18.10.2020 10:21:55
| von Wu kirjutas: |
Uurisin siin millalgi uusi sülearvuteid ja i5-10210U jääb leitud võrdluste põhjal Photoshopis isegi i5-2500K-le (kohe saab 10-aastaseks) alla. |
Geekbenchi järgi vastupidi, i5-10210U on selgelt tabelis ülevalpool. Seega sünteetiline test versus pärismaailm on erinevad, mis pole isegi üllatus aga tiba kahju, ei saa seda markerit kasutada.
147 |
anubis
283 |
20.10.2020 13:34:42
Nüüd neil rohkem raha 14++++...edasiarendamiseks
20.10.2020 15:29:48
Optane arenduse jätavad siiski endale. Selles eest saab rohkem küsida . Mõnes mõttes ajastu lõpp. Oli ju Inteli X25M esimene mainstream SSD (MLC ja TRIM) ja X25E (SLC) esimene high end/entusiast SSD. Tollal kui Intel veel oma kontrollereid tegi NAND flash jaoks mitte low end kraami sisseostetud Silicon Motion jms kontrolleritega.
Before the X25-M was released, all of the multi-level cell (MLC) drives were the same piece of hardware, but with a different company logo on it.[citation needed] This is called rebranding, which happens often in the computer hardware market, but Intel opted to develop its own MLC drive. The most notable feature about the X25-M is how well it performed in comparison to other MLC and single-level cell (SLC) SSDs. SLC drives are naturally more efficient than MLC drives, however Intel's unique architecture for this MLC drive was much more efficient than the typical MLC drive.
To prevent data loss, Intel included additional 7.5–8% more space (6–6.4 GB on an 80 GB drive), specifically for reliability purposes. If it ran out of good blocks to write (nearing the end of the drive's lifespan), the SSD will write to this additional space on the drive. |
https://en.wikipedia.org/wiki/List_of_Intel_SSDs
Aasta oli 2008 muideks. 12 aastat tagasi.
| Kommentaarid: 92 loe/lisa |
Optimist
20.10.2020 18:00:06
Mul siiani üks Intel X25-M G2 80GB ühes masinas idlemas.
Intel on harjunud kõrgete marginaalidega oma toodetel ja ei taha liiga "mainstream" toodete kategoorias konkureerimises osaleda. Meenutab IBMi väljumist HDD ja PC'de ärist, polnud enam seda katet mis vanasti. Selles vist keegi ei kahtle, et Intelil CPU'de valmistamisele suurema fookuse panemine kahjuks tuleks
| Kommentaarid: 10 loe/lisa |
One
20.10.2020 18:48:38
Inteli SSD-d olid ikka paras kräpp, massiliselt surid 2.5"(256GB, äriklassi masinates) kohe peale garantii lõppu ja neile tuli peale seda firmware uuendus mis oleks "probleemi" ära fixinud..
Ainuke probleem oli see, et kui muidu arvutid neid SSD-sid nägid siis Inteli firmware update tool pani nendega lihtsalt pange.
Mul oli eelmises töökohas neid sama veaga erinevaid SSD-id mitu sahtlitäit, lõpuks läksid kõik pressi alla.
728 |
SilQ
26.10.2020 11:01:47
Nõustun Winterwind'iga. Ka sadade viisi Inteli kettaid minema visanud. Nuc'e ka kastide viisi garri saatnud. Minu silmis on Intel halvim IT tarvikute tootja viimased 5 aastat, nad ei oska midagi teha enam. Oli vaid aja küsimus kui AMD neist mööda läheb.
Kuigi olen terve elu praktiliselt nende prosesid kasutanud siis viimased 5a lihtsalt sellepärast, et muud pole osta. Pankrotti neile ei soovi, kuna konkurents on vajalik.
_________________ If you can’t explain it simply, you don’t understand it well enough – Albert Einstein |
215 |
anubis
283 |
217 |
29.10.2020 23:20:01
Kahjuks põhineb Ice Lake disainil mitte uuemal Tiger Lake omal. Lisaks läheb tagasi 8c/16t peale. Cypress Cove lekitas esimesena MLID juba tükk aega tagasi. See pole üllatus.
