| Kas ja kuidas mõjutab teie ostuotsuseid 1.juulist lõppev käibemaksuvabastus alla 22€ kaupadele? |
| Tellin vähem. |
74% |
[ 659 ] |
| Tellin rohkem. |
6% |
[ 57 ] |
| Ei lase end sellest häirida. |
13% |
[ 116 ] |
| Tellin endiselt neid kaupu, mida Eesti müüjad ei paku. |
5% |
[ 47 ] |
| hääli kokku : 879 |
Hiid
20.03.2019 07:42:30
mnjahh
2019.03.18 11:47 (GMT-7): Undeliverable item, has been returned to shipper
2019.03.18 07:22 (GMT-7): The item has been returned and arrived at PostNL
2019.03.14 17:16 (GMT-7): Shipment from country of departure
2019.03.14 16:39 (GMT-7): The address of the item is incorrect and will be returned
2019.03.14 16:39 (GMT-7): The delivery of the item was unsuccessful
2019.03.06 09:00 (GMT-7): The item has been processed in the country of destination
2019.03.05 15:21 (GMT-7): The item has arrived in the country of destination
2019.03.05 15:21 (GMT-7): The consignment has arrived in the country of destination
2019.03.05 06:30 (GMT-7): The item is on transport to the country of destination
2019.03.04 19:12 (GMT-7): The item is processed at the PostNL sorting center
2019.03.04 19:12 (GMT-7): Shipment from country of departure
2019.03.03 09:34 (GMT-7): Acceptance of packet from client
2019.03.03 09:33 (GMT-7): Consignment received at the PostNL Acceptance Centre
2019.02.25 06:53 (GMT-7): The item is pre-advised
2019.02.22 02:17 (GMT-7): The Item is at the shippers warehouse |
| Kommentaarid: 664 loe/lisa |
512 |
Hiid
20.03.2019 17:35:52
Hea klient
Täname meile kirjutamast.
Antud pakil olid puudulikud andmed, seetõttu saadeti saadetis tagasi saatjale.
Paki uuesti saamiseks, palun võtke ühendust saatjaga.
Kaunist kevade algust Teile. |
512 |
avrn
20.03.2019 19:12:38
| salatoimik kirjutas: |
miks õldse confirmima peab? Ma pole seda kunagi teinud  |
Sul on selles veebipoes oma kasutajaprofiil ja sellel on vägagi tõenäoliselt ka see osa mida sina ei näe, aga näevad müüjad.
Kuidas seda kujundada, on igaühe enda asi.
rex
20.03.2019 20:57:40
| Püüdlik ja viisakas hiinlane saadab sulle paki ka siis välja, kui su hindeks seal 1 on.
228 |
avrn
20.03.2019 21:05:17
| rex kirjutas: |
| Püüdlik ja viisakas hiinlane saadab sulle paki ka siis välja, kui su hindeks seal 1 on. |
Sugugi kõik ei ole seal ülearu püüdlikud ega mitte just alati ka viisakad.
Pealt neljasaja tellimuse juures on üht-teist kogetud.
rex
20.03.2019 21:10:59
Okei, püüdlikud ja viisakad vähemalt seni, kuni pole raha kätte saanud, seega tuleb neid harjutada raha kätte saama nii hilja kui võimalik.
228 |
macc
21.03.2019 00:45:03
| pois11 kirjutas: |
| Kas Teil on ka aliexpressis ära kadunud nupp kuhu saab märkida, et olen kauba kätte saanud? Hetkel pole ühelgi tellitud tootel nuppu küljes. |
nüüd uuesti tagasi
| Kommentaarid: 24 loe/lisa |
23 |
Märt.
22.03.2019 07:31:38
| tcumen kirjutas: |
Kuidas seda kujundada, on igaühe enda asi. |
On võimalik endale antud hinnanguid näha.
