DigeBeni
21.01.2019 14:28:54
... see sulgemise probleem on juba väikse habemega ja esineb ka teistes süsteemides, seega ikka Spotify asi korda teha
163 |
softis
21.01.2019 14:59:33
| Draqula kirjutas: |
| softis kirjutas: |
| Ma olen tähele pannud, et Spotify tirib aeg-ajalt playlistis olevaid laule uuesti. Millest see tuleneb? |
Kindel, et playlist pole uuenenud?
Tõmmatakse listi lisandunud laule? |
Ei ole uuenenud. Minu enda lood. Lihtsalt mõned suvalised olemasolevad lood tiritakse uuesti.
| Kommentaarid: 21 loe/lisa |
21 |
olavsu1
külaline
08.02.2019 10:18:12
Klikimagnetist uudisnupuke. Kui reklaame ei taha, siis kasuta tasulist varianti. Nii lihtne see ongi.
| Kommentaarid: 763 loe/lisa |
571 |
softis
08.02.2019 11:58:45
| After it was reported last March that 2 million users (about 2 percent of free Spotify users) were dodging ads with modded apps and accounts, Spotify began cracking down by disabling accounts when the company detected abnormal activity. |
Sellise käitumise eest on üsna okei ju bänniga lajatada.
21 |
12.02.2019 18:18:01
Sain nüüd samuti selle uuendatud kasutustingimuste e-maili. Ei näe probleemi selles.
Hello,
Spotify wants to give you the best possible streaming experience and to make sure you enjoy our service today, tomorrow, and in the future. Our goal is to be as open and transparent with our users as possible. Therefore, we want to let you know that we will be making some changes to our Terms and Conditions of Use, which will be effective March 15, 2019.
The updated Terms and Conditions of Use can be found here. In order for you to easily understand what is changing from the current version of our Terms and Conditions of Use, below is an overview of the most important changes for you:
We’ve made changes throughout to make the Terms and Conditions of Use clearer and more streamlined;
We’ve included updated information about third-party subscriptions, applications and devices;
We’ve updated our User Guidelines, making it clear that all types of ad blockers, bots, and fraudulent streaming activities are not permitted;
We’ve simplified our Brand Guidelines and included an updated link to the Spotify Community Terms (for Customer Support);
Please note that we have made no changes to our Privacy Policy in this update
You do not have to do anything else in order to agree to these Terms. Your acceptance of the updated Terms and Conditions of Use will be deemed to have been granted if you continue to use the Spotify service after the effective date. If you do not want to accept the terms, you can close your Spotify account before March 15, 2019.
Thank you for using Spotify! |
571 |
pois11
12.02.2019 18:32:02
| Kui maksad pappi iga kuiselt siis polegi probleemi.
109 |
12.02.2019 18:41:31
Aga milles tasuta versiooniga probleem seisneb antud juhul?
571 |
pois11
12.02.2019 19:05:29
| Paljud kasutavad tasuta versiooni nii öelda nuditud rakendust. Nad peaksid kuulama lugude vahel reklaame aga rakendus filtreerib ära. Nüüd siis läheb konto kustutamisele kui reklaame ei kuula ja tasulist versiooni ei kasuta.
109 |
12.02.2019 19:10:32
| pois11 kirjutas: |
| Paljud kasutavad tasuta versiooni nii öelda nuditud rakendust. Nad peaksid kuulama lugude vahel reklaame aga rakendus filtreerib ära. Nüüd siis läheb konto kustutamisele kui reklaame ei kuula ja tasulist versiooni ei kasuta. |
Aga see ongi mõte - tahad tasuta, kuulad reklaame. Reklaamid ei meeldi, siis maksa või otsi mõni teine pakkuja. See pole mingi heategevusteenus.
Kas sulle meeldiksid sellised "puugid", kui sa Spotify omanik oleksid?
571 |
pois11
12.02.2019 19:27:35
| Minul polegi probleemi. Kasutan mitmendat aastat järjest perepaketti.
