Foxhole is a massively multiplayer game where you will work with hundreds of players to shape the outcome of a persistent online war.
This is the ultimate game of collaborative strategy and tactics. Every action you take can have a powerful and permanent effect across a vast world in a constant state of war.
Key Features Player Autonomy - Every solider is controlled by a player. Players ARE the content.
Sandbox warfare, where players determine the narrative of a long term war
Emergent strategies and tactics make every part the war feel unique
Your character stays active in the world even after you've gone offline
Build your capacity to contribute to the war by acquiring resources, crafting, and building
Persistent World - Join hundreds of players in a shared, war torn universe. (Praegu serveri limiit on 120 inimest)
Capture and setup supply lines to keep your frontline well equipped
Execute long term strategies that take weeks of planning, changing the tide of the war with minimal casualties
Conquer and relinquish territories in a back and forth, high stakes conflict
Play as a persistent character throughout the war, gaining notoriety and influence among your faction
Realistic Combat - Tense and cerebral battles that keep you on the edge of your seat.
Ammunition, resources, and information are limited, requiring players to work together to survive
Dynamic battle conditions: Use the time of day and terrain features to gain an advantage
Combat where skills and strategy matter more than stats or XP points
Reconnaissance is as important as firepower
Hetkel ikka väga pull ja pelame. Lambist sattusimr mingi teise eestlase otsa ka. Sõda käib, soovitan soojalt!
EDIT: keda huvitab mis praegu toimub - Eesti-Inglise segastriim http://twitch.tv/mihkeljacksoff _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
Võtsin isegi mängu ligi. Kaasahaarav, süvasukelduv. Olles põlvkonnast, kes raamatuid veel luges, kunas arvutimänge polnud, siis
väikese fantaasiaga saab päris hea elamuse. Olles mutrike suures mängus, kus üksi pole keegi.
Aga inglise keelt vaja küll jah...
Praegu palju uuendusi tulnud, ilmselt võtame oma seltskonnaga mingi hetk jälle ette. _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
Proovisin seda ka nüüd mängida, kuna mingil ajal sai see muretsetud. Esiteks on algajal väga keeruline midagi aru saada, mis lahinguväljal täpselt toimub...Et kuhu peab minema või mida täpselt kaitsta. Kuidagi palju infot oli korraga kaardil. Küsisin ka mingeid juhiseid, et kus, mis, kuidas ja mida. Aga vastust ei tulnud. Lisaks mingid vennad ainult ropendasid ja vingusid seal kõigi kallal. Panin mängu kinni ja rohkem ma seda tõenäoliselt ei mängi.
Kahju et selline kogemus. Muidu hea mäng. Tavaliselt on leidunud tüüpe kes kenasti õpetavad ka.
Seal mitu varianti kuidas mängida.
1. Teed logistikat ehk siis vead materjale või teed materjalidest juba relvi jms ning vead õigesse kohta. Kus mida vaja - tuleb chatist küsida kuhu koorma viid. Ntks särke, karabiine, ammot jms alati vaja. Bmate ka. Nüüd vist näeb kaardilt ka kus mida puudu on - vaja ainult uurida kus põhiline front on kuhu vaja kraami.
2. Lähed otse sõtta, uurid kus liin hetkel on ja kus madin käib.
3. Ajad paar sõpra kokku ning teed nendega koos midagi - me oleme nt ehitanud 4-5kesti normaalse baasi mis vahepeal sai kogu tiimi päästvaks kommandopunktiks
Et seal tuleb alguses natuke süveneda ja pärast on fun juba. _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
No see, et rohkem ei mängi tuli ka ilmselt sellest, et veri kees sellel hetkel natuke Kindlasti proovin uuesti. Peab vist lihtsalt pundi leidma, kes seletada natuke viitsib.
Me mingi pundiga vahepeal mängisime ja tulevikus ehk veel. Hetkel oleme küll Hell Let Loose maanias.
https://discord.gg/Tv2Jrb5 selles discos koguneme. Jälgi seda või paku ise välja. _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
Mängul tuli suur update välja" Trench Warfare", mis lubab labida kätte võtta ning hakata kaevikut kaevama. Hiljem saab seda igasuguste punkrite ja muude asjadega uuendada. Otsustasin ka minna ja proovida ning kogemus oli super. Sattusin ühe saare peale, kus tegutses paarikümneliikmeline peamiselt uutest mängijatest koosnev grupp. Kuna olen seda mängu ka varem mänginud, olen saavutanud majori auastme, määrati mind juhtima saare kaitset. Määrasime kiirreageerimise üksuse mis ka reaalselt toimis, meil olid oma logistikud, mehitasin posti rannale, kes pidas valvet ja andis häiret kui järjekordne vastase laev saabus. Ehitasime saare igasse külge kaudtule tarbeks haubitsad, kuid kuna uued mängijad ei saanud aru kuidas nendega laskmine täpselt käib, siis pidin ise binokli haarama ja neile kõik numbrid ette andma. Samuti töötas meil masinapark soomukitega. Kuna viimane sõda meie factionil hästi ei läinud, siis jäi saar umbes neljaks päevaks vastase tagalasse. Meie kaitse pidas pikalt vastu, kuid kuna enda omad olid kaugel ja logistikat me enam ei saanud siis lõpuks ikka murdusime.
See oli minu viimane seiklus. Mängu saab mängida üksi, kuid grupiga on kordades lõbusam. Kui keegi soovid in-depth õpetust või lihtsalt veidi pelada siis võtke steamis lisada. https:/steamcommunity.com/profiles/76561198053033231
Kui kahtled, kas osta mäng- siis vastus on kindel JAH.