Vaatame mis see IPC tõus teeb. Praeguse seisuga Zen3 omab kuskil 16% IPC edu 10900K ees. Parimal juhul suudab RL selle võrdsustada aga jääb tuumade arvult piiratuks ja ilmselt ka kuumaks vooluõgardiks tupik platvormil, sest järglane on Alder Lake mis nõuab lisaks prose ja emaplaadi vahetusele ka mälude vahetust uue ja kalli DDR5 vastu.
Mitte, et AM4 tupik poleks aga see oli pikalt ette teada juba ja on mustmiljon valikut mida seal kasutada.
Lisaks pole RL PCIe 4.0 mitte kiibistikust vaid ainult prosest. Seega midagi B550 sarnast.
Auron
30.10.2020 08:36:30
Tomorrow, double digits on nii 10 kui 99 Enne socket 1700 ei julgeks intelilt midagi võtta kui just rahakott puuga niiseljas pole, et pohh ja tahad näppida. AMD' ga vähemalt praegune väga hea ja ega järgmine kehvem saa tulla. See muidugi jahh nats nutune, et AM4'ga aamen ja seda ostes ei saa nigu sellega arvestada, et paari aastapärast võtad siis veits parema CPU muud näppimata.
133 |
anubis
30.10.2020 10:30:26
| ot: |
| Paari aasta pärast on AM4 puhul jätkuvalt olemas alternatiivne upgrade path, näiteks (4c/8t Zen-> 6c/12t -> 8c/16t Zen+) -> 12c/24t Zen2 -> 16c/32t Zen3 |
283 |
Auron
30.10.2020 11:14:25
| anubis kirjutas: |
| ot: |
See tuumade ralli pole tavalise hõumjuuseri/mänguri jaoks eriline teema kui juba miski 8 core masinas.
133 |
anubis
30.10.2020 11:48:34
| ot: |
| Zen -> Zen+ -> Zen2 -> Zen3 ka sama tuumade arvuga on oluline upgrade, eriti kui võtta Zen -> Zen3 |
283 |
Optimist
30.10.2020 13:02:32
| + see teema, et suuremate tuumade arvuga kallimad CPU'd binnitakse tänapäeval nõksa paremini, saab tuumadel mõnevõrra paremad taktid
kapuuts
30.10.2020 13:23:27
| Kui samas hinnaklassis on valikus 5600X ja 3800XT siis puhtalt mänguri jaoks parim valik on?
rene p
68 |
30.10.2020 13:35:12
see pealkiri peab vale olema.
edit:
nii, vaadates 5.1ghz peale jõudva 10700k tulemusi, siis single-core on 14% kiirem (ja 4.35mhz 3800x võrdluses 19%).
179 cs 157 cs 150. average tulemused on olemasolevatel madalamad aga seal on hunnik tulemusi, kus cpu-d ei boosti sinna kuhu peaks (148, mis on ~4.7ghz 10700k ja 143, mis tundub olema ~4.1ghz 3800x).
8-core on 1115 vs 1045 vs 958 (sedapuhku average tulemuste pealt), mis ei ole paha tulemus.
küll aga on küsimus, et mis takti peal see jookseb. ma saan aru, et test mõõdab ja raporteerib aga 4.2 ei kõla kuidagi reaalselt, sest see tähendaks ~38% single-core tulemuse tõusu samale taktile taandatuna.
_________________ - londiste
viimati muutis londiste 30.10.2020 13:50:33, muudetud 1 kord |
217 |
Auron
30.10.2020 13:44:36
| kapuuts kirjutas: |
| Kui samas hinnaklassis on valikus 5600X ja 3800XT siis puhtalt mänguri jaoks parim valik on? |
Mänguri jaoks on ilma küsimuseta 5600X - nö. IPC tõus on korralik.
anubis - jutt käib inimestest kes nö. ostaksid praegu ehk siis B550/X570 plate ehk siis emba kumba kas 3K seeria või 5K seeria. Loogiline on, et kui praegu võtta siis miski 5600X ikka - sellepealt mänguri mõttes pole kuhugi areneda. See teoreetiline 5959 peale kolimine ei anna tattigi kui võibolla paari aastapärast on IPC kasv uutel asjadel 20-30% olnud.
