01.02.2019 21:38:49
laadimisajad on kole pikad.
ilus näeb välja küll.
selline nõme online mäng tundub, bulletsponge vastased ja team-only.
_________________ - londiste
217 |
Kris1
01.02.2019 21:40:39
| HDTanel kirjutas: |
| Okei ma juba näen ära miks see mäng sureb esimesel nädalal.. väga lappes.. tahan seda lõpu missiooni minna hard tasemel tegema aga matchmaking ei leia MITTE ÜHTE inimest ka, kes seda teeks.. ja üksinda ei lase mitte mingil juhul mängida :/ fuck this. Juba näen ette kuda ootad sada aastat matchmakingut ning kui mängu jõuad on isu juba läinud ja ALT F4. |
Olen aru saanud et ainult Strongholdid nõuavad 4 inimest - ülejäänud storyt saab läbida ka üksi.
| High-Q kirjutas: |
| demosse ei jõudnud PC jaoks mõeldud KB+M patch. |
Jep arendajad kirjeldasid täna redditis muutusi mis demosse ei jõudnud, kuid on 15/22 releases.
PC kontrolli muutused:
https://www.reddit.com/r/AnthemTheGame/comments/am3lvf/pc_controls_update_aiming_and_flight/
Hey All,
Thanks to all of the amazing feedback last weekend during the VIP Demo, we have some updates to share on PC Controls. These are updates for LAUNCH (15th Feb / 22nd Feb). Unfortunately we couldn't get these fixes in for the open demo this weekend.
TL;DR - Aiming uses raw mouse input. Flight & Swim controls are improved and more responsive.
Aiming
Raw Mouse Input Fixed
-We found and fixed a bug that caused the symptom of negative acceleration
Flight and Swimming
Increase Available Range for Mouse Sensitivity Options
Flight and swim sensitivity sliders now allow for more than double the range it offered before. This allows different mouse DPI settings (specifically extremely high or low) to better fit into our in-game swim/flight sensitivity settings.
PC Flight Box is now a Circle
PC Flight Cursor is now constrained by a circle boundary instead of a box. This allows better turn/speed management as the distance away from center dot (which dictates the speed of your turn) is always the same maximum amount in any direction.
Added Auto-Centering for PC Flight
Added auto-centering behavior on swimming and flying by default for PC.
When mouse input stops (after a delay) the crosshair will automatically return to center.
Resolved bug with Sprint/Fly on Button Press
We’ve resolve a jittering/FX spam issue bug that players would receive when playing with hold-to-fly (rather than toggle) option for flight.
Raw Mouse Input is now achievable in PC Flight
By setting Flight/Swim Response and Precision settings sliders to 0% you can now achieve raw mouse input.
Default Flight and Swim Sensitivity Settings Updated
All default PC flight and swim sensitivity settings are now tuned to 1200 DPI instead of 1800 DPI.
Default flight and swim sensitivity changed from 50% and 35% respectively, to both being 40%.
-This is the same as having both set to 100% with our previous sensitivity tuning, and since swimming was lower sensitivity than flight it’s seen an even bigger boost in responsiveness at default settings.
Tuned Flight/Swim Response and Precision Default Settings and Curves
The defaults are now much closer to raw mouse input.
Adjusted defaults for Precision / Response:
25% for flight and swim precision down to 15%
50% for flight and swim response down to 30%
Tweaked flight and swim response to ease into the slowing down behavior close to center in a less steep way than before.
Once the game launches, we look forward to getting more feedback and we are prepared to make more improvements as needed |
PC UI muutused:
https://www.reddit.com/r/AnthemTheGame/comments/am4ovn/pc_ui_updates_for_launch/
Hey All,
Similar to the PC controls thread, thank you all so much for your feedback on the UI for PC players. Below are some changes we are making for LAUNCH. We were unable to get these in for the open demo this weekend
Summary
We have made numerous updates to menu and Forge navigation with mouse and keyboard on PC since the Demo build. In Early Access (15th Feb), you will see improvements like using Q and E to navigate tabs and being able to drill into menus by clicking the visible options on the right side (except Social menus which are coming for the Worldwide Launch 22nd Feb). In the Forge you will notice that rotating and zooming your character are more responsive.
We are also working on improving our graphics options on PC. For Worldwide Launch (22nd Feb) the issues with Motion Blur will be addressed along with adding an option to toggle HDR on or off. We are adding the ability to adjust camera shake with a slider to help alleviate any issues with motion sickness for Worldwide launch (Feb 22). We are also actively investigating adding an FOV slider to the game. We understand the importance of this option for a large numbers of players. In addition we are investigating adding options for FPS Limit and HDR Brightness in future patches. More information on that when we have it.