109 |
NATAS999
12.02.2019 20:02:44
| 1 kuu spotify'd maksab 7€, 1 album maksab 15-20€. albumi peal on umbes keskelt läbi ütleme 12-13 lugu pluss miinus. spotifys on miljon triljon gaziljonit lugu. nii rott vend ikka ei saa olla, et isegi enam torrentist ei viicita lugusi alla laadida, kui rahakott ei võimalda seda 7euri kuus kõvale panna.
| Kommentaarid: 41 loe/lisa |
39 |
Draqula
13.02.2019 10:19:24
| Betamax kirjutas: |
| pois11 kirjutas: |
Kas sulle meeldiksid sellised "puugid", kui sa Spotify omanik oleksid? |
Eks inimene otsib ikka kuidas saaks lihtsamalt, soodsamalt ja parem oleks kui tasuta - eriti 50a "õndsat kommunismi" nautinud piirkondades.
Paljud kasutavad veebilehtedel ad-blockereid (mis sisuliselt teeb sama välja - kasutad veebilehe omaniku raha eest loodud sisu ja "jätad teenuse eest maksmata", kuna reklaame ei vaata) ning Spotify puhul ad-blockeri kasutamine võib nende jaoks tunduda loogiline jätk.
Mul on perepakett ja tõesti ei kujuta ette, et viitsiks sellise jamaga tegeleda.
| Kommentaarid: 42 loe/lisa |
34 |
minisvami
01.03.2019 11:43:29
Kakub, hakib ja katkestab, rsk!
Mobiilsetelt seadmetelt (Android 8 telefon, miski Android 6 tahvel) üle wifi striimides jääb muusika vahel suvalisel kohal pausile ja seda peab käsitsi taaskäivitama. Vahel unustab ka ära, et võrgus mõni selline seade, kuhu ta striimis, üldse leidus. Vahel aitab selle viimase vastu force close ja (ka telefoni, tahvli) taaskäivitus. Vastuvõtvad seadmed on Spotify Connectiga Marantzi ressiiver ja Chromecast Audio, konto Premium.
Ruuteri (standardne Elioni wifipurk) ja ressi vahel on ca 3m. Kõrvaklappidega mängib samadest seadmest probleemivabalt, huvitav, kas asi on wifis suunaga purk>ress/chromecast? Ostan täna võrgujuhtme purgist ressini ja vaatan, kas see parandab asja. Teie kogemused?
EDIT: nii oligi, nagu kahtlustasin, juhtmega ühenduse puhul töötab laitmatult. Eks mul ole ressiiveri ümber omajagu rauda.
_________________ OM MONEY PADME HUM! |
| Kommentaarid: 59 loe/lisa |
56 |
571 |
ufo56
| Kommentaarid: 79 loe/lisa |
67 |
29.07.2019 19:51:24
Huvipärast proovisin ka üle mitme aasta, et kuidas musalist on
kaks otsingut tegin ja kumbagi lugu polnud Eks proovib 5 aasta pärast taas
| Kommentaarid: 39 loe/lisa |
31.07.2019 13:58:33
Kaks varianti - kas artist ise blokib või mingi kamm plaadifirmaga. Mul on paar lemmikartisti, kelle vanemaid albumeid Spotify's pole. Elab siiski üle selle "esimese maailma probleemi".
571 |
NATAS999
31.07.2019 14:32:42
| praegu ei tea, kuidas seis on, aga endal ka tulnud ette paaril korral. album ise olemas, aga 1-2 lugu puudu. ja need ei ole mingi special regional edition extra lood. näiteks birthday massacre - red stars oli puudu. oli ainult live versioon vist ja mingi imelik mix. praegu vaatan, et on olemas.
39 |
DigeBeni
05.08.2019 14:23:01
... üsna tavaline nähtus paraku, päris palju kohtab albumeid või kogumikke, mis on kuidagi valikuliselt esindatud ja pahatihti algupäraseid versioone lugudest pole
163 |
pois11
109 |
Éxxon
16.08.2019 14:48:09
Kuidas seda mittesobivust väljendada saab? Peab ära canceldama?
| Kommentaarid: 72 loe/lisa |
71 |
21.08.2019 09:16:42
Kas kellelgi on veel Spotify widget valikutest kadunud Androidi telefonil (Android 8)? Tegin üleeile uuenduse, sest muidu ei lasknud kasutada (kuu aega uuendamata) ja avaekraanilt pärast seda kadunud ning widgetite all samuti pole. Spotify töötab ja rippmenüüs ning lukustusekraanil on olemas. Restardid-reinstallid tehtud.