133 |
Vael
30.10.2020 14:22:15
Pole küll AMD teema, aga ma ei väsi kordamast, et mitmikosas kus100+ mängijat, lähevad kõik tuumad käiku, mis ette söödetakse. Eriti veel kui miski rx5700xt masti graafika 1440p peal kõrval...
Imo on 5xxx seeria msrp mõttetult kallis.
Aga mis inteli tulemused siin läbi käivad, kas selle 1165g 8tuumased vennad? Ja millal välja tulemad? Mul kadus järg nende covede ja lakedega juba ammu ära...
| Kommentaarid: 17 loe/lisa |
16 |
Dev Grex
30.10.2020 14:27:52
| 5600x on 50 eurot kallim kui 3600x. Pole just suurem asi hinnavahe.
| Kommentaarid: 362 loe/lisa |
303 |
30.10.2020 14:49:56
| Vael kirjutas: |
| Aga mis inteli tulemused siin läbi käivad, kas selle 1165g 8tuumased vennad? Ja millal välja tulemad? Mul kadus järg nende covede ja lakedega juba ammu ära... |
rocket lake, desktopile q1-2021.
cypress cove ehk sisuliselt ice lakes olevate sunny cove tuumade backport 14nm peale. kuni 8 tuuma, kahekohaline "ipc" suurenemise protsent.
1165g on tiger lake ja willow cove tuumad ehk veel samm uuem arhitektuur.
viimati muutis londiste 30.10.2020 14:51:03, muudetud 1 kord |
217 |
30.10.2020 14:50:29
| kapuuts kirjutas: |
5600X. Sa võidad suuremast IPC-st ja kelladest rohkem kui 6 tuuma pealt 8 peale minemisest. 3-5 aasta pärast võib uutes mängudes olla küll teine olukord aga 5600X peaks kiirem olema lähiaastatel.
Vael
30.10.2020 20:35:21
| Tomorrow kirjutas: |
| kapuuts kirjutas: |
5600X. Sa võidad suuremast IPC-st ja kelladest rohkem kui 6 tuuma pealt 8 peale minemisest. 3-5 aasta pärast võib uutes mängudes olla küll teine olukord aga 5600X peaks kiirem olema lähiaastatel. |
Midagi ei võida, benchmarkis keskmine FPS kasvab, tegelikkuses on SOTR džunglilinnas 2700x\3600 ikka sama <70 jõnksutamine DX12 peal. DX11 ei hakka puutumagi, aga i73700k pealt 2700X peale minnes oli SOTR džunglilinnas 30FPS mõlema prosega. Ammu teada, et 5700XT-le ei jää kuidagi jalgu mõlemad prosed.
Ja 100+ mängijaga mitmikosades on "füüsika" arvutust nii palju, et lisatuumad tulevad kasuks. Igaljuhul 3600 paremaks ei teinud olukorda.
Mu meelest on mõttetu 300€+ 6 tuumase peale panna, kui 2700X 8 tuumase saab 2x odavamalt...Mindfactorys saab 170€ga ning täitsa talutav jahutus on ka kaasas...
Backport. Seesama Ice Lake, mis ainult läpakates oli paari prosega esindatud ja mis perfis alla igasugust arvestust? Ja nüüd 14nm peal tuleb 50% IPC kasv?
Tiger Lake oli küll päris võimas IPC edasiminek, 8 tuuma sellest saaks oleks korralik prose olemas. Aga enne tuleb veel ming 14nm...
Usun sama palju kui Tiger Lake 96EU iGPU 2x perf kasvu;)
Või oli Ice Lake tegelikult hea, ainult et 10nm jäi jalgu?
16 |
30.10.2020 21:11:33
Vael, ice lake on läpakates päris hästi saadaval. perfib samuti väga okeilt, küll aga võinuks olla voolutarve väiksem ja taktsagedused suuremad.
ice lake ipc võrreldes skylakega jäigi sinna 18% kanti nagu intel urundusjutus kilkas.
