As the Commander of a Ukrainian Special Reconnaissance Unit, he fought in Ukraine’s surprise offensive in Kharkiv in the autumn of 2022, which pushed back an initial Russian invasion all the way back to the border.
But now Denys and his men are facing the prospect of doing the same all over again.
Russian forces have, in recent days, made small but significant gains right along the border in the Kharkiv region.
Their advances are only a few miles deep but have swallowed up around 100km (62 miles) of Ukrainian territory. In the more heavily defended east of Ukraine, it’s taken Russia months to achieve the same.
Denys wants to know what happened to Ukraine’s defences.
“There was no first line of defence. We saw it. The Russians just walked in. They just walked in, without any mined fields” he says.
He shows me video from a drone feed taken a few days ago of small columns of Russian troops simply walking across the border, unopposed.
He says officials had claimed that defences were being built at huge cost, but in his view, those defences simply weren’t there. “Either it was an act of negligence, or corruption. It wasn’t a failure. It was a betrayal”.
midagi sinna lendamas ühelgi kaadril ei paista ja plahvatus tundub tulevat trepikojast, maja seest.
Netis juhiti veel tähelepanu sellele, et plahvatus toimus täpselt kell 11:21:00 nagu oleks tegemist taimeriga. _________________ /digitaalselt allkirjastatud/
Mõned numbrid.
Lvivi sõjakalmistu on kogu kurbuses ja meeleheites üks ilusamaid.
Siia on maetud 670 sõdurit, kus neid austatakse piltide, lillede ja lipumerega.
Üle 30 000 meie kodaniku teenib eesliinil. Iga päev on meil kaks-kolm sõdurite matust. Linnapea osaleb kõikidel matustel, et näidata austust nende vastu, kes on oma riigi heaks tehes pidanud maksma oma eluga.
Linna elanike arv on ligikaudu sama kui Oslos, umbes 750 000 elanikku.
https://www.vg.no/nyheter/i/93vz65/ukrainsk-sorg-og-sinne-vi-skal-drepe-putin
Nikolai Patrušev: Julgeolekunõukogu sekretär > ?
Sergei Šoigu: Kaitseminister > Julgeolekunõukogu sekretär
Andrei Belousov: Asepeaminister > Kaitseminister
Võimuvangerdust kommenteeris pühapäeva õhtul ka Putini pressiesindaja Dmitri Peskov. Ta ütles ajakirjanikele, et Kreml tahtis kaitseministri ametisse majanduseksperti, kuna Vene kaitsekulud on praeguseks kasvanud 6,6% SKTst ja nõuavad erilist tähelepanu. Peskov andis mõista, et edaspidi võib kaitse-eelarvet oodata vähendamine.
Vaatame kas midagi muutub. Kummaline samm panna majandusinimene Belousov kaitseministriks, aga kui see tagab käpardliku sõjaväe juhtimise, siis minugipoolest
Veel kummalisem on see, et Peskov väidab kaitsekulude vähenemist tulevikus...
Kuulsin kuskilt Youtube analüüsi videost, et Shoigu oli muude kõrgete sõjaväe juhtidega seotud sellise kinnisvara skämmiga, kus sõjavägi palkab mingi lihtsameelse ehitusettevõtte, kes 10% ettemaksega teeb asja 90% valmis ja siis kui järgmine osamakse peaks tulema, siis see jääb tulemata. Väidetetakse, et ehitus ei vasta nõuetele ja lastakse ehitusettevõte üle ning omistatakse ehitautud kinnisvara.
Mingi tüüp läks selle pulli pärast kinni aga otsapidi oli ka Shoigu seotud.
"Some Russian commentators have said the arrest will be a blow to Mr Shoigu. "If he can't manage it, he will be next to fall. This person is 100% his man," one anonymous source told a popular military Telegram channel."
Ja keegi ei näi vastavat küsimusele.... "Kus on Gerassimov?"
Kui lääneriigid tahavad lahendada Ukraina kriisi lahinguväljal, on Moskva selleks valmis, kuulutas Venemaa välisministri kohusetäitja Sergei Lavrov föderatsiooninõukogus, kus toimusid konsultatsioonid tema uuesti ametisse nimetamise üle.
väidetavalt on venelastel õnnestunud sisse murda Helsinki linnavalitsuse süsteemidesse ja saadi kätte kasutajatunnuseid ja e-maili aadresse
hetkel siiski salasõnu kätte ei olevat saadud, seega ligipääs olevat piirdunud avaliku ja poolavaliku teabega
läbi olevat murtud mingi kalapüügialase küsimusega e-maili abil
Häma. Ukraina korduvalt viimase ööpäeva jooksul seletanud, et mingeid kaitsevööndeid või rajatisi ei oleks saanud ehitada, sest me räägime paarist kilomeetrist piirini. Kaitsevööndid, liinid ja muu taoline on ehitatud kaugemale, kuhu tibla ei saaks kohe FABid pähe vajutada ja nende liinide otsa tiblad eile sisse lendasidki, tulemuseks ametlikult loetud 1740 laipa ühe päevaga. Seis on hetkel vägagi positiivne.
Tabel on enamvähem selline nagu arvasin. Probleem on suur hulk Austria ja Saksamaa elanikke kes arvavad, et Ukrainat on aidatud liiga palju.
Üllatav on Lõuna-Ameerika suurem hulk neid kes leiavad, et Ukrainat on abistatud liiga vähe. Ei tea kas see tuleneb sellest et need riigid pole palju aidanud ja seega ei tunne elanikud erilist "kadu" aitamisest või on see lihtsalt võimalus kritiseerida USA ja EU'd.
Kuna ümber töödelda ei saa, siis on ainult kaks valikut. Kas eksportida või vähendada tootmist. Venelased on oodatult valinud esimese variandi, mis pikemas perspektiivis hoopis langetab töötlemata nafta hindasid maailmaturul, kuna sinna jõuab koguselt suurem hulk toodet mis varem oleks läinud siseturule.
most fortifications north of Kharkiv were not properly positioned. While bunkers were built, and some positions even had concrete, the firing positions weren't picked right. Some of the positions were built in open fields, some were built at the lowest elevation points making them useless.
This may be a result of disconnect between civilian contractors and the military units that were suppose to hold these positions.
The government of Estonia is “seriously” discussing the possibility of sending troops into western Ukraine to take over non-direct combat, “rear” roles from Ukrainian forces in order to free them up to fight on the front, Tallinn’s national security advisor to the president told Breaking Defense.