Vähemalt mõni aasta tagasi oli.
| Kommentaarid: 29 loe/lisa |
23 |
pwn13
22.03.2019 08:21:53
Mul ka nüüd väike mure, sai üks epiip võetud, nädalakese töötas ja kööga. Müüja 100% refundi teha ei taha ja kurdab, et kaotab nii raha. Lubab järgmisel ostul hinda alla teha. Ilmselgelt see mind ei aita. Miskeid arvamusi+
_________________ pWn |
| Kommentaarid: 73 loe/lisa |
68 |
pois11
109 |
rex
22.03.2019 12:02:49
| pwn13 kirjutas: |
| Mul ka nüüd väike mure, sai üks epiip võetud, nädalakese töötas ja kööga. Müüja 100% refundi teha ei taha ja kurdab, et kaotab nii raha. Lubab järgmisel ostul hinda alla teha. Ilmselgelt see mind ei aita. Miskeid arvamusi+ |
Peabki saama sõnumi, et kaotab raha, kui rämpsu müüb. Nõua 100% raha tagasi ja anna teada, et võid asja tagasi saata, kui ta ettemaksuna postikulu tasub. Olen ise paar korda nii teinud, kui on kas vale asi või silmnähtavalt piltidest erinev / rämps saadetud. Raha olen tagasi saanud, toodet pole sel tingimusel kordagi tagasi tahetud.
228 |
SiMka
22.03.2019 12:18:02
Noo.. tagasisaatmine on ikka oma kulu eest.. ja seda kauplejalt nõuda on ikka väga . Aga noh, tänapäeval inimesed ju sellised, et iga asja eest küsitakse/tahetakse kompensatsiooni ja muud..
| Kommentaarid: 15 loe/lisa |
14 |
rex
22.03.2019 12:29:53
| Ei hakka mina küll midagi peale maksma, kui tema vale asja saadab. Puhtalt tema viga ja et ta õpiks, peab see talle rahakoti kaudu tunda olema. Muidu saadab meelega süüdimatult edasi, kuna keegi niikuinii midagi ei tee.
228 |
KillFrenzy
22.03.2019 12:36:50
| SiMka kirjutas: |
Noo.. tagasisaatmine on ikka oma kulu eest.. ja seda kauplejalt nõuda on ikka väga . Aga noh, tänapäeval inimesed ju sellised, et iga asja eest küsitakse/tahetakse kompensatsiooni ja muud.. |
Mis loogika see on, et ostja peaks oma kuludega vale või katkise asja tagasi saatma?
133 |
SiMka
22.03.2019 12:39:31
| Kus või kes ütles, et asi vale või katki on? Nädal aega ju töötas.. ei ole vale ning katkise asja mõte on niiiiiiii suur.
14 |
KillFrenzy
22.03.2019 12:44:05
| SiMka kirjutas: |
| Kus või kes ütles, et asi vale või katki on? Nädal aega ju töötas.. ei ole vale ning katkise asja mõte on niiiiiiii suur. |
Miks peaks nädala pärast katki läinud saasta tagasi saatmise kulud ostja kandma?
133 |
napoleon
Unknown virus
22.03.2019 13:45:44
| pwn13 kirjutas: |
Sul vedas, et üldse läbi tuli. E-sigareti piiriülene kaugmüük on keelatud ehk enamasti saadab toll need tagasi.
Seega võib olla probleeme ka tagasisaatmisega ehk tagasi saates võib ka toll selle kokku korjata.
| Kommentaarid: 79 loe/lisa |
60 |
pwn13
22.03.2019 17:41:52
| napoleon kirjutas: |
| pwn13 kirjutas: |
Seega võib olla probleeme ka tagasisaatmisega ehk tagasi saates võib ka toll selle kokku korjata. |
pole kuulnudki, et keelatud kaup. oma 5tk neid tellinud. eks jauran edasi selle müüjaga.
68 |
napoleon
Unknown virus
22.03.2019 17:49:45
| pwn13 kirjutas: |
| pwn13 kirjutas: |
pole kuulnudki, et keelatud kaup. oma 5tk neid tellinud. eks jauran edasi selle müüjaga. |
https://www.riigiteataja.ee/akt/112122018068
§ 22. Keelud tubakatoote ja tubakatootega seonduva toote jaemüügil
[RT I, 28.06.2016, 3 - jõust. 08.07.2016]
(1) Tubakatoote ja tubakatootega seonduva toote jaemüük on keelatud müügikohas, mis paikneb järgmiste asutuste ruumides või nende piiratud maa-alal:
1) laste hoolekandeasutus;
2) koolieelne lasteasutus, põhikool, gümnaasium, kutseõppeasutus, huvikool, avatud noortekeskus või noorte püsilaager ja noorte projektlaager;
[RT I 2010, 44, 262 - jõust. 01.09.2010]
3) haigla.
