Markx
| Kommentaarid: 92 loe/lisa |
83 |
Anti
10.12.2006 03:51:15
Intel Celeron M 420 1,6GHz
512MB DDR533
107,922
240 |
AJ
11.12.2006 15:22:41
wPrime 32M 158,953 sec
| Kommentaarid: 37 loe/lisa |
36 |
ivar43
12.12.2006 06:53:15
w-Prime v.1.28
skoorid
32MB (speed Test) - 31,906 sec
1024MB (stability Test)- 1016,563 sec
/ 12-12-2006 / 4:08 /
CPU Found: CPU0
Name: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+
Speed: 2640 MHz
L2 Cache: 512 KB
CPU Found: CPU1
Speed: 2639 MHz
L2 Cache: 0 KB
? millegi pärast Everest näitab CPU x2 5000+
aga tegelt on AMD x2 4600+ / ( mitte AM2)
everest info :
CPU Properties
CPU Type DualCore AMD Athlon 64 X2 5000+
CPU Alias Manchester
CPU Stepping BH-E4
CPUID CPU Name AMD Athlon(tm) 64 X2 Dual Core Processor 4600+
CPUID Revision 00020FB1h
CPU Speed
CPU Clock 2640.0 MHz (original: 2400 MHz, overclock: 10%)
CPU Multiplier 12.0x
CPU FSB 220.0 MHz (original: 200 MHz, overclock: 10%)
Memory Bus 220.0 MHz
DRAM:FSB Ratio CPU/12
CPU Cache
L1 Code Cache 64 KB per core (Parity)
L1 Data Cache 64 KB per core (ECC)
L2 Cache 512 KB per core (On-Die, ECC, Full-Speed)
Motherboard Properties
Motherboard Name Asus A8N32-SLI Deluxe
Chipset Properties
Motherboard Chipset nVIDIA nForce4 SLI X16, AMD Hammer
Memory Timings 3-3-3-8 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
SPD Memory Modules
DIMM1: Corsair CMX512-3200C2 512 MB PC3200 DDR SDRAM
(3.0-3-3-8 @ 200 MHz)
(2.5-3-3-7 @ 166 MHz)
(2.0-2-2-6 @ 133 MHz)
DIMM2: Corsair CMX512-3200C2 512 MB PC3200 DDR SDRAM
| Kommentaarid: 14 loe/lisa |
rewer
12.12.2006 15:15:50
32M
39,046 sec
X2 3800+@2200MHz
| Kommentaarid: 1309 loe/lisa |
922 |
1dumbpcuser
97 |
antikondor
15.12.2006 18:18:53
Sai ome uut opteron 165 piinatud veidi.
9x311 1.4v
Mälud 200 mhz 2.5-3-3-7
Aeg 30,375 sec
http://www.hwbot.org/result.do?resultId=562639
_________________ Olen jah muusika suhtes elitaarne sitapea
000 WHILE hangover
001 drink beer |
| Kommentaarid: 48 loe/lisa |
45 |
okas5
15.12.2006 20:41:48
Celeron 2.66 GHz, 256 mb pc2700 ram. 130,969 sec
_________________ Võtan suurtes kogustes tagastamata laenu ja muid vidinaid. Kõik pakkumised PSi  |
| Kommentaarid: 11 loe/lisa |
rewer
15.12.2006 23:18:11
| kodulehelt ei leidnud- win98-ga vist ei tööta?
922 |
WäntWõll
make.believe
300 |
hashi
16.12.2006 00:24:05
P4 2,8GHz HT
1GB PC3200 DDR 2,5-3-3-7
101,15 sec
_________________ Seniks...
Hashi |
| Kommentaarid: 32 loe/lisa |
30 |
SirVorkars
16.12.2006 01:53:57
x2 3800+
ja aeg 41,859
56 |
CoiL
16.12.2006 02:24:16
päris hea skoor ju 1core kohta PS! oleks tore kui Jaan HV wPrime tabelit uuendaks.
