffff806`38755875 : ffffbf04`ceaf7040 00000000`00000080 ffffbf04`b849a040 7af5a417`00000001 : nt!ExpWorkerThread+0x105
ffffb906`203b7bd0 fffff806`387fe578 : ffff8e00`31450180 ffffbf04`ceaf7040 fffff806`38755820 d7cf4a93`db8d4a97 : nt!PspSystemThreadStartup+0x55
ffffb906`203b7c20 00000000`00000000 : ffffb906`203b8000 ffffb906`203b1000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x28
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD.sys
STACK_COMMAND: .thread ; .cxr ; kb
FAILURE_BUCKET_ID: 0x124_16_AuthenticAMD__UNKNOWN_IMAGE_AuthenticAMD.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {590f0c83-3219-aceb-da4c-6b8bc7c00f79}
Followup: MachineOwner
Kommentaarid: 10 loe/lisa |
10 |
Bunny
Kommentaarid: 1 loe/lisa |
0 |
A.S.
07.08.2021 09:18:10
Re: Arvuti crashib osades mängudes(Dump faili lugemisoskust vaja) |
KarlLe kirjutas: |
Mitte, et ma oskaks või tahaks dump faili lugeda, lihtsalt mainin, et mina igatahes ei näe siin ühtegi faili.
Kommentaarid: 34 loe/lisa |
34 |
KarlLe
07.08.2021 09:34:43
A.S. kirjutas: |
KarlLe kirjutas: |
Kogu see pikk tekst all
10 |
A.S.
07.08.2021 09:40:22
See pole dump fail, lihtsalt selle lühike sisukokkuvõte.
Sest lisaks !analyze -v käsule eksisteerib veel palju-palju käske, mis oskajale (mitte mulle, vaid asjatundjale) täiendavat infot võivad anda.
34 |
KarlLe
07.08.2021 12:24:22
A.S. kirjutas: |
Sest lisaks !analyze -v käsule eksisteerib veel palju-palju käske, mis oskajale (mitte mulle, vaid asjatundjale) täiendavat infot võivad anda. |
Arusaadav, üritan selle ka lisada
10 |
lisa lemmikuks |