List of Changes for Launch (15th Feb / 22nd Feb)
UI Clicking on visible options in menus fixed for 15th Feb (except social which is 22nd Feb)
Navigating Menu tabs with Q and E instead of old keybindings fixed for 15th Feb
Forge rotation speed with mouse improved - 15th Feb
Scrolling with mouse wheel wont zoom your javelin AND scroll the menu (will be contextual based on where your mouse is) - 15th Feb
D-Pad will show as keyboard bindings - 15th Feb
Turning off Motion Blur in settings now works (decoupled from post processing) - 22nd Feb
HDR toggle available - 22nd Feb
Camera Shake slider added - 22nd Feb
Thanks again for all of your feedback, we look forward to continuing to listen and make changes as needed. |
HDTanel
Overclocker
01.02.2019 21:51:51
Jaa nagu ikka.. kurb, et chattida ei saa.. null suhtlust võõrastega.. kui konsoolidega chattida ei saa siis ei tohi nagu millegi peal saada... cries in PC..
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
Vihmausss
01.02.2019 21:53:05
see 144hz feels like 60hz, r2me lag ja unplayable w m/kb
| Kommentaarid: 13 loe/lisa |
AlvinL
01.02.2019 21:57:57
Uninstall ka siit poolt. Destiny tunne koguaeg, kehvasti optimiseeritud, online mäng, millel puudub chat. Vaatab, mis aasta pärast saab.
_________________ Võimatu on teha midagi lollikindlaks, sest lollid on haruldaselt leidlikud. |
| Kommentaarid: 18 loe/lisa |
17 |
Kris1
01.02.2019 21:58:05
| HDTanel kirjutas: |
| Jaa nagu ikka.. kurb, et chattida ei saa.. |
Jep sellest väga kahju. Tõesti loodan et see asi mis tulevikus lisatakse.
HDTanel
Overclocker
01.02.2019 22:04:53
Tore ka see, et saad surma ütleb "RESPAWNING" ja midagi ei juhtu kuni keegi ei ärata sind ellu..
Kukkusin selle lõpu bossi alguses maha ja mitte keegi kordagi mind ellu ei äratanud tiimist lol... mitte sittagi teha ka ei saa ala chattida või mikri karjuda.
vist ei saa mind enam see missioon rohkem revivida vms?
| Vihmausss kirjutas: |
| see 144hz feels like 60hz, r2me lag ja unplayable w m/kb |
Jep mingi motion blur vms..
496 |
heretic666
01.02.2019 22:11:12
| Ma ei saa aru miks chati ei ole .. samahea kui windowed mode mängul peal ja fullscreen mode ära kaotada.
| Kommentaarid: 73 loe/lisa |
Vihmausss
01.02.2019 22:41:37
| HDTanel kirjutas: |
Jep mingi motion blur vms.. |
Post Proceccing low peale siis eiole
kaido163
01.02.2019 22:50:56
| A-lvin kirjutas: |
Uninstall ka siit poolt. Destiny tunne koguaeg, kehvasti optimiseeritud, online mäng, millel puudub chat. Vaatab, mis aasta pärast saab.  |
Sain Destiny 2 mingi aeg kuskilt tasuta... ja kui neid kahte võrrelda, siis tundus Destiny 2 single player hulka huvitavam ja parem kui see Anthem. Pealegi oli ka Destiny 2 graafika väga ilus ja FPS palju parem.
Eks aeg näitab aga pool tundi demot mängides ei tekkinud mingit WOW effekti. Destiny 2 proovides igatahes oli juba alguses tunne palju parem.
_________________ EBV  |
| Kommentaarid: 24 loe/lisa |
24 |
High-Q
01.02.2019 23:10:03
põhimure demotajatele on vast see, et anthemis laskmine on suht tühikargamine või trashmobide mahavõtmiseks. enamikjuhul ikkagi abilityd, nende combotamine ja eriti meeskondlik panus. Ainult, et madala leveliga ei ole just väga palju kraami veel lahti.
text chat oleks tore, aga tänapäeval kipub siiski voicechat võitma. hea seegi, et push-to-talk on täisa olemas.