(2) Tubakatoote ja tubakatootega seonduva toote jaemüük on keelatud:
1) kandekaubanduses;
2) müügiautomaadist;
3) tänava- ja turukaubanduses kaubandustegevuse seaduse § 17 tähenduses;
4) apteegis;
5) aktsiisilaos;
6) piiriülesel kaugmüügil.
ja nagu kuulda on, saadab toll neid ka suht usinalt tagasi ehk sul on tõesti vedanud, kui kätte oled saanud. Rohkem võid sellest seadusest ise lugeda, mis see kaugmüük on jne.
Niipalju ütlen, et e-sigaret on tubakatootega seonduv toode.
Lisainfot võid saada ka https://nna.ee/ või https://www.e-suits.eu
60 |
pwn13
24.03.2019 09:38:56
Igatahes tegin dispute selle vända kohta.
Igatahes, peaks saama 19 doltsi tagasi, eks näha ole. Ei viitsinud rohkem jaurata selle lambaga.
68 |
Hiid
25.03.2019 17:29:46
krt., ma vaatan et mind on vist üle lastud kuidagi ja dispute ei kehti. Segasüü vms
ei saa inglise keelest suurt aru ka, aga kuidagi teisiti on see asi, kui muidu.
Eesti post saatis paki tagasi, kuna aadress olevat vigane. Müüja ütles, et aadress oli õige.
Ja nüüd on piiks.
Mina kirjutasin:
| 2019.03.18 11:47 (GMT-7): Undeliverable item, has been returned to shipper 2019.03.18 07:22 (GMT-7): The item has been returned and arrived at PostNL 2019.03.14 17:16 (GMT-7): Shipment from country of departure 2019.03.14 16:39 (GMT-7): The address of the item is incorrect and will be returned 2019.03.14 16:39 (GMT-7): The delivery of the item was unsuccessful 2019.03.06 09:00 (GMT-7): The item has been processed in the country of destination |
Aliexpress kirjutab:
We will look at the refund request and make a fair decision based on the information provided by both you and the seller. We will propose a solution which you can find on the dispute details page.
For more information, please check the 'AliExpress' Judgment Details' or your email inbox. While we are looking into this case, you are still allowed to contact the seller and attempt to resolve the issue by clicking 'Add a New Proposal', 'Accept' (to accept the seller or AliExpress' proposal), 'Upload Evidence' or 'Edit' (to modify comments on the proposal).
0 calendar days 0 hour 0 minute 0 second |
Müüja kirjutab:
No return & No refund
New proposal provided
Comments:
No problem with the address |
44 eur
512 |
rex
25.03.2019 20:36:56
Nõua Omnivalt sisse.
Ma just sain mingi kümneka tagasi, kuna 50 päeva oli mingi aeg tagasi üle jooksnud.
228 |
25.03.2019 21:09:05
Ma miskipärast kahtlustan, et neile käis seal omnivas jälle miski üle jõu ja tuima saadeti tagasi mingi kuhi ning siis lajatatakse mingi lamp põhjus. Siit sealt veel kuulnud, et on sel kuul lampi pakk tagasi saadetud kuigi varem samast kohast tellides samade adrede ja numbritega probleemi polnud.
| Kommentaarid: 39 loe/lisa |
shushlik
25.03.2019 21:26:52
See on esialgne otsus, nad teevad lõpliku otsuse mõne päeva jooksul. Mul oli sama keiss ja sain raha tagasi. Müüja väitis, et oma süü, et pakile järele ei läinud, kuid träkingust oli näha, et Eestis oli pakk alla 3 päeva ja tagasi läks sorteerimiskeskusest. Tegin ise nii. Kleepisin Omniva vastuse Google translate aknasse ja tõlkisin inglise keelde (veidi parandasin tõlget). Tegin ekraanitõmmise ja laadisin tõendina üles. Samuti tegin pildi träkingust, kus oli näha, et pakk viibis Eestis lühikest aega, saadeti tagasi sorteerimiskeskusest ja ei jõudnud kohalikku postkontorisse. Panin sinna juurde ka punase noole ja selgituse. Lisaks ka tekstina selgituse, et sorteerimiskeskus ei paku "public service" ja pakile polnud võimalik järgi minna.
| Hiid kirjutas: |
Ja nüüd on piiks.
