sõnum ![Teata moderaatorile Teata moderaatorile](./images/icon_move_w.gif) |
priit04
15.05.2020 13:10:55
Lisasin https://github.com/yllar/plugin.video.jupiter.err.ee kuid käima panemisel annab errori..
13:04:28.310 T:1945809568 ERROR: Control 50 in window 10025 has been asked to focus, but it can't
13:04:29.215 T:1837102000 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.ValueError'>
Error Contents: too many values to unpack
Traceback (most recent call last):
File "/home/pi/.kodi/addons/plugin.video.jupiter.err.ee/addon.py", line 26, in <module>
locale.setlocale(locale.LC_ALL, 'et_EE.UTF-8')
File "/usr/lib/python2.7/locale.py", line 578, in setlocale
locale = normalize(_build_localename(locale))
File "/usr/lib/python2.7/locale.py", line 485, in _build_localename
language, encoding = localetuple
ValueError: too many values to unpack
-->End of Python script error report<--
13:04:29.241 T:1945809568 ERROR: GetDirectory - Error getting plugin://plugin.video.jupiter.err.ee/
13:04:29.242 T:1945809568 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.jupiter.err.ee/) failed
13:04:36.708 T:1945809568 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
13:04:43.024 T:1925182384 WARNING: CSkinInfo: failed to load skin settings
Keegi oskab aidata?
Kommentaarid: 14 loe/lisa |
![](./images/komment/img_10_1.gif) ![](./images/komment/img_10_0.gif) ![](./images/komment/img_10_2.gif) |
14 |
![](templates/HinnaVaatlus/imagesHV/spacer.gif) |
15.05.2020 15:34:26
Väga hea, peab ka oma vana kodiboksi käima ajama, jäi seni 4K tulekuga seisma.
Kommentaarid: 255 loe/lisa |
223 |
kaliif
04.06.2020 13:30:32
Kas Kodiga saab kuidagi Elisa Elamust vaadata?
Vaatasin et sommidel on mingi oma versioon vist ainult järelvaatamiseks.
Kommentaarid: 3 loe/lisa |
avrn
20.06.2020 20:23:20
kaliif kirjutas: |
Vaatasin et sommidel on mingi oma versioon vist ainult järelvaatamiseks. |
Oleneb Elamusest ilmselt.
Kui sa mõtled nüüd otseselt Kodi lisa, siis seda Eesti versioonis keegi pole teinud ja soomlaste oma ma kommenteerida ei tea.
Küll saab vaadata seda "Elamust", mida antenniga vastu võtta saab. Selleks peab olema DVB-T(soovitavalt T2) tuuneriga(või mitmega) arvuti, mingi TV-box sobiva tarkvaraga, vms., millest toimetab mõni Kodile sobiv server.
Siit saab sobivatest asjadest aimu ehk:
https://kodi.wiki/view/PVR_recording_software
Kaablis edastatava, ehk DVB-C peaks samamoodi kätte saama.
Kaardi lugemine on "delo tehniki".
PVR-lisa kaudu järelvaatamist kindlasti ei saa, küll võid eetrist ise salvestada meelepäraseid asju.
IPTV-na edastava Elamuse kohta ei tea. Pole olnud vajadust proovida. Kuigi osad PVR-id sellist võimalust omavad. Kuidas neid kohaliku operaatori eripäradega ühildada, selle kohta minul info puudub.
Kommentaarid: 5 loe/lisa |
kaliif
13.07.2020 10:35:26
OT:
Olen nüüdseks seda KODI asja 4 kuud pusinud, no ei saa korrlikult tööle. Ennem olin W10 WINDOWS MEDIACENTERI peal(10 aastat). Töötas 95% väga hästi TV vaatamiseks kuid filmidega oli jama palju nimelt ta ei suuda refresh rate muuta erinevate failde puhul jne, puudu on HDR, ATMOS jne. Aga ta hoidis koralikult windowsi os -il slma peal. Kodi seda ei suuda. Kogu aeg peab käed kapoti all hoidma ja näpud õliseks tegema. Kodi suurimad mured (minu PC puhul) SLEEP ja WAKEUP, sound settings ise muutub recieveril ATMOSE puhul , TV saadete salvestamine ja arusaamine kas minna sleepi või jätkata kodi kasutamist. Tegelt need kõik kodi mured on seotud windowsi kontrollimisega.
