sõnum |
RaidoR
18.05.2017 16:30:53
ID-kaardi lugeja(d) ei installeeru |
Tegemist W7 pro 64bit. millel ID-kaardi lugejad ei installeeru. Proovitud kahte erinevat lugejat.
Device manager annab errori:
"Windows cannot verify the digital signature for the drivers required for this device" Code 52 error.
Syslog kirjutab: driver \Driver\atrfiltr failed to load for the device
Proovinud olen installida seadet:
* Disable Driver Signature Enforcement modes
* Chipset ning usb driverite reinstall
* Kustutasin Upfilter/lowfilter registrivõtmed HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{36FC9E60-C465-11CF-8056-444553540000}
* Uninstallisin kõik usb hubid/pordid device managerist.
* sfc /scannow
* Tegin läbi need sammud:
1- Open Windows Explorer
2- Go to C:/Windows/System32/DriverStore
You will have a couple of folders and files.
You will have *.dat files and other file named: infcache.1
3- Right click every file (dont touch the folders!) and choose properties.
4- go to security tab
5- click Edit
6- choose your account and check the box: full control (see ss)
7- Click ok.
8- Repeat to every file
9- Select all the files (*.dat and infcache.1)
10- Press shift+del
11- Press OK.
12- Now, go to C:Windows/System32/Driver Store/File Repository/
13- Search for folder named usbstor.inf
14- Open it (if you have more than one, choose the most recent)
15- Copy "usbstor.inf" and "usbstor.PNF"
16- Paste those two files to C:/Windows/inf
Teised USB seadmed (hiir, pulk) töötavad, seega otseselt pordi viga ei ole. Tööle ei saa ID-kaardi lugejaid.
Ideid?
Kommentaarid: 52 loe/lisa |
50 |
Märt.
18.05.2017 17:02:15
Tõmba draiver käsitsi?
Proovi Snappy Driver Installer?
Kommentaarid: 29 loe/lisa |
23 |
RaidoR
50 |
FullHC
18.05.2017 17:14:25
Ühel Delli läpakal Win 7 x64 Pro-ga hakkasid asjad ID-kaardi lugejaga jooksma kui peale sai lastud 64bit Vista driver.
Enne seda lihtsalt ei suutnud aru saada kui ID-kaardi lugeja oli ühendatud.
Ehk täpsustad, mis masinaga/configa sul tegu?
Kommentaarid: 195 loe/lisa |
182 |
RaidoR
50 |
19.05.2017 16:08:52
Draiver on valmistaja poolt allkirjastamata. 64-bitine windows seda enam vaikimisi paigaldada ei lase.
Võimalikud variandid:
- otsid uuema ja allkirjastatud draiveri
- kui esimene variant pole võimalik, siis saab allkirja kontrolli ka välja lülitada. Sel juhul jääb ekraanile tekst, et windows töötab testirežiimis. Tekstist saab ka lahti vajadusel.
Esimene variant on igal juhul parem, kui vähegi võimalik.
Kommentaarid: 33 loe/lisa |
RaidoR
20.05.2017 08:58:04
Tootja kodulehel olev draiver on allkirjastatud - ei toimi. Syslog kirjutab ikka \Driver\atrfiltr failed to load for the device
Samuti lülitasin allkirja kontrolli välja, kuid paigaldada ei õnnestunud.
50 |
WäntWõll
make.believe
20.05.2017 11:19:40
services.msc leia Windows Driver Foundation - mis staatus on stopped või running ?
Peab käima, kui vaja siis startup "Automatic" ja masinale restart.
Kommentaarid: 373 loe/lisa |
299 |
RaidoR
22.05.2017 09:30:03
Oli Manual ning Running staatus. Lükkasin Automatic ning tegin resa.
ID-kaardi lugeja järgi pistan, siis kohe märk küljes ning syslog kirjutab endiselt: driver \Driver\atrfiltr failed to load for the device
50 |
Cemtey
22.05.2017 10:54:35
Proovi id.ee ja sk.ee supporti.
Start -> Run -> Dxdiag, windowsi andmed pane juurde.
Kord tööle ei saanud, ei osanud nad midagi öelda. Tuli alla laadida kõik sertifikaadid (nende kodulehel lingid) käsitsi ja paigaldada brauserisse. Siis hakkas kaarti lugema ja id haldusliides hakkas tööle.
St eeldasin ka, et probleem draiverites, oli hoopis sertides. Lahenduse neile kribasin, ei tea kas KKK alla läks.
Eraldi käis plugini aktiveerimine ja allalaadimine brauseris, küllap automaat setup ei suutnud tol ajal sellega hakkama saada.