Mina kirjutasin:
Müüja kirjutab:
Comments:
44 eur  |
Hiid
26.03.2019 08:11:44
| rex kirjutas: |
Ma just sain mingi kümneka tagasi, kuna 50 päeva oli mingi aeg tagasi üle jooksnud. |
nõme on see, et kui Omniva midagi otsustabki maksta, siis pakile märkis hiinlane väärtuseks 5 usd ja mingi muu kauba üldse
Saatja saatis tõenduseks pakisildi, kus on aadress kõik korrektne.
saatsin Omnivale päringu, et pangu endapoolne pilt, ebaselgest aadressist.
Näis, mis saab.
512 |
26.03.2019 08:16:20
| Omniva on nii ja naa...üldiselt üle 200.- asju ei tasu liigutada, siis saad ikka raha tagasi.
201 |
26.03.2019 08:28:18
Hiid, aadressi teisele reale topi oma telefoninumber
Hiid
26.03.2019 08:35:40
praegu vaatan jahh, et seda seal eiole. Mul on aadress aliexpressis salvestatud ja alati on telefon ka seal juures olnud.
512 |
pois11
26.03.2019 08:45:03
| Võibolla sai aadressi koht kahjustada, et ei olnud enam võimalik välja lugeda kellele pakk on.
109 |
26.03.2019 08:57:17
| Hiid kirjutas: |
praegu vaatan jahh, et seda seal eiole. Mul on aadress aliexpressis salvestatud ja alati on telefon ka seal juures olnud.  |
Telefoninumber tuleb topelt panna, sest paljud ei lisa numbrit pakile.
Sp aadressi teisele reale tuleb lisaks number panna
Su pildi järgi see pakk ei oleks saanudki kohale jõuda, numbrit njetu
avrn
26.03.2019 11:25:08
Mnjaa, tundub, et Omnivale ei saa palju etteheiteid teha. Kui siis seda, et nime järgi oma andmetest ei otsitud seonduvat tlf. numbrit.
Ja ega nende oskus pakilt seda numbrit leida ei ole ka teab mis suur. Mulle viimasel ajal tuleb neid pakiteatisi juba üle ühe paberil, kuigi tlf.nummer pakil ka kahes kohas kirjas.
Aga selle pildiga saaks nüüd Aliexpressilt õigust nõuda, selgitades, miks on telefoninumber ilmtingimata vajalik.
Nende support peaks minu meelest ka vene keeles asjatama, kui see inglisest suupärasem juhtub olema.
Hiid
26.03.2019 11:26:34
jeesus188, kõigil pakkidel on number peal, mis alist tulevad. Viimasel real. Aadress seal salvestatud, seda ma ei muuda iga kord eraldi
512 |
KillFrenzy
26.03.2019 11:36:09
Omniva lehel oled ära reganud ennast selle aliexpressi jaoks?
Sellejaoks see peaks olema, et kui näiteks number puudu siis saavad sealt otsida.
133 |
26.03.2019 12:02:45
| Hiid kirjutas: |
jeesus188, kõigil pakkidel on number peal, mis alist tulevad. Viimasel real. Aadress seal salvestatud, seda ma ei muuda iga kord eraldi  |
No siis enamus müüjaid on toredad ja panevad numbri peale. See müüja paraku polnud nii tubli. Sp ka aadressi teisele reale tuleks oma number panna, see on alati siis olemas kui müüja ei suvatse numbrit lisada.
See ju ühekordne tegevus, miks sa peaksid seda iga kord tegema hakkama?
Ebay näide
veiko xxxx
tel: 5019054, pagusoo xxxx
sõmeru vald, ussimäe küla 442xx
Estonia
+372 5019054 |
Green_Day
26.03.2019 13:17:12
| Kui sa just esmatellija pole, siis on võimalik nime järgi ka varem kasutatud telefoninumber üles otsida. Või kui oled Omniva lehel end reganud. Ilmselgelt poõe keegi viitsinud liigseid liigutusi teha lihtsalt.
| Kommentaarid: 7 loe/lisa |
A.S.