Algselt püüdsin masinat juhtida IR puldiga, no see oli ikka peavalu, kord sai käsud kätte kord ei saanud, samal ajal arvuti sai ja näitab ekraanil et IR käsk on käes. Kodi ignoreeris neid üsna tihti. Peale Harmony Bluetooth puldi kasutusele võtmist töötab 100%,
HDR videodega on veel omakorda huvitav teema, peaaegu töötab kuid see jooksutab PVRi kokku, või ei lähe üldse tööle. (ma kasutan DVB viewer backendi koos DD kaartidega, ELISA kaabel). 4K upscaling, lõpuks isegi ei saanud aru kes või mis millega korralikult läbi ei saa. NVIDIA kaart upscales kuid TV pilt jõnksutas aegajalt ja pilt minumeelest teravamaks ka ei läinud, 1050TI peaks sellega suurepäraselt hakkama saama. Praegu 1080P 4:4:4 peal ja on üsna ok.
Kisub halamiseks ära aga hetkel vist midagi paremat ALL IN ONE softi pole võtta ka.
Masinaks W10 PC nvidia 1050TI+Atmose toega reciever+Atmose toega TV.
Proovin veel CoreELEC ka ära, äkki peab olema ikka päris standalone masin et igapäevaselt 100% töötaks. Tellisin dualboodi võimalusega Ugoos AM6 Plus. Vaatan kuidas see suudab KODIga hakkama saada.
avrn
22.11.2020 11:05:29
Keegi Kodiga neid Elisa h265 kanaleid näeb?
Serveriks tvheadend 4.2.9.
Arvutis VLC teeb lahti ilusti. Kodi jookseb kinni, vahel kiilub terve masina kinni. Ubuntu 18, I5 prose ja Nvidia graafika.
Libreelec 9.2.5 ja Raspberry 4: heli on, subtiitrid on, pildiks värviline säbru.
Kodi lehel on testklipid, 4K asjad mängivad ilusti igal pool. See antennist tulev asi on ju ainult HD.
See kodumaine h265 on miski analooge mitteomav?
Oskab keegi viidata, mis suunas otsida?
kaliif
22.11.2020 11:33:40
Mis kanalid H265ga on, saan vaadata kuidas minul on.
Mul muidugi ELISA DVB-C ehk kaabliga.
avrn
warwas
![warwas warwas](https://foorum.hinnavaatlus.ee/images/avatars/upload/ae4deeee80cae8c94cc144333ae4cc5a.png)
22.11.2020 12:02:11
kaliif, kaablis on MPEG-2, sellega ei saa võrrelda.
Kommentaarid: 243 loe/lisa |
221 |
avrn
22.11.2020 14:20:14
Hmm. Majandasin siin veidi ja proovisin korra W10 peal Kodiga . Ja pilt ees.
Mingi Linuxi spetsiifiline probleem? Kuidas neid jälgi nüüd ajada, mis valesti on?
kaliif
22.11.2020 22:34:49
warwas kirjutas: |
kaliif, kaablis on MPEG-2, sellega ei saa võrrelda. |
Kaablis on ikka HD kanalid h264 ehk MPEG4 formaadis
-Koppel-
![-Koppel- -Koppel-](https://foorum.hinnavaatlus.ee/images/avatars/upload/2d9a9019ac770101fb2940671462960a.png)
30.11.2020 19:08:44
avrn kirjutas: |
Oskab keegi viidata, mis suunas otsida? |
Mis valemiga sa Elisa kanaleid saad VLC-ga arvutis vaadata? Või Kodiga?
Ja kuidas see sellisel juhul Leviraga seondub.
Levira edastab ju üle õhu seda värki... sinu kodus on antenn, mis püüab selle kinni, läheb kuskile ressiiverisse, mis selle dekodeerib ja telekasse kuvab.
ETV, ETV 2 ja ETV+ on ilma krüpteeringuta nn vabalevi värk.
Kui ei tule antennist, siis tuleb telepilt üle interneti... minul on Telia internet ja TV.
Kas siis Elisa edastab ka üle õhu seda värki?
https://levira.com/programm.pdf
Levira selles tabelis on Kanal 2, TV3 jne kanalid kuidagi kirjas, et Elisa on nende operaator... ja formaat ka siis HEVC ehk H.265.
Mul on muidu vana Telia karp ning olen ka soovinud kuidaig Raspberry Pi ja Kodi panna neid kanaleid näitama.
Kuskilt veebist leidsin IP aadressid, mis mingile kanalile vastavad ning sain samamoodi neid VLC voogedastust avades vaadata.
Et kui eksisteerib mingi meetod, siis oleks huvitatud kui keegi valgustab seda võimalust natuke detailsemalt.