| Kommentaarid: 95 loe/lisa |
83 |
okas5
16.12.2006 03:58:55
Sõbra AMD Turion 1.6ghz, 1gb ram läpakas pani mu 2.4 kellule pika puuga
Läpakal 55,219 sec
super kelllul 130,969 sec
WäntWõll
make.believe
16.12.2006 04:13:26
60,047 sec
Krt. natu jaäi puudu minuti alistamisest,47 millisekundit
Opteron 144 SingleCore @ 3066mhz
2x512 ram 2.5,3,3,6 @ DDR439mhz
Asus A8n-SLI Premium
50mhz tõstsin ja sekundi võitsin
Mingi hetk proovin veel(asi on põhimõttes juba)
http://www.hwbot.org/compare.do?resultId=562733
300 |
ivar43
16.12.2006 07:15:00
sai veits seadeidid muudetud, teised m2lud prooviks ja juba tuli -8 kymnendiku alla
uus skoor 31,202 sec
uued seaded .
CPU Found: CPU0
Speed: 2700 MHz
L2 Cache: 512 KB
CPU Found: CPU1
Speed: 2699 MHz
L2 Cache: 0 KB
CPU Speed
CPU Clock 2700.0 MHz (original: 2400 MHz, overclock: 13%)
CPU Multiplier 9.0x
CPU FSB 300.0 MHz (original: 200 MHz, overclock: 50%)
Memory Bus 192.9 MHz
DRAM:FSB Ratio CPU/14
SPD Memory Modules
DIMM1: OCZ OCZ4001024DCGEVX-K 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz)
DIMM2: OCZ OCZ4001024DCGEVX-K 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz)
okas5
16.12.2006 09:14:08
AMD Turion 64 x2, 1gb ram sain nüüd 54.672
1GHz celeron, 256mb pc133 ram = 197.634 seci
Edit:
tõstsin celeroni 1.1ghz, mälud sama = 178,998 seci. 100mhz kiirem ja 20 sec kohe tulemus paranes
Edit: Näppisin celeroni mäludega ka midagi, sai seki alla
Edit:
1140mhz sain cellust 174,832 seci
1170mhz max mis raibe kannatas, tulemuseks siis BSoD
Hardi
16.12.2006 09:35:15
Celeron 2.4 @ ~3.2GHz
512MB DDR PC3200 2.5-3-3-7 200mhz
94.828 sec
_________________ ツ |
| Kommentaarid: 84 loe/lisa |
rewer
16.12.2006 13:19:48
3000+ winchester@1980MHz 87.062
Celeron 466MHz soc370 449.417
win98 all tööle ei saanud.
922 |
Rutz
16.12.2006 14:17:50
| Rutz kirjutas: |
Celeron M 360J (C0) @1873MHz (14x133) 1,28v
Asus P4GPL-X + Asus CT-479
2x256MB Winbond BH5 200Mhz 2-2-2-5-2
92,296 sec |
Celeron M 360J (C0) @2342MHz (14x167) 1,35v
2x256MB Winbond BH5 167Mhz 2-2-2-5-2
73,859 sec
| Kommentaarid: 410 loe/lisa |
354 |
ebuprofen
16.12.2006 14:39:49
AMD X2 3800+@2722MHz (s939 BOX jahutus )
DDR 2x512MB 181MHz 2-2-2-5
Asus A8N SLI Deluxe
33.078
67 |
antikondor
17.12.2006 13:20:15
Sei siis veel paarkümment megahertsu prosest välja pigistatud ning tulemus lõpuks alla 30 sekundi.
http://www.hwbot.org/compare.do?resultId=562862
29.77 sec
000 WHILE hangover
001 drink beer |
45 |
ranel
18.12.2006 10:54:47
sai ka natuke proovitud, aga mitte veel räige klokiga. Aga vaadake, mida ütleb see wPrime ja mida ütleb cpuz prose kiiruse kohta. Muidu on veel see, et kui ma sätin kahe tuuma peale, siis ma võidan ca 0.1sec.
CPU:AMD Athlon XP Thorton 2400+@2631mhz
MOBO:Epox 8RDA+ rev1.1
MEM Dualis:2xCorsair 3200xl (2.2.2.5) 256Mb@175 (2-2-2-2)
165 |
Jaan
18.12.2006 23:55:53
edetabel nüüd esimesel lehel.
viimati muutis Jaan 19.12.2006 01:02:41, muudetud 1 kord |
123 |
ceemic
24/7@kalal
19.12.2006 00:39:43
Opteron144@3277MHz
2*512MB@273MHz@2-2-2-5 1T
51.640sek 8)
322 |