97 |
HDTanel
Overclocker
02.02.2019 16:06:38
Kõige rohkem killib ikkagi loading screenid... täitsa lõpp.. pole pikka aega mingit MP põhist mängu mänginud kus nii haigelt loading screene on.. ugh
edit: Kurat see loading screenide crashimine on küll kohutav ikka.. tahan siin kõiki Javeline proovida erineva geariga ja noo kaheksal korral kümnest sitt crashib loadingu lõpus :S väga väga lappes mäng ikka.. räägivad, et demo pärast pikad loading screenid aga crashid?
edit2: oskab keegi öelda mida kuradit tegema peab, et neid cage lahti teha seal Tyranti missioonis? Redditis kustutatakse kõik teemad ära kui küsid mängu questi kohta infot :S tra eile terve tiimimga olime seal 30minutit... kuni KEEGI lõpuks midagi tegi.. aga ma ikka ei saa aru MIDA.. chatti pole, mikreid keegi ei kasuta..
496 |
Killhoven
OC`er
02.02.2019 18:23:24
Leidsin kah emase üles (spider queen), aga crashis ja enam tagasi sinna madinasse ei saa. See suur ümmargune uks on kinni. Ühel tiimikaaslasel sama lugu.
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
| Kommentaarid: 409 loe/lisa |
351 |
ahvilõust
02.02.2019 20:54:40
Milline okse mäng. Täis seda paska mis praegu moes mängudes.
Lisaks gameplay on ka sitt. Lendamise juhtimine on nii mööda. Lisaks mängida saab ainult grupis. Ja siis ka mingite jobudega, kes farmivad midagi või lihtsalt meeldib rushida.
Vaenlased tahavad liiga palju tulistamist, et üksinda nendega jamada. Nii et ei kõlba see kuhugi. Järgmine online only mäng, mis jobude mängijate poolt ära rikutud saab.
_________________ Gdesainer |
| Kommentaarid: 8 loe/lisa |
HDTanel
Overclocker
02.02.2019 21:17:15
ahvilõust, Vaenlased tahavad liiga palju tulistamist? Kõik peaks mingi oneshot olema? Iga RPG on selline, et kõrgemad kollid on rohkemate eludega ja kui sitt gear siis teedki zero dps-i.
496 |
virx
03.02.2019 03:19:45
No ei saa absull aru kus on selle mängu fenomen. Shootimine tundus nagu Far Cry 5s...halb ühesõnaga. Jookseb mitte tihti vaid ainult alla 30 fps Xnox X peal..peale mõnda minutit mängus olles hakkas juba minu okse refleksi meeter tööle ja peale 20-t minutit oli kogu mäng läinud kah kettalt. Loodetavasti Metro eeltellimus läks õigesse kohta
| Kommentaarid: 363 loe/lisa |
308 |
Dj-E
Aeg Maha 2a
03.02.2019 04:51:41
| virx kirjutas: |
Loodetavasti Metro eeltellimus läks õigesse kohta  |
Oleneb kust kohast tellisid.
| Kommentaarid: 22 loe/lisa |
21 |
03.02.2019 05:37:20
| Kommentaarid: 92 loe/lisa |
heretic666
03.02.2019 13:04:23
Kurdame PC mängude teemas kui halb mäng on sest jookseb halvasti Xbone peal
Eks ta kangesti mass effecti meenutab. Minu arust seda mõtet ainult tuttavatega mängida, randomitega suht jura.
Gameplay animationid on väga sujuvad.
kuccu
03.02.2019 13:36:44
Sai ka veits proovitud. Tomorrow lingitud videost seda imelikku 100% cpu kasutust sain ka tunda, hetkel siiski tundub, et jääb ostmata.
Kunagi hiljem ehk vaatab uuesti kui manti juurde pannakse ja vead ära silutakse.
Isu ajas küll aga peale ja hetkel tõmbab warframe-i taustal.
Vael
03.02.2019 13:43:22
Sain gruppi lv14-15, ehk kes juba midagi mõikas. Liiga palju kohati, teadis obj ja rushis. Kuna obj nagunii mõttetu pallikest kogumine, siis vähemalt madistada sai.
Üksi tyleb jah mitu korda respawnida, et Eliite maha saada, 2si juba on ability peale ja tehtud ka. Ainult tulistamisega hakkama ei saa jah.
Pmst on chokepointid, paned ability peale, kombo otsa ja vähemalt 5 vaenlast pikali. Kaaslased ka mõikavad midagi, siis on hakklihamasin.
Graafika tõmbasin Medium peale Fury x-ga, ilusti 80 FPS, vahepeal kukub aga mitte hullult. Välja näeb ikka ilus.