Kommentaarid: 10 loe/lisa |
10 |
warwas
30.11.2020 21:08:14
-Koppel- kirjutas: |
Et kui eksisteerib mingi meetod, siis oleks huvitatud kui keegi valgustab seda võimalust natuke detailsemalt. |
-Koppel-, üle õhu kanalid (ja Elisa või STV kaablikanalid) saad omale VLC'sse sedasi, kui paned ühe või rohkem DVB-tüünereid striimingut tegeva tarkvara külge. Kodukasutuseks on vast üks parimaid variante eelpoolmainitud TVHeadend (hea integratsioon KODI'ga). Vähe spetsiifilisemaks minnes on veel MuMuDVB, DVBlast või Astra.
Tüünereid on nii USB'ga väliseid, kui ka PCIe peale käivaid sisemisi. Tasuliste kanalite vaatamiseks (ilma teenusepakkuja tingimustega raksu minemata ) on olemas ka CAM'i toega tüünerid.
221 |
30.11.2020 23:16:07
-Koppel-, Tasuvus antud lahendusega läheb kodustes tingimustes igal juhul kaheldavaks. Ainus viis tasuvust saavutada on hakata tegelema piraatlusega ja selle sisu edasimüümisega.
Telia IPTV on sisuliselt häkkimatu kui sa ei kasuta hulganisti digibokse ja HDMI krüptot murdvat riistvara millega iga kanal eraldi striimiks oma sisevõrku ja KODI/VLCsse pritsida.
Elisa DVB-C ja DVB-T ja IPTV on sama lugu. Sellist hübriidboksi päris vist pole kuhu antenn/kaabeltv järele läheb ja KODI sees on, kus oleks võimalik kasutada ka Conax vaatajakaarti. Need a'la Syno NAS ja DVB softid koos kaardilugejaga peaks ikka erilise entusiasti pärusmaa olema sest see vajab käsitööd, seadmete ostu ja häälestust ning tavaliselt seda 1-3 teleri pärast keegi ette ei võta.
Ehk, et kuna telerid sisaldavad niikuinii osa nutikust tänapäeval, siis tuleb tarbida sisu erinevatelt platvormidelt. Vabalevi DVB-T annab sulle ETV ja ETV2 jne. enamasti iga ilmaga, internet teleris annab sulle Youtube, ja kui teler on android siis igasuguseid vabalt vaadatavaid äppe.
TV teenused jäävad ametlikult ja kuutasuliseks, mistahes operaator ning seadmed (digiboksid) ja sisuteenused. Isegi piraat televisiooni ostes nagu L3iser, maksad ikka kuutasu ja kui ma õigesti aru saan, siis VLC ja Kodi ikka seda ei mängi.
Tulemus, TV taga on erinevaid bokse, mis täidavad erinevaid ülesandeid.
223 |
viljar
01.12.2020 14:57:37
indrpo kirjutas: |
Tulemus, TV taga on erinevaid bokse, mis täidavad erinevaid ülesandeid. |
Juba pikalt ootan, et Telia või Elisa vms teeks oma digiboxi asemel appletv toe - eraldi äpp või apple enda TV äpi osa vms. Saaks ühe karbiga teleka taga hakkama. Seniks kastan Logitech Harmony universaalpuldiga stseene erinevate tegevuste jaoks sisendite vahetemisel jne.
Kommentaarid: 34 loe/lisa |
34 |
avrn
01.12.2020 17:53:23
avrn kirjutas: |
Tuleb antenniga, tarkvara on mainitud juba.
indrpo kirjutas: |
Piraatlusega ei tegele, sisu ega kaarti ei jaga. Tasuvust ei ole kunagi silmas pidanud, ega see ilmselt ei tasugi end ära.
Pigem on asi selles, et soovin vaadata asju siis, kui soovin ja mõnda asja ka säilitada. Salvestust pakkuvatel opekatel on paraku ajapiirangud salvestiste kättesaadavusele, mis mulle ei sobi, samuti võib olla probleeme välise netiühendusega.
Tõsi, ega nendelt nn. Elisa kanalitelt säilitusväärset väga tihti just ei leia, et peaks tingimata HD olema. Samas, tehniline võimalus on olemas ja võiks ära kasutada. Natuke on asi ka õhina-põhine, et kas saab käima.
Teler iseenesest saab asjaga hakkama, aga paraku on nutitelerite kasutusmugavus suures osas alla arvestust, eriti, kui Kodiga joonele panna.
Hetkel pole saanud ise asja uurida, miks winnis mängib ja linuxis mitte. Seega igasugu viited ja soovitused endiselt oodatud.
