praegune kellaaeg 06.06.2024 02:46:30
sõnum |
tequ
20.01.2008 12:30:33
Probleem DNS serveritega |
Tere!
Mul on probleem nimeserveritega, loodan, et keegi oskab aidata.
Nimeserverid jooksevad Bind 9 peal.
Kui secondary dns maha läheb, siis millegipärast ei ole enam võimalik domeene resolvida.
Veider on veel selline asi, et peale secondary dns mahaminekut, sain dnscheck.net kaudu sellise vastuse:
CheckDNS.NET is asking root servers about authoritative NS for domain
Got DNS list for 'cooper.ee' from NS.EENET.ee or NS.EENET.ee
Found NS record 'cooper.ee', but could not resolve it to IP, answer from 193.40.56.245: host 'cooper.ee' not found.
Found NS record: office.cooper.ee[213.219.118.142], was resolved to IP address by NS.EENET.ee
Domain has 2 DNS server(s)
CheckDNS.NET is verifying if NS are alive
DNS server cooper.ee failed and will be dropped from other tests
Error fetching SOA from office.cooper.ee [213.219.118.142], request timed out. Probably DNS server is offline.
0 server(s) are alive
No DNS servers alive, tests stopped
Kui aga secondary dns uuesti tööle panna, siis domeenid resolvivad sekundiga kohe ära. (Isegi kui secondary dns on ööläbi maas)
checkdns.net näitab siis, et kõik on korras:
Got DNS list for 'cooper.ee' from ns.ut.ee or ns.ut.ee
Found NS record: office.cooper.ee[213.219.118.142], was resolved to IP address by ns.ut.ee
Found NS record: cooper.ee[212.47.220.120], was resolved to IP address by office.cooper.ee
DNS server office.cooper.ee[213.219.118.142] is alive and authoritative for domain cooper.ee
DNS server cooper.ee[212.47.220.120] is alive and authoritative for domain cooper.ee
2 server(s) are alive
kaabakas
20.01.2008 14:09:15
Huupi lasen - äkki on esimene kogemata ainult forwarder/cache teisele?
Kommentaarid: 103 loe/lisa |
93 |
incx
21.01.2008 00:55:05
Sama domeeni all asuvad domeeniserverid on alati tore kamm. Uuri tausta selliste asjade kohta nagu "glue records" dns-is ja vajadusel kurda eenetile. Paistab, et office.cooper.ee'st teab ns.eenet.ee paljutki (aga sellest pole suuremat kasu, sest nagu paistab, on see su maas-olev secondary) ja cooper.ee'st ei tea ta muhvigi.
Kommentaarid: 20 loe/lisa |
20 |
Andrus Luht
itimees.ee
21.01.2008 01:15:29
Võtame siis kõigepealt dig'i ja vaatame, mis see arvab:
; <<>> DiG 9.3.3rc2 <<>> cooper.ee
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 20053
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 0
;; QUESTION SECTION:
;cooper.ee. IN A
;; ANSWER SECTION:
cooper.ee. 38390 IN A 212.47.220.120
;; AUTHORITY SECTION:
cooper.ee. 259190 IN NS office.cooper.ee.
cooper.ee. 259190 IN NS cooper.ee. |
Masin nimega 'office.cooper.ee' aga ei vasta üldse pordist 53 nimepäringutele. Sestap ka domeeni 'haihtumine' 'cooper.ee' masina vaikimise korral.
EDIT: Sul seal ikka paras kamm. Saada oma servude cooper.ee tsoonifailid. Praegu on pilt üsna kummaline:
cooper.ee. SOA cooper.ee rene.cooper.ee. (1166633902 10800 3600 604800 38400)
hilfiger.denimdream.com. A 88.196.158.158
cooper.ee. NS cooper.ee
cooper.ee. NS office.cooper.ee
cooper.ee. A 212.47.220.120
cooper.ee. MX 10 cooper.ee
cooper.ee. MX 20 sip.cooper.ee
classic A 217.159.212.126
clonedsouls A 212.47.220.120
domina A 159.148.204.220
ns.cooper.ee A 212.47.220.120
ns2.cooper.ee A 213.219.118.142
eluaeg A 212.47.220.120
galerija A 217.28.50.6
guess A 90.190.142.114
hostility A 212.47.220.120
jaanus A 212.47.220.120
jarve A 217.159.191.5
johvi A 80.235.127.66
joint A 212.47.220.120
junior A 217.159.212.146
kaubamajakas A 90.190.96.10
koerahoidja A 213.219.118.142
kristiine A 80.235.113.210
liis A 212.47.220.120
louna A 80.235.112.102
mail A 212.47.220.120
mailadmin A 212.47.220.120
maile A 212.47.220.120
mrtg A 212.47.220.120
mysql A 195.50.208.137
narva A 217.159.171.190
ns2 A 213.219.118.142
office A 213.219.118.142
office2 A 213.219.118.142
parnu A 217.159.155.8
pierrecardin A 217.159.212.58
pildid A 212.47.220.120
rait A 212.47.220.120
rene A 212.47.220.120
rmm A 212.47.220.163
rocca A 80.235.114.249
shadow A 80.235.107.208
sikupilli A 80.235.114.27
sip A 194.204.44.17
site A 195.50.208.137
sixty A 88.196.158.134
spice A 62.63.129.179
stats A 212.47.220.120
sten A 212.47.220.120
tartu A 84.50.186.186
test7 A 212.47.220.120
testtt A 212.47.220.120
tommy A 213.35.191.101
viru A 217.159.213.70
voip A 194.204.44.17
work A 194.204.44.17
www A 212.47.220.120
ylemiste A 217.159.202.186
www.teknolink.ee. A 212.47.220.120
cooper.ee. SOA cooper.ee rene.cooper.ee. (1166633902 10800 3600 604800 38400) |
_________________ Äriklassi serverilahenduste müük, paigaldus ja haldus. SaaS / PaaS / IaaS lahendused
Tier-3 privaatpilvede, virtuaal- ja virtuaal-privaat-serverite lahendused. 24/7 haldus, monitooring |
Kommentaarid: 377 loe/lisa |
318 |
lisa lemmikuks |