Lendamine on lihtsalt jube, vb tahab harjumist ka. Tulistamise kohta ei saa midagi paha kosta.
UI on täielik mõistatus, selleks, et mängu minna, tuleb Enter(q,f,e vms) asemel ESC vajutada, no kes sellise lolluse peale tuli?!!!
Missioonide ning Javelinide valimine on ka loto. Linnas peaks joosta saama.
Pole üheski (rpg) mängus nii kaua kosmeetikale pühendanud, mecha fännina on tähtis, et rüüs saab kõiki juppe välja vahetada ja välimust muuta hetkega. Värvivalik rakendub hetkega, see on küll hästi korda läinud. Kui nüüd Legendary rüü juppe paywall taha ei peideta, siis võiks isegi grindida.
Varandust kukub ikka kolinal, üheski videos pole juppide vahetamisele ja valmiatamisele tähelepanu pööratud, hea et prooviversioon olemas. Muidu olekski jäänud mulje, et ainult MT saab varandust.
Selles suhtes tõmbas mäng kohe endasse nagu Diablo, saab lootida ja arendada.
Esimest korda ei tahtnud üldse ühendada, restart aitas arvutile. Loopis ka välja Tower missiponist. Laadimiaajad on küll pikaldased, aga mingi hetk tundus, et hakkas poole pealt juba mängu sisenema, cacheb midagi? Server shuttdown teadet andis ka, per player ajalimiit peal?
Nüüd oleneb, kas lendamine, ühendumine mängu, liikumine saadakse väljalaske ajaks sujuvamaks. Kui jah siis hüppan ka Javelini.
| Kommentaarid: 17 loe/lisa |
16 |
heretic666
03.02.2019 13:53:30
Stability teena serveritel on suur probleem, näis kas release ajaks infra mured lahendatud.
Menüüde ülesehitus on jah saast mis saast, konsoolist 1:1 üle toodud PC peale nagu fallout 76.
Vael
03.02.2019 20:03:41
Bossi ajal saab küll elustada, respawnida ei saa. Ise elustasin ja mind ka poputati jalule;)
HDTanelile siis...
Missiooonides eriti kraami ei pudene, freelance mode täiendab küll pauna kiiresti kasuliku kraamiga.
Vb õige ka muidu jääks missiooni ajal osa rahvast laegast uurima ja edasi ei areneks lugu.
16 |
-myyr-
03.02.2019 20:33:19
Tegin ka esimese proovi pela ära.
Destiny 2te olen ka mõned korrad lasknud aga sarnasus on märgata.
FPSi probleeme polnud, kõik ultra ja keskeltläbi koguag 60fpsi, ei kurda absoluutselt.
Chati puudumisega nõustun,väga vajalik tegelikult.
Aga samas isegi ostaks, kuna tundub päris mõnus jällegi
_________________ Autovaruosad Pärnus/kuni -30%
www.mardigarage.eu |
| Kommentaarid: 6 loe/lisa |
HDTanel
Overclocker
04.02.2019 14:42:42
| virx kirjutas: |
No ei saa absull aru kus on selle mängu fenomen. Shootimine tundus nagu Far Cry 5s...halb ühesõnaga. Jookseb mitte tihti vaid ainult alla 30 fps Xnox X peal..peale mõnda minutit mängus olles hakkas juba minu okse refleksi meeter tööle ja peale 20-t minutit oli kogu mäng läinud kah kettalt. Loodetavasti Metro eeltellimus läks õigesse kohta  |
Metro näeb suht igav välja.. need open world instanced näevad kuidagi väga igavad välja ja videotest vaadates pole seal midagi erilist tarka teha ka.. oleksid võinud ikkagi lineaarse süsteemi juurde jääda.
496 |
High-Q
04.02.2019 15:14:05
| mul isegi täitsa ok tundus. kui nad pisut parandavad lendamist/ujumist, siis pole nii hullu. destiny2 on muidugi hulga seeditavam ja algajasõbralikum. Aga, võibolla samas ka igavam. Sarnasus muidugi on suur. Mõlemal on n.ö tutvustav campaing või kohustuslik osa, kuid kõik see siiski viib endgame-farmimiseni ja lõppude-lõpuks ikka nühid sama sisu.
97 |
Scart
04.02.2019 15:44:39
| Täna on viimane päev võtta üks kuu Origin Access Basicut ühe euri eest, millega tuleb kaasa ka kümme tundi Anthemi release-versiooni accessi alatest 15. veebruarist. Pole just paha diil.