Oskar.r
![Oskar.r Oskar.r](https://foorum.hinnavaatlus.ee/images/avatars/upload/010ecbcd50528039d60525b1f6290d75.png)
01.12.2020 19:58:50
küsiks vahele kui stabiilne teil Kodi on et TV 'tuunerina' kasutada? Wife factor ka muidugi.
Juba üle 6a kasutanud ja ikka tihtipeale restardib ja teeb ime asju. Põhiliselt siis kui Youtube'i videoid sisse streamida, aga see youtube ongi neil kogu aeg selline kehva olnud.
14 |
jaank
01.12.2020 20:07:49
odroid n2 ja enam-vähem veatu praeguseks hetkeks. yt ei kasuta.
Kommentaarid: 61 loe/lisa |
55 |
-Koppel-
07.12.2020 10:33:51
Youtube piisavalt tihti muudab oma ülesehituses midagi, et mingi APP katki läheks.
Mul ka piraatluse huvi ei olnud. Lihtsalt Telia enda box on nii aeglane ja seadmete vahetamiseks pean reaalselt kaabli ühe tagant ära võtma ja teise järgi panema. Et suht ebamugav. Ja kuna mingeid kanaleid sai VLC-ga vaadata lihtsalt IP aadressi teades, siis tekkis küsimus, et miks Raspberry Pi peal oleva Kodi-iga ei saa vaadata.
Ma alati arvasin, et see loogika on midagi sellist, et kuna internet tuleb Teliast, siis see on põhjus miks mul need voogedastuse IP aadressid töötavad. Aga reaalsuses ei pruugi sellel mingit seost olla.... või need on rudimendid mingist iidsest asjast sest viimasel ajal ka VLC-ga need kanalid "hakivad" justkui teenustpakkuva serveri ülekoormus vms.
(Ma praegu tööl olles ei saa vaadata/vastata, et mis need IIP aadressid on)
10 |
McCoffin
07.12.2020 16:01:58
Odroid N2 ja peal Hardkerneli foorumist "voodik" toodetud Android TV. Sisuliselt on vaja selle peal kasutada Kodi ja GO3, mis jooksevad seal probleemivabalt, YT samamoodi. ETV ja ETV2 äpid ka. Rohkem wife factor use case ei vaja hetkel. Androidil oleva Netflixi jaoks pole Odroidil piisavalt head DRM taset, mängib kõige kehvema resoga.
Kui Odroidi peale puhtalt Coreelec panna, siis saab ka Netflixi ja YT jooksutada, aga mu meelest on see rohkem hambaopp läbi pärasoole, pigem siis nende kahe jaoks mmingit sertifitseeritud Android toodet kasutada, mis kõik 4K HDR DRM värki toetatavad - odavamatest MiBoxid, FireTV pulgad ja nüüd uus Chromecast with Google TV on head valikud.
Kommentaarid: 40 loe/lisa |
40 |
dony
![dony dony](https://foorum.hinnavaatlus.ee/images/avatars/upload/77ee6d05b23e742e2aca3fd602f4c599.jpg)
22.10.2021 11:00:58
Kuna Telia teatas, et Motorola digiboksid tapetakse kuu aja jooksul ära ja COREEleciga odroidikarp nagunii teleka küljes, siis tekkis mõte lisada Kodile lihtsalt Telia TV addon. Leidsin küll Soome, Rootsi, Taani ja Leedu Telia TV addoni, kuid Eesti Telia TV jaoks mitte. Teab keegi, kas selline asi kusagil olemas võiks olla? Mulle piisaks täiesti sellisest funktsionaalsusest, nagu teliatv.ee või mobiiliäpil on. Saaksin ühe karbi teleka juures vähemaks.
_________________ Kui oled 45+, siis oled sa tööandjatele nähtamatu... |
Kommentaarid: 23 loe/lisa |
23 |
S.I.L.L.U
![](images/avatars/gallery/Female/00128.gif)
22.10.2021 11:33:43
Jälgin
Kommentaarid: 90 loe/lisa |
84 |
salusoft
![salusoft salusoft](https://foorum.hinnavaatlus.ee/images/avatars/upload/ebd9a92710e075e02cd3bc15aeae82f0.gif)
23.10.2021 10:08:09
S.I.L.L.U kirjutas: |
Jälgin |
+1
Kommentaarid: 9 loe/lisa |
9 |
-Koppel-
23.10.2021 13:20:07
Mis nende Motorola boxidega siis juhtub? Lähevad mingile uuele standardile üle, mida need Motorolad ei toeta?
10 |
dony
23 |