Kommentaarid: 18 loe/lisa |
17 |
RaidoR
22.05.2017 12:12:38
Kirjutasin sk supporti, ehk oskavad kuskilt otsast kinni hakata.
50 |
WäntWõll
make.believe
22.05.2017 16:02:11
tsitaat: |
ei ole võimalik
Mingi Firefox autentimine teatud veebiserveri puhul võib olla, muud küll ei mõjuta.
tsitaat: |
sellest pole ka täna pääsu kuna brauseri tootjad on kiusupunnid va. IE mis on täis AIO.
299 |
matu21
26.02.2018 19:42:29
See on mingi Win Update puudujääk. Kui kõik uuendused peale tõmmata, läheb korda.
Hea oleks muidugi, kui saaks teada selle 1 ja õige, et ei peaks kõike saasta peale laskma
_________________ Kõik, mis mul müügiks on, küsi julgelt soodushinda : www.digimarket.ee
Kõiki kaupasid saan müüa ka järelmaksuga
Kasutatud arvutid ja laptopid Tartus, Vanemuise 43 |
Kommentaarid: 1357 loe/lisa |
1039 |
DeTHiCa.
26.02.2018 20:16:57
mul oli sarnane jama paar kuud tagasi. lõpuks jooksis windowsil terve usb süsteem rappa ja ei saanud midagi enam kasutada (sülearvuti).
pidin recovery partitsioonilt taastama tehaseseaded et masinat uuesti tööle saada.
Kommentaarid: 144 loe/lisa |
136 |
LKits
Kommentaarid: 13 loe/lisa |
RaidoR
27.02.2018 11:28:50
Ma tegin kõik variandid läbi, mis windowsi fiximiseks saadaval olid
50 |
KyBer
21.03.2018 11:40:48
Maadlesin ise ka sama veaga, et id-kaardilugejaid ei tunnistanud ja kui kõik uuendused tehtud siis hakkas tööle
Esimese hooga isegi id-kaardi tarkvara keeldus käima minemast.
Kommentaarid: 112 loe/lisa |
96 |
RCC
12.02.2019 22:34:08
pärast koodikaartide kaotamist omal sama jama. kuhugi on kadunud smart cardi servic ja draiverite puhul errror code 52, eks tuleb hakata pangakontoris käima.
_________________ piirkonnas on tõrge - turutõrge. mullnett, 1ns , 870M iops, 1tb/s |
Kommentaarid: 183 loe/lisa |
8 :: |
146 |
Märt.
15.02.2019 08:07:58
Ära virise, vaid tee asi korda.
Kui XP, siis pead kaasaegsemat OS-i nüüd kasutama hakkama.
23 |
RCC
15.02.2019 10:50:48
teeks, ainus võimalus on minna redmondi ja õpetada neile pisvinni tegemist. xp-ga ju idi-kat kasutada ei saagi, kuigi seal pole usbiga mingeid muresid. - veakood ikka tavaline - Windows cannot verify ... (Code 52" - ja see kehtib konkreetselt usbi ühendatud kaardilugejatele - sh ka mälukaartidele. enne töötas, pärast id-i softi installimist enam ei tööta. ehk tuleb oodata, kuniks id-ikäki uuesti uuendavad ja ehk võtavad sellele ka siis ms-i allkirja. siis see ilmselt nati aega töötab, kuniks see järgmise uuendusega uuesti peeti keeratakse - uuendused uuendused uuendused. - selmet teha üks töötav asi.
8 :: |
146 |
15.02.2019 13:21:41
smartid / mobiilid..
_________________ Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER! https://www.yaga.ee/mox-fulder
https://www.facebook.com/marketplace/profile/100087345405856/ värskeim loetelu. |
Kommentaarid: 1104 loe/lisa |
704 |
Märt.
17.02.2019 21:49:35
laurx, ta on põhimõtteline mitteedasiliikuja.
23 |
17.02.2019 22:06:13
ma saan aru, teatud puhkudel see id kaardilugeja töötamine ka vajalik kui sul oin smartcardiga sisselogimine domeeni nt aga siin on viimasel ajal igasugu kalasid nii palju olnud, et varsti on tunne,et peaks omale pinkalkulaatori ka igaks juhuks hankima..
704 |
seeru
18.02.2019 00:08:13
Peale id-tarkvara uninstalli tuleb ikka varjatud ja mitte varjatud kaustad ka käsitsi maha kustudada ProgramData alt, users-user-AppData-Roaming alt.
eID, RIA, digidocpp nimelised ja mingid kaustad võivad veel olla.
Ja pärast puhas install.
LKits