26.03.2019 13:23:58
| jeesus188 kirjutas: |
| Sp ka aadressi teisele reale tuleks oma number panna, see on alati siis olemas kui müüja ei suvatse numbrit lisada. |
Kusjuures näiteks UK saatjad suudavad idioodi järjekindlusega numbri ka sealt eemaldada. Pole küll Aliga seotud, lihtsalt teadmiseks.
| Kommentaarid: 34 loe/lisa |
34 |
Hiid
26.03.2019 17:18:14
| KillFrenzy kirjutas: |
Sellejaoks see peaks olema, et kui näiteks number puudu siis saavad sealt otsida. |
ikka jahh. Tegin seda esimese asjana, kui hakkasin pakiautomaati tellima, teie soovitusel
Mis nad kirjutavad ka? Pean ootama 3 päeva vä?
Dear Laur Hiiemae,
Thank you for contacting AliExpress. I am sorry to hear that you are not satisfied with your order 99166193781604.
We have traced the tracking number and found the package was returned by the shipping company. And the seller would contact with the shipping company to check the returned package within 3 calendar days. Please be kindly waiting for seller's response.
Problems with the order Judgement from AE Invalid Reason
Package was returned to seller by shipping company Valid -
Package Information
PostNL LX634251517NL Package Returned
Solutions:
Option 1: Please continue to wait for 3 days
Response time: 3 days
Waiting for seller's response, you can also resolve the issue by clicking 'Add a New Proposal', 'Accept' (to accept the seller or AliExpress' proposal), 'Upload Evidence' or 'Edit' (to modify comments on the proposal).
Note: If you have already settled the dispute with seller, please kindly give a response in the dispute detail page so that we can be informed and follow this dispute based on the settlement.
Your understanding and cooperation will be appreciated.
Best regards,
AliExpress Case Management Team |
512 |
avrn
26.03.2019 19:18:17
| Hiid kirjutas: |
Pm küll. Sinu kontol peaks olema nüüd avatud selle tellimuse kohta "dispute"
Selle all mingeid nuppe näppida ei ole vaja praegu ja midagi acceptida ei tohi.
Hiid
26.03.2019 19:34:40
selge- Siis ootan
eesti post ütles, et kuna telefoninumbrit peal ei olnud, siis saadeti kohe tagasi ja asi ants.
Ei jõudnud kaugemale, kui pealattu.
512 |
napoleon
Unknown virus
26.03.2019 19:40:24
| A.S. kirjutas: |
GDPR võibolla. Rohkem andmeid kui teenuse pakkumiseks vajalik ei tohi ju nõuda ega partnerile edastada ja kuna välismaise müüja jaoks paistab see pakiautomaadi aadress samasugune nagu iga muu aadress, siis telefoni nagi ei tohigi anda kui tegemist pole saadetisega, mille kuller kohale toimetab.
See on juba ammu selge, et ülereguleerimine kaitseb mõnda üksikut kriminaali, aga tavainimese elu pigem häirib
60 |
KillFrenzy
26.03.2019 19:40:39
| Omniva on selle aliexpressi jaoks regamise vormi üldse maha võtnud, ju siis sai neil isu täis telefoni numbrite otsimisest.
133 |
napoleon
Unknown virus
26.03.2019 19:44:31
| Või siis pole seda vormi vaja enam. Ma kunagi ammu tellisin midagi e-bayst pakiautomaati ja tuli kohale ja seal omniva lehel ma ennast siis reganud polnud.
60 |
pois11
26.03.2019 19:48:06
| Omniva on selle aliexpressi jaoks regamise vormi üldse maha võtnud, ju siis sai neil isu täis telefoni numbrite otsimisest. |
Ammu pole vaja enam midagi ära regada: https://www.omniva.ee/era/kiri/aliexpress_pakiautomaati
Üldiselt niipalju kui on tutvusringkonnas teemaks olnud siis ei tasu antud teenust harrastada. Hea näide juba siit mõned postid tagasi võtta. Tellides kodusele aadressile tuleb vähemalt paber lipik postkasti. Vähemalt tallinnas on selges saadud, et postkontoris saab paki kiiremini kätte kui oodates seda kappi.
Aga eks igaüks teab ise kuidas oma rahaga riskida.
