praegune kellaaeg 17.11.2026 06:16:35
murka390
18.05.2021 21:26:48
Armhfi peal Xorgi jooksutamine? |
Tundub ei taha vedu võtta.
On mul lootust saada selle abil lxde gui tööle?
Eeldan et seda on vaja selleks.
Selline logi (osaliselt):
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.19.0-16-armmp-lpae armv7l Debian
Current Operating System: Linux odroidxu4 4.14.222-odroidxu4 #2 SMP PREEMPT Thu May 6 21:45:40 UTC 2021 armv7l
Build Date: 19 April 2021 09:34:38AM
xorg-server 2:1.20.4-1+deb10u3 (https://www.debian.org/support)
Current version of pixman: 0.36.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue May 18 19:22:21 2021
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
MESA-LOADER: failed to retrieve device information
gbm: failed to open any driver (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
gbm: Last dlopen error: /usr/lib/dri/exynos_dri.so: cannot open shared object file: No such file or directory
failed to load driver: exynos
(II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
xinit: connection to X server lost
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
| Kommentaarid: 81 loe/lisa |
74 |
serxx
18.05.2021 21:51:23
armhf ei ole probleemiks.
Raspberry pi (alates 2?) on armhf ja xorg jookseb ilusti. Uuemad on arm64, pi 1 on vist armel. Kõigi nende peal jookseb xorg.
Küsimus on video driverites.
Mingi generic framebuffer xorg driveriga (xorg.conf muutmine võib vajalik olla) võib saada vist suht iga videokaardi peal selle käima.
ARM platovormil on video driveritega üldiselt ikaldus. Linuxile pole closed source dirvereid ja open source driverid on nagu nad on ja tihti tahavad kõvasti käsitööd, et käima ajada.
Lisaks tuleb veel pildile device tree teema ja ka see peab vastava raua jaoks õige olema, et kõik töötaks nagu vaja.
Olen GUI käima ajanud erinevate RK3188 RK3328 S905/x//w/x2/x3 ja rasperry pi seadmete peal. Enamus on nendest olnud Androidiga TV boksid, millele olen linuxi peale ajanud.
Lihtsalt pildi ette saamine pole enamasti probleemiks olnud. Aga kindlasti on probleeme riistvaralise kiirenduse tööle saamisega. Ilma selleta kipub GUI kehvapoolne olema. Ja kinldasti on suht nutune seis video vaatamisega, kui riistvaraline kiirendus ei toimi.
Selleks et GUI töötaks ilusti ja ka video vaatamine oleks võimalik on vaja head video driverit ja kogu riistvaralise kiirenduse käima ajamist.
Et see oleks võimalik, on vaja väga hoolega valida, millist riistvara valida.
Hetkel tundub, et sul mingid MESA asjad puudu või midagi mesa driveritega pahasti. Või mingi konf viitab failidele, mida olemas pole.
Siin on mingi viide:
https://forum.odroid.com/viewtopic.php?f=77&t=4628&p=37134#p37132
Võibolla aitab, kui exynos.conf faili ringi nimetad, et seda ei loetaks. Kui sul on selline konfifail.
cd /etc/X11/xorg.conf.d
sudo mv exynos.conf exynos.conf.old |
| Kommentaarid: 162 loe/lisa |
145 |
murka390
19.05.2021 01:33:13
Videot vaadata ei tahagi, mõtlesin et gui´ga lihtsam ehk seadistada mõni meedia server selle Odroidi peale.
Et võrgus oleva smart telekaga saaks sirvida odroidi kettalt videosid ja muud meediat.
74 |
serxx
19.05.2021 16:00:32
Samba või NFS seadistamiseks pole GUI-d vaja. Kas selleks on üldse mingeid häid GUI tööriistu? Ma pole ise kunagi selle jaoks GUI-d kasutanud.
Samba jaoks on ainult paar rida vaja, et see toimiks:
/etc/samba/smb.conf - või /etc/samba/smb.conf.d/<pane ise mingi nimi>.conf
[global]
workgroup = <siia mingi workgroup nimi>
server string = <vist mingi serveri description vms, optional>
netbios name = <masina nimi, millega ta võrku välja paistab>
# kantsulgudes on share nimi, tee nii mitu kui vaja
# \\<netbios name>\share
[share]
path = /path/to/shared/dir
writeable = yes
browseable = yes
guest ok = yes
# force user/group teeb nii, et kõik failisüsteemi operatsioonid tehakse selle kasutaja alt
# ja ei teki mingit õiguste jama
# paljude kasutajatega suures võrgus halb mõte - kodus videote jagamisel ilmselt pigem hea mõte
# et ei tekiks ligipääsu õigustega probleeme
force user = <mingi username mis linuxi masinas olemas>
force group = <mingi username mis linuxi masinas olemas>
# teine share
# \\<netbios name>\videos
[videos]
path = /path/to/another/dir
# + muud parameetrid
Sambale restart ja võiks toimida. Ma ise seda konkreetset konfi katsetanud pole, aga teoorias võiks olla piisav.
Kui telekas NFS-i toetab, võiks see võibolla parem variant olla.
Kui windowsi masinast ka ligi saada tahad, teeb samba ilmselt elu lihtsamaks.
145 |