217 |
degreal
31.10.2020 10:41:29
| IPC-s vist tasuta ei tule. Peab rohkem transistore kellama. Lihtne backport lööks ilmselt powerbudgeti lõhki ja peab taktsagedust piirama hakkama.
| Kommentaarid: 29 loe/lisa |
26 |
31.10.2020 11:02:23
degreal, pigem on ikka transistore rohkem vaja. rohkem cache on rohkem transistoreid, rohkem execution uniteid on rohkem transistoreid jne.
nii või naa paistab, et taktsagedused jäävad skylakelistele pigem alla, küsimus on lihtsalt, kui palju.
8c põhjus on ilmselt just power.
217 |
NATAS999
01.11.2020 10:14:09
| degreal kirjutas: |
| IPC-s vist tasuta ei tule. Peab rohkem transistore kellama. Lihtne backport lööks ilmselt powerbudgeti lõhki ja peab taktsagedust piirama hakkama. |
ipc ja takt ei ole omavahel seotud.
| Kommentaarid: 41 loe/lisa |
39 |
degreal
01.11.2020 11:44:43
| sõnastasin valesti, tahtsin öelda "Peab suuremat hulka transistore kellama". 20% parem IPC aga võtab 20% rohkem voolu. seega vähendame tuumade arvu 20% võrra et voolutarve mõistuse piiridesse jääks.
26 |
One
04.11.2020 12:49:38
| Head nimed ikka, huvitav kas sealt järvest kunagi välja ka saadakse või jääbki lõpp peatuseks.
728 |
04.11.2020 13:19:48
Küll see Vestmann kord taas peal on, lihtsalt aega läheb
182 |
04.11.2020 13:24:21
| Winterwind kirjutas: |
| Head nimed ikka, huvitav kas sealt järvest kunagi välja ka saadakse või jääbki lõpp peatuseks. |
mm, arhitektuurist endast rääkides ice lake ja sunny cove on täna ju täitsa konkurentsivõimelised.
seda, kas rocket lake/cypress cove - mis tundub, et ongi puhtalt ice lakest pärit sunny cove tuumad 14nm peal ja desktopil, sest tiger lake muutused tunduvad poea täielikult olema moar cache - zen3 vastu just arhitektuurisest seisukohast ("ipc") saab, näeb kevadel.
poweri osas üsna kindlasti mitte, see on puhas tootmisprotsessi lugu.
ärilises mõttes on üsna loogiline desktop vaeslapse ossa jätta ja prioriteediks panna mobile (millele aitab kaasa, et neid väiksemaid kive saab intel 10nm peal mingis hulgas toota) ja server (kuigi mul pole õrna aimugi, millega intel serverit müüb - inerts ja aled?).
217 |
04.11.2020 14:29:09
Tomorrow, see oli peamiselt tolle järvest välja saamise kommentaari kohta.
intelil on täna üks probleem - tootmine. kuidas see laheneb, eks näeb. ma ei peaks inteli inimesi rumalateks ja neil on oma tootmise hoidmiseks ja arendamiseks tõsised kaalutlused. kui probleemid aga veel väga pikalt kestavad, ju nad ikkagi lõpuks tsmc või samsungi manu lähevad.
tootmisvõimsusest on kahjuks ainult väga üksikud numbrid teada. tsmc omadest (näiteks amd-le eraldatud osast) teame omajagu aga intelist praktiliselt mitte midagi.
õiged analüütikute dokumendid on kahjuks väga kõva paywalli taga
217 |
pots4t4j4
04.11.2020 18:40:08
| Intelil on knowhow olemas, pappi nagu ka oleks, mis põhjusel nad siis oma tootmisvõimekust ei suurenda ?