571 |
Maxstpau
21.08.2019 09:28:44
| Betamax kirjutas: |
| Kas kellelgi on veel Spotify widget valikutest kadunud Androidi telefonil (Android 8)? Tegin üleeile uuenduse, sest muidu ei lasknud kasutada (kuu aega uuendamata) ja avaekraanilt pärast seda kadunud ning widgetite all samuti pole. Spotify töötab ja rippmenüüs ning lukustusekraanil on olemas. Restardid-reinstallid tehtud. |
Minul on ka kadunud (OnePlus 6, Android 9).
100 |
571 |
DigeBeni
163 |
21.08.2019 14:17:50
Eks hääletan, aga tundub, et läheb nagu 2-tasandilise autentimisegagi - mida ei tule, seda ei tule.
Krt, see widget oli jube hea asi. Sai selle mugavalt avaekraanil allossa panna ja ühe puutega Play vajutada. Samal ajal topitakse mingeid videokatkendeid lugude taustale, mida 99% ajast keegi ei näe, sest kuulatakse muusikat ja ekraan väljalülitatud.
571 |
DigeBeni
21.08.2019 15:29:58
... mulle on jäänud pikemat aega juba mulje, et praktilise funktsionaalsuse juurutamine pole nende jaoks ilmselgelt prioriteet ja sellest püütakse võimalusel pigem vabaneda. Foorum on täis väga häid soovitusi, mis on konkureerivate programmide puhul ammu elementaarne, kuid neid ignoreeritakse juba aastaid. Seega üldse ei imesta, et ekraanividinast nüüd kah loobuti. Äärmiselt rumal otsus muidugi, sest droidi jaoks on see funktsionaalsus, mille olemasolu kasutajad eeldavad ...
163 |
alpha
softis
05.09.2019 13:00:19
See vidin on midagi, mille vajadust näen ma ainult selleks, et kiirelt käima panna lustikummut. Lugusid vahetada ja pausitada saab ka teavituste riba või lukuekraani kaudu.
21 |
05.09.2019 13:18:26
See on mugavam kui ülemine riba, sest altpoolt saab kiiremini ja lähemalt kätte.
571 |
131 |
26.09.2019 14:35:02
Täna juhuslikult näppisin widgeteid seoses kalendri uuesti seadistamisega ja Spotify widget samuti tagasi
571 |
zim01
17.04.2020 13:22:30
Kellelgi veel desktop rakendusega probleeme pärast hiljutist Windows uuendust?
Paar päeva tagasi tegin update ja pärast seda enam desktop rakendus ühtegi lugu ei mängi. Vajutan play ja siis skipib lihtsalt kõik listis olevad lood läbi.
Proovitud uuesti sisse logimist, uninstall/reinstall, restardid ette ja taha. Proovisin ka eraldi MS Store rakendust ja veebilehelt allalaetavat varianti.
Telefonis ja veebis toimib.
| Kommentaarid: 98 loe/lisa |
86 |
17.04.2020 13:25:02
Ei ole. Kõik töötab nagu ennemuiste.
571 |
17.04.2020 13:35:37
Kas ma pime või free variandiga ma ei näegi mis lood plaadil/playlistis on või mis lugu järgmisena mängima hakkab?
| Kommentaarid: 95 loe/lisa |
Janar!
17.04.2020 13:51:49
| Kui shuffle all on preview, mis näitab lugusi
69 |
17.06.2020 11:36:02
Ok see on äärmiselt kummaline. Sain meili, et minu spotify kontole on logitult uuest seadmest. Kuskilt ühendriikidest. Meili lõpus on minu meiliaadress.
Ja nüüd tuleb parim osa: mul polegi omateada spotify kontot. Pole kunagi sinna reganud. Ehk siis keegi kasutas regamisel minu meiliaadressi?
