Perf per watt vahe on ikka nii meeletu, et kole vaadata. Peaaegu kolmekordne...
Eksperimendi mõttes võiks Asus selle i7-10875H samasse sülerisse panna. Siis saaksime testida, kui hästi põleb.
https://www.pcgamer.com/amd-ryzen-3-3300x-3100 "Rumour has it AMD is planning to release two new budget Ryzen 3 processors: the Ryzen 3 3300X and Ryzen 3 3100. Both CPUs are listed as four-core/eight-thread processors, with moderate clock speeds in tow, and appear to be a play for the affordable CPU market ahead of Intel's Comet Lake Core i3s." _________________
The Ryzen 3 3300X will be rocking 4 Zen 2 cores with SMT enabled making it a 4 core 8 threaded machine with a base frequency of 3.8 GHz and a boost clock of up to 4.3GHz. The Ryzen 3 3300X will be paired up with 18 MB of total cache making it 80% higher than the 10 MB found on its predecessor the Ryzen 3 2300X. All of this staying at a low TDP of 65W should make it appealing for smaller builds and requiring a very modest cooling solution. Expect the Ryzen 3 3300X to be available beginning May 21st, 2020.
The Ryzen 3 3100 tones things down just a hair but manages to retain the 4 core and 8 thread Zen 2 based design. Cache and TDP remain the same with a total of 18 MB and a 65W TDP. The biggest change here is the reduction of the base clock to 3.6 GHz and the boost clock to up to 3.9GHz. If that doesn't scare you then the $20 savings over the Ryzen 3 3300X should make the price tag of $99 for the Ryzen 3 3100 a very attractive offer! This chip is also expected to become available beginning May 21st, 2020.
B550 emaplaatide suhtes on nad suht hiljaks jäänud, eriti arvestades seda et uus protsessori seeria on välja tulemas. Võiksid sama hästi selle unustada....
Mina siiamaani ootan B550 platet. Ennem ei uuenda. Aga nüüd on vast juba mõttetu, et tuleb B550 + 4000 seeria cpu. _________________ If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Mis sellel kombol viga oleks? _________________ Dima oli siin
uusi 4c/8t prosesid tahetakse nii odavalt saada? 1600AF on vanem tehnoloogia ja madalama jõudlusega.
mis siis inteli prosedega järelturul saab, tuleks üldse tasuta ära anda? mingid napakad müüsid siin foorumis veel vanu i5 4c/4t prosesid 80-100€. paras lasnamäel asfaldiaukusid lappida nendega.
lisaks, 4t prosega pole väljaspool kontori ja netimasinat enam midagi teha, nõudlikuma töö ja gamingu jaoks on 6-8t prose minimaalne.
anubis, aga kes üldse 2600-ga võrdles? siin võrreldi 1600AF ja uusi 3000 seeria prosesid.
1600af~2600 jõudluse poolest. MP mängudes rohkem tuumasid=parem, mitmelõimerakendustes sama. Ühe tuuma jõudlust vaja siis siiski Intel parem või oodata zen3 ära. Seega jään ikka enda juurde, et võtaks odavama ja rohkemate tuumadega prose, 40raha võitu minimaalse perfikao juures või MP pigem parem perf vs 3300x.
Ma ei kujuta küll ette olukorda kus ma hetkel 3600x peale kolides 20%+ juurde saaks lisajõudlust. Oleks asi nii lihtne olnud, oleks 2700x asemel kohe 3xxx peale kolinud. Hinnavõit oli küll tuntav samas, zen3 peale saab iga kell kolida...
4-tuumalisi i5 3570 prosesi olen ikka 50 EUR/tk ostnud kasutatult siit foorumist. Seda siis juba 2-3 aastat tagasi.
Pigem probleem, et korralikke emaplaate pole enam saada.
neid 100+ euriseid 4 tuumalisi on tänagi mitu tk müügil foorumis. neid on alati müügil - iga kord kui müügifoorumisse asja on võib leida mõne.
müüsin 2 nädalat tagasi oma vana 1700X maha, selle eest kah pole võimalik väga üle 100 euri saada, 8c/16t prose. samas kõrval müüakse mingeid inteli uunikume sama hinnaga
upgrade on rahaliselt odavam, kui on vaja osta ainult 100€ eest uus prose. Teine variant tähendaks juba emaplaat+protsessor+mälu ostu, mis läheb tõenäoliselt veidi kallimaks kui 100€.
Ehk siis kui tahta kiirelt, lihtsalt ja "odavalt" vana käsna veidi upgradeda, siis vist mõned tõesti valivad selle iidse 100€ prose.
Aga see ei tähenda, et see oleks mõistlik raha kokkuhoid
Sest paljud ei oska arvutit kokku panna, prose vahetusega saavad veel kuidagi hakkama.
Upgrade muidugi mõistlikum, ddr4 suht odav, mobod poolmuidu saadaval ja miski 6-8 tuumalise vanema gen prose saad samuti poolmuidu.
Ddr5 on ukse taga kohe _________________ This message was sent from space using stargate
Küsin igaksjuhuks üle ennem kui installima hakkan et Ryzen 3000 seeria protsessori jaoks pean ma BIOSi update tegema. Kas piisab sellest kõige uuemast upddatesit või pean võtma selle versiooni mis on just 3000 seeria jaoks tehtud. Emaplaat on x470 gaming PRO
priitval, Kõige uuem (kuupäeva järgi) on kõige parem. Enamus emaplaatidel saad otse uusima peale uuendada. AsRock oli vist ainus kellel pidi jupiti uuendama kuni jõudsid kõige uuemani (täiesti absurdne imo).
DDR5 tuleb 2021 aasta lõpus Zen4-ga. Enne seda levib see ainult serverites. Isegi Zen4-st ei piisa siiski mainstreami minekuks (vaadake praegu PCI-E 4.0 levikut ja pakkumisi). Selleks on vaja ka Inteli poolset tuge mis juhtub loodetavasti 2022 aasta jooksul. Lisaks on alguses hinnad kallid, kuna tootmismaht on väike. Latentsuse/kiiruse suhe on samuti küsimärk veel hetkel. Ega DDR4 tuli, siis 2133-2666Mhz kiirused @ CL15-22 kah teab mis superhead polnud vs DDR3 @ 1600Mhz CL9 (nn sweetspot nagu praegu on 3200Mhz CL16).
Seega kohe ei juhtu veel midagi. Läheb paar-kolm aastat.
Mul tulevad asjad ukse kaudu tuppa, mitte aknast _________________ This message was sent from space using stargate
Ma siiani mõelnud, et miks mulle omal ajal 4790k juurde just sellist kombot soovitati kindlasti panna
olafsand, Jep igas mälude põlvkonnas (desktop RAM osas vähemalt) on oma nn sweetspot kus hind ja perf on hästi tasakaalus. Alla selle kiiruse kaotab liiga palju jõudlust aga ei säästa eriti rahaliselt. Üle selle kiiruse ei saa eriti jõudlust juurde aga hind tõuseb rohkem jne. _________________ Win11 upgrade skriptid neile kelle masin ise ei taha 23H2, 24H2 või 25H2 pealt ennast uuendada: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738