109 |
avrn
26.03.2019 20:11:55
Üks asi, mida enda seljataguse kaitsmiseks võiks teha:
Kui te tellimust vormistate, siis vähemalt Alis on selles tellimuse vormistamise aknas üks lahter, peale aadressi ja makseviisi valiku: "Leave a message for this seller".
Sinna võiks jätta siis oma erisoovid müüjale. Kasvõi tlf.numbri pakile kirjutamise vajadus või et kauba õige väärtus pakile kirjutataks.
Ma usun, et teistes keskkondades on selline asi ka mingil kujul olemas. Isegi kodumaistes veebipoodides on pea alati mingi märkuste või kommentaaride lahter olemas.
rex
26.03.2019 21:09:24
| pois11 kirjutas: |
| Üldiselt niipalju kui on tutvusringkonnas teemaks olnud siis ei tasu antud teenust harrastada. Hea näide juba siit mõned postid tagasi võtta. Tellides kodusele aadressile tuleb vähemalt paber lipik postkasti. Vähemalt tallinnas on selges saadud, et postkontoris saab paki kiiremini kätte kui oodates seda kappi. |
Selle tagasiside nad võiks ka saada, et kui niiviisi pohhuilt tagasi saatmistega näkku nussivad, siis levib sõna, et seda teenust enam ei kasutataks. See peaks neile päris motiveeriv piitsameetod olema, kuna loogiline oleks arvata, et juhatus sooviks propageerida pigem vähema inimeste osalusega pakkide liikumisi - postkontori inimestest tahetakse pikemas perspektiivis siiski lahti saada.
228 |
XeStAiSy
Aeg Maha 2a
27.03.2019 18:51:27
Keegi võiks pakkuda soovitust trackingus waitng for pickup juba olnud 10 päeva. Ostin ühest kohast 2 asja 1 pandi kohe shippment cancelled, siis pandi uus tracking kuna see oli tehtud ühel ajal ja vist lootus sealt midagi saada pole. Mina küll enam 60 päeva ootama ei hakka. Vähegi tundub kahatlne ja tracking ei liigu kohe dispute ei ole mõtet oodata 60 päeva ja siis müüja hala lugada mida veel pikendatakse jä ikkagi tuleb dispute teha sest pakki pole teelegi pandud.
Aliexpress müüjad peavad kümmne päevaga tellimuse regama, nad registreerivad trakingu kuhugi süsteemi. Kui kas pakk ise kohale viiakse on teine asi. Tihti neil polegi seda kaupa mida saata. Ilmselt kogu jama tekib või sihilikult eesti nad ei taha saata.
Minul on olnud praktiliselt igakord 1 ost alt vedama läinud just sellega ,et peab dispute tegema. Platinum member, siis selle leveliga saab alati kobinata raha tagsi ükskõik mis ka ei ole.
Varasemate aastatega ei pidanud ühtegi disputed tegema kõik jõudis kohale. Viimane aasta ainult olnud mingi dispute teema. Selline ootamine tegelikult on jama, ootad oma 20 päeva siis kulub veel aega dispute jaoks, siis veel x aega millal raha tagasi saab. Sisuliset võib minna 2 kuud ja ikkagi mida tahtsid tuleb teisest kohast osta uuesti.
_________________ Punktkeevitus patareidele/akudele. Akutrelli/laptopi/e-bike. PM
viimati muutis XeStAiSy 27.03.2019 19:15:02, muudetud 4 korda |
| Kommentaarid: 12 loe/lisa |
27.03.2019 18:52:00
Sa pane oma tekstis esialgu punktid ja komad paika Siis võibolla viitsiks ka sisusse süveneda
n3wb0y
27.03.2019 20:00:44
Kas see on ok, et minu tracking näitab, et keegi on Kristiine keskusest (Tallinn) minu paki välja võtnud kuigi pakk pidi Võrumaale tulema Pakk ise ei tohiks kohal olla veel. Tea kas see number mulle kuidagi vale saanud või miks näen teise inimese pakki?
24 |
avrn
Green_Day
27.03.2019 22:41:37
Väga levinud probleem. Küsi saatjalt õige kood.
viimati muutis Green_Day 28.03.2019 11:07:22, muudetud 1 kord |