401 |
04.11.2020 18:59:16
| pots4t4j4 kirjutas: |
| Intelil on knowhow olemas, pappi nagu ka oleks, mis põhjusel nad siis oma tootmisvõimekust ei suurenda ? |
kurat seda teab.
arvata võib, et jõudumööda suurendavadki. need 10nm ja 7nm hädad sellele kaasa ei aita, sest tehase kummagi peale seadistamine on pikk ja kallis protsess.
samal ajal intel paariks viimaseks aastaks nähtavasti suurendas veel 14nm tootmisvõimekust (osalt 10/7nm plaanitud tehaste arvelt), sest kõik toodang müüdi ära ja jäi puudu.
217 |
Le Inc
05.11.2020 15:58:52
| Inteli läppari prose i7-10510U teeb CPU-Z cpu testis (Ver. 1.94.0.x64) 1 koorik 394 kuni 401 ja kõik koorikud 1947 kuni 2275. Ühe tuumaga läheb üle 4 GHz ilusti.
| Kommentaarid: 56 loe/lisa |
54 |
Harrison
06.11.2020 15:05:08
| Le Inc kirjutas: |
| Inteli läppari prose i7-10510U teeb CPU-Z cpu testis (Ver. 1.94.0.x64) 1 koorik 394 kuni 401 ja kõik koorikud 1947 kuni 2275. Ühe tuumaga läheb üle 4 GHz ilusti. |
Ei tea kuidas sa nii vähe said 1 kooriku tulemuseks i7-10510U-ga, i5-8250U teeb sarnase 1 kooriku tulemuse.
Ise testisin siin hiljuti 3 masinat.
i5-8250U vs R5 4500U vs i7-10510U:
| Kommentaarid: 290 loe/lisa |
259 |
Le Inc
09.11.2020 15:27:25
.. Intel sakib hetkel?
Tõsisemalt rääkides et ei tea jah miks vahe nii väike on, CPU test 1 kooriku tulemus kõikus ka kahtlaselt palju. Kuigi oli värske Win 10 install. Samas masin jookseb sujuvalt ses suhtes teeb oma töö ära küll .
54 |
One
09.11.2020 19:28:16
Lenovo läppar?
Neil võib olla mingi SSD jama, kindlasti firmware ja bios uuendada(kui on uuemaid) ja reeglina lahendas analoogsed probleemid ssd nullidega üle laskmine ja softi reinstall.
PS niisama reinstall ei aidanud, ei tea mis kehva perfi jama neil tehasest on.
728 |
Vael
10.11.2020 17:08:12
TRIM ja clean install küll, aga 0 fill SSDga?
16 |
One
10.11.2020 17:27:35
| Jah, muu kui nullidega üle laskmine ei aidanud, erinevad Lenovo Thinkpadide seeriad sama kalaga.
728 |
Viilutaja
| Kommentaarid: 226 loe/lisa |
196 |
10.11.2020 22:09:11
Varsti on portatiivne konditsioneer prosega kaasas
10.11.2020 22:31:28
Ei aita see TEC kah Intelit. Lisab 500Mhz ja mitusada watti voolutarvet pluss topelt AIO hind veel otsa. Lisaks kondesatsiooni oht emaplaadil. On see kõik seda väärt?
20% defitsiiti niikuinii tasa ei tee Zen 3-ga võrreldes. Pigem paistab nagu plaan F sest B, C, D ja E on edasi lükatud.
Palju rohkem huvitab, et miks on vaja prorietary lisasofti selle käitamiseks? Selleks, et AMD omanikud ei saaks seda kasutada?
Ja lol @ golden sample. Paljud ei saagi 10900K osta ja siin demob intel mingit one in 200 isendit
Kui selle saaks AMD peal tööle häkkida oleks ilmselt tulemuseks 5Ghz allcore mis oleks niikuinii kiirem kui Inteli 5.6Ghz allcore.
10.11.2020 22:51:29
Tule kustutamine bensiiniga
Zuumbox
10.11.2020 23:39:32
| jeesus188 kirjutas: |
Varsti on portatiivne konditsioneer prosega kaasas  |
Oli kunagi selline tore ja vahva arvuti nagu EC-1035 (kes teab, see teab; lähemalt seletama ei hakka )
Protsessorikappi jahutas konditsioneer. Ajalugu kordub