101 |
HZo
04.02.2019 17:00:11
Scart, tänud.
Võtan ligi.
Selle raha eest on proovimist küll.
| Kommentaarid: 30 loe/lisa |
Dj-E
Aeg Maha 2a
04.02.2019 18:40:22
Ei ole seal Originis isegi selle raha eest midagi pelada.
_________________ HV - Eesti kõige debiilsem kommuun!!! |
21 |
saihtam
| Kommentaarid: 16 loe/lisa |
15 |
Kris1
11.02.2019 20:29:22
Nagu videos ka öeldud 15ndal näeb ära kuidas mikromaksed on. Mind ennast see teema väga ei häiri - see et ainult kosmeetilised asjad on päris rahaga ostetavad, ja neid asju saab ka mängus sees teenida on minusilmis hea kooslus. Kui palju see mikromaksete poole kaldu on näeb 15ndal ära, aga minu mängimist see ei sega (vähemalt esialgu).
Võtsin ka muidu Origins Access Premieri (või mis selle nimi oligi) ära, saab juba see nädalavahetus mängima hakata. Tahaks story osa läbi teha, ja siis näeb kui palju mängulusti päras seda veel järel on (loodetavasti piisavalt).
heretic666
11.02.2019 20:37:17
| No mis seal kaldu saab olla kui ainult cosmetic itemid on microtransadega ja seda ka ilma RNG gamblinguta.
Kris1
11.02.2019 20:57:49
| heretic666 kirjutas: |
| No mis seal kaldu saab olla kui ainult cosmetic itemid on microtransadega ja seda ka ilma RNG gamblinguta. |
Kaldu mõtlesin suhtes mängusisese teenimisega. Ja eks 15ndal näeb kui kaldu (ning saab paremini hinnata kui häid asju müügil on - kui palju muudetavaid detaile jne jne).
Aga väga vähetõenäoline et midagi ostan - kui tõesti peale lvl30 jõudmist veel mänguisu suur, siis annab edasi mõelda.
Vael
11.02.2019 21:40:48
Ülehomme saab preloadida jah.
MT koha pealt- pole peale Dead Space nii palju kosmeetikale tähelepanu pööranud, pool lõbu selles mängus ongi raudrüü meelepäraseks tuunimine. Kui see tasuliseks muudetakse ja varandusena midagi ei pudene, siis juhtub nagu teistegi EA mängudega, cancel Premierile peale 1. kuud.
Eks jah nv juba paistab, pole enam kaugel.
16 |
KrisVr
15.02.2019 18:14:14
| Põhimõtteliselt peaks LIVE's olema Origin Access kasutajatele...aga serverid on nagu on!
Vael
15.02.2019 20:30:30
KrisVr, Täpselt, Play nupp on olemas aga ühendus mitte, ega ei oodanud ka EA-lt seda:P
Twitteris teatasid juba, et tegelevad probleemiga. Ses suhtes on lähenemine õige, et ei peideta pead liiva alla, vaid antakse juba mängus teada, et kust saab teavet rohkem ning antakse teada, et probleemiga tegeldakse. Muidu on tavaline vastus olnud, et mine kontrolli oma ruuteri seadeid;)
EDIT: Kohe sai sisse ka. Matchmaking on ikka aeglane, jalutab kiiremini linnnas? Sprint küll ei tööta.
Poodi ei pea õnnek kuhugi linna teise otsa jooksma, mapis ESC all hoida siis viskab poodi, Rewards alt leiab ka boonus rüüd(Legion of Dawn Premium Accessiga).
Esimene missioon Normaliga, sai kambast eemale mindud ja üksi Multi-Kill Combosid lvl 4 ga tehtud, ehk siis kohe peale Tutorialit. Tutorial oli ka hästi mu meelest lahendatud.
MT seisneb siis selles, et saab Shards´e $€ eest osta. Kõike kaupa saab poest Shards või mängus kogutud Coin eest soetada. Ehk kõik on vaba kõigile, ainult kui ei viitsi grindida, siis saab ka lihtsamalt kraami kätte. Ainult kosmeetikat ja animatsioone saab siis poest? Relvad pudenevad niisama kollidest?
So far, so good.