Jõle kummaline.
EDIT:
Lol võtsin konto üle password resetiga. Profiiliinfo kah olemas. Tasuta plaan kasutuses:
Account overview
Profile
Username
x9e7zm26h5kp6iexkhdj2j78t
Email
*******@gmail.com
Date of birth
2/2/88
Country
DE |
EDIT 2:
Ja sulgesin konto. Uuesti regamisel ei saa sama kasutajanime enam kasutada aga kesiganes see jobu oli võib ilmselt ikka minu meiliaadressi kasutada uuesti. Eks näis. Juhul kui uuesti regab siis võtan uuesti üle ja jätan aktiivseks, et blokeerida regamised selle meiliaadressiga.
viimati muutis Tomorrow 17.06.2020 11:42:36, muudetud 1 kord |
| Kommentaarid: 92 loe/lisa |
17.06.2020 11:41:53
Date of birth on õige?
571 |
siLc
26.07.2020 15:22:07
| Spotify'd kasutanud oma 6a juba - peaasjalikult mobiiliäpi kaudu autos ja kodus Windowsi rakendusest. Nagu mäletaks, et kui kui alguses kuulasid ühest ja siis läksid kuulama teisest, siis teine mängis edasi sealt kus esimene pooleli jäi. Nüüd mingit aega on mobiili ja töölaua rakendused nagu kaks eri asja, mille vahel peale konto seost ei ole?
186 |
NATAS999
26.07.2020 15:54:53
| siLc kirjutas: |
| Spotify'd kasutanud oma 6a juba - peaasjalikult mobiiliäpi kaudu autos ja kodus Windowsi rakendusest. Nagu mäletaks, et kui kui alguses kuulasid ühest ja siis läksid kuulama teisest, siis teine mängis edasi sealt kus esimene pooleli jäi. Nüüd mingit aega on mobiili ja töölaua rakendused nagu kaks eri asja, mille vahel peale konto seost ei ole? |
telefonist saad panna töölaua spotify käima telefonis pooleli jäänud mussiga. kas/kuidas vastupidi töötab, ei oska öelda-
39 |
26.07.2020 21:00:52
Mobiiliäpist on Show local devices only ikka maha võetud?
571 |
siLc
26.07.2020 22:41:52
| Betamax kirjutas: |
| Mobiiliäpist on Show local devices only ikka maha võetud? |
Jep.
186 |
Kribenski
08.11.2020 19:22:29
| Kas Spotify puhul ei ole võimalik kasutada nt Vene VPN ja saada paar euri odavamalt Premium?
Anna tooli
08.11.2020 19:37:34
| Family paketiga per nägu niigi odav ju
300 |
softis
17.11.2020 11:04:39
Kas kellelgi veel Androidi peal selline kamm on, et peale uuendust on vähemalt 1 allalaaditud playlist seadmest ära kustutatud?
Eelmise uuendusega pidin kõik uuesti alla tirima, peale viimast on jälle 1 puhtaks tehtud.
21 |
17.11.2020 11:44:43
| Kribenski kirjutas: |
| Kas Spotify puhul ei ole võimalik kasutada nt Vene VPN ja saada paar euri odavamalt Premium? |
Spotify.ac kaudu saab
17.11.2020 18:12:59
| softis kirjutas: |
Eelmise uuendusega pidin kõik uuesti alla tirima, peale viimast on jälle 1 puhtaks tehtud. |
Ei ole täheldanud. Mul on pigem cache'iga probleeme. Teen cache'i puhtaks ja paari nädalaga sinna 10+GB kogunenud.
Viimase uuendusega muutus Car View. Kahjuks veidi ebamugavamaks
571 |
24.11.2020 10:29:32
Ei tea, mis häda Spotify'l on, et ei võta kahetasandilist autentimist kasutusele.
https://www.vpnmentor.com/blog/report-spotify-scam/
Igatahes minul kadusid need perepaketi anomaaliad ära, kui lõpetasin Facebookiga sisselogimise. Pole aimugi, kas need on omavahel seotud.
571 |