16 |
High-Q
15.02.2019 21:03:32
seni kõik hästi. alguses pidin korra restart game tegema, muidu oli nagu kunagi hdtanelil, et ei leidnud ühtegi matchmakingu parterit. nüüd ok.
lendab ja ujub imho pisut paremini kui betas. eks ikka mõni wall-faceplant tulnud, aga pole hullu, saab ka kitsas koridoris lennutsi navigeerida.
hetkel tegin vaid paar missi ära, et asjad unlockida. teen pisut teisi asju ja ajan tatikad magama, siis võtab õhtul hiljem ette.
97 |
heretic666
15.02.2019 22:16:27
| Peab ka prem accessi ikka sis ära habama krt, beta ikka meeldis.
Vael
15.02.2019 23:51:28
| Keegi kampa soovib lüüa, siis ma Wboson...
16 |
Kris1
16.02.2019 00:45:57
Alguses paar missiooni teinud, ja seni nautinud. Loodetavasti kestab lõpuni.
Vael
16.02.2019 22:59:18
Lõbu sai läbi Tyrant Mine juures. Mitu korda sai ainult 1 mängija läbi, teised jäid ukse taha, jälle restart. See oli raske missioon, raskem kui betas minu meelest. Ja kui veel 3 Colosseust ka kokku pandi, siis oli täitsa piin läbida.
Combosid ei tulnud, lihtsalt tulistamisega läks terve igavik. Lõpuks sai boss napilt tehtud, kui ainult Interceptor ellu jäi. Ma juba ootasin Squad Defeati:P
Kuidas siin tugevamate kaaslastega mängimisel vastased muutuvad? Ise olin lvl 11, teised 13-18lvl.
Võiks saada missiooni alustamisel\respawnimisel Javelini tüüpi valida, tobe on kui kõik on ainult ühest klassist ja kombosid ei tule.
Colosseus tundub üldse tobedalt ehitatud olevat. Paned kilbi ette, pärast laskmist viskab kilbi ära- surnud. Kõigi tegevuste jaoks võtab kilbi eest, st automaatselt Low Health peale kukkumist, teistel klassidel läheb enne Shield, siis kilp. Raskerelva laadimine, eriti granaadiheitja, võtab terve igaviku. Seega kuna kilpi pole siis on relva laadimisel 5 sekundit kerge märklaud- jälle surnud. Pmst muud ei saanudki teha kui kilp ees pätakatest üle joosta ja siis vahel Abilitied kasutada. Relv oli täitsa kasutu käes. Võiks elustamisel ja laskmisel kilpi saada ees hoida.
16 |
Kris1
17.02.2019 01:32:03
Täna edasi mänginud. Origins näitab kogu mänguaega 8 tundi, sellest ehk mingi 5 täna. Kuna story peaks olema kuskil 15 tunni kanti, siis ehk olen kuskil poolepeal, üritan põhi ja kõrvalasju segamini teha. Kohe kukub level 13.
Kui alguses üritasin solo, siis edasi olen teinud randomitega ja nii tundub rohkem fun. Aina enam tundub et nii ka loodud (mis pole üllatus) - üksi tehes on kogu vastate tähelepanu sinul, ja on rohkem punnitamist - kui teised mängijad abiks, saab rohkem combodele keskenduda, ja targemalt tegutseda. Olen mänginud ainult Rangerina, ja viimastes ülesannetes on mind paari pandud ka Rangeritega - on see juhus, või on tegemist popima javeliniga praegu. Teisena on mul Interceptor lahti lukustatud, kuid pelgan kuidas ma sellega hakkama saaks. Võibolla homme hommikul natuke harjutan temaga Freeplays.
Vael
17.02.2019 09:21:49
Freeplays tasub igat uut relvasüsteemi ka katsetada;)
Uue Javelini kasutuselevõtul kulus Crafting ära, muidu oleks lvl 1 rwlvadega välja läinud.
Kas uncommon Javelin mingit boonust ka annab?
16 |
heretic666
17.02.2019 13:11:39
| Olen Interceptoriga mänginud nüüd palju kuna meeldib tema kiire liikuvus. Samas peab tõdema et Titan / Ämblik bossude puhul on Interceptor täiesti kasutu sest mõõkadega ei saa vehkida hiigelkõrgel olevat weak pointi ja siis lased tuima oma machine pistoliga ..
Vael
17.02.2019 13:57:49
Koos oleks lihtsam;)
Tegin just 1h üksi Titan vastu, lõpuks ei saanud missiooni lõpetada, sest Interact(F) nupp ei töötanud
16 |
Scart
19.02.2019 00:45:53
| See quest on bugine. Osadel loeb enne seda kvesti tehtud sammud ja osadel mitte.
101 |
