uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) märgi kõik teemad loetuks
mine lehele 1, 2  järgmine
Zonerman
Zonerman
sõnum 20.03.2024 14:12:27 nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) vasta tsitaadiga
Tegin teema, kus saab arutada ja jagada infot ühes kohas, kui lekib juurde. Iga kuu tuleb rohkem ja rohkem infot.
Hetke teada oleva info põhjal arvatavad spekid Blackwell osas on ajas muutuv kuniks täpsemat infot lekib.
Nvidia’s upcoming GB202 GPU could feature a multi-chip package with 192 SMs and a 512-bit memory bus. (Eeldatav TDP on 500w)
It's also rumored to feature a 512-bit memory bus that is 33% wider than the one on Nvidia’s RTX 4090, the memory bandwidth will feature a 77% boost compared to the 4090, and 28Gbps GDDR7 memory modules which would be 33% faster than the 21Gbps memory modules in the RTX 4090.
GB202 will use the same process node as GB100. TSMC 4N(vidia) is based on TSMC 5, not 4nm.
16-pin 12VHPWR connector could be a standard for the 5090 and other 5000-series cards, meaning even third-party board partners would need to use the it.
People is confused about Nvidia Blackwell top die gaming GPU memory bus and VRAM capacity. I can't say too much right now but gen-to-gen performance uplift is the biggest ever. Don't forget that Blackwell was designed to compete with a monster 3nm MCM RDN4
All signs seem to point to late 2024 or early 2025 at the absolute earliest.
https://www.techradar.com/computing/gpu/nvidia-rtx-5090-gpu-rumors-possible-specs-and-everything-we-know
Lisaks tuleb arvestada, et Nvidia võib planeerida Blackwelliga konkureerida oletatavasti ka rDNA5'ga kui AMD plaan high-end rDNA4 ei too ning alles rDNA5'ga kuid varem.
Malemäng laias laastus, et ette arvata konkurendi plaane.
Sõim ja räuskamine läheb SIIA
viimati muutis Zonerman 21.03.2024 14:57:23, muudetud 2 korda
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 62
kaspar737
sõnum 20.03.2024 14:19:09 vasta tsitaadiga
Huvitav saab näha olema, kui palju 5090 voolu võtab, kui node ikka 4nm peal põhinev.
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 47
Killhoven
OC`er
Killhoven
sõnum 20.03.2024 17:23:53 vasta tsitaadiga
Esimesed kõlakad on juba tõepoolet liikvel. Kõige huvitavam neist ehk see, et järjest rohkem "allikaid" räägivad 5090 võiks tulla selle aasta lõpus juba, võiks kasutada DDR7 ja konfiguratsiooni järgi "vaid" 24GB VRAM, kõva edasiminek RT osas, hind rohkem kui 4090 MRSP. Elame näeme.
Kommentaarid: 393 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 340
heretic666
heretic666
sõnum 20.03.2024 17:38:02 vasta tsitaadiga
Raske uskuda et juba see aasta reliis, konkurenti ei ole.
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
Dolph
sõnum 20.03.2024 21:03:58 Re: nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) vasta tsitaadiga
Zonerman kirjutas:
At least, there is a 30% increase in density
Lovelace oli TSMC 4N. Kui Blackwell on ka TSMC 4N, siis ei ole ju "30% increase in density"
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 14
Kristoferr
Kristoferr
sõnum 20.03.2024 21:24:18 vasta tsitaadiga
Tundub, et korralik monster tuleb sellest 5090'st.
Ostan 400-650W PSU (Platinum-Titanium)
Liitu Binance'ga
Liitu Honey'ga
Kommentaarid: 251 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 203
Zonerman
Zonerman
sõnum 21.03.2024 01:18:55 Re: nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) vasta tsitaadiga
Dolph kirjutas:
Zonerman kirjutas:
Seda pole kuskil kinnitatud veel, mis protsessi Blackwell kasutab. TSMC 4N or P on vaid oletus. Ka ei ole teada kiibi suurust. Eemaldasin selle info.
Kristoferr kirjutas:
Jah ja kallis ka. Kui lekke andmed hakkavad settima rohkem, siis tuleb päris kallis kaart.
ahvilõust
ahvilõust
sõnum 21.03.2024 10:20:54 vasta tsitaadiga
5090-ga ei hakka vaid kabla sulama vaid ka mobo?
Kiirem RT renderduses on küll hää. Aga kes see reaalselt RTd mängudes käima paneb? Ma etem panen korralikku fps-i ja reso peale.
Aga jah nVittia peaks enne kuumuse ja voolu õgimise vähendama. 1000W kast mitte iialgi! thumbs_down.gif
Gdesainer
M: MSI RTX 3070 Gaming Trio
Zonerman
Zonerman
sõnum 21.03.2024 15:26:45 vasta tsitaadiga
Üsna hea kokkuvõte.
Link
One
sõnum 22.03.2024 17:46:14 vasta tsitaadiga
ahvilõust kirjutas:
Toiteplokk sulab ka koos kaablitega ära.
Kommentaarid: 1007 loe/lisa Kasutajad arvavad:  :: 3 :: 1 :: 727
Zonerman
Zonerman
sõnum 24.03.2024 13:32:08 vasta tsitaadiga
Viimased kõlakad Blackwell launch pigem selle aasta teises pooles. https://wccftech.com/nvidia-limit-supply-geforce-rtx-40-ada-gpus-make-room-rtx-50-blackwell-gaming-lineup/
Optimist
Optimist
sõnum 28.03.2024 16:13:33 vasta tsitaadiga
Killhoven kirjutas:
...Kõige huvitavam neist ehk see, et järjest rohkem "allikaid" räägivad 5090 võiks tulla selle aasta lõpus juba, võiks kasutada DDR7 ja konfiguratsiooni järgi "vaid" 24GB VRAM, kõva edasiminek RT osas, hind rohkem kui 4090 MRSP. Elame näeme.
512-bitise mäluga on kas 16 või 32Gb VRAM, 24GB tähendaks 384-bitist mälu ribalaiust. Samas kui AMDilt konkurentsi ei tule, siis võimalik, et see 512-bitine pole äkki enam prioriteet.
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
KrikU
KrikU
sõnum 31.03.2024 22:29:22 vasta tsitaadiga
512-bit mälu konfiguratsioon on senini üsna eksootiline nähtus, aga igatahes midagu mis võiks olla teemaks.
Nvidia GPU puhul on see olnud kasutuses üsna ammu ainult ühe generatsiooni GPU peal - GTX 280 ja 285 aastast 2009
AMD on kasutanud seda lahendust pisut enam, ning esimesena üldse 2900 PRO/XT kaartidel nii 2007 paiku ning Radeon 290/290/295X2 390/390X 2015 aastatel ja lisaks oli erilahendus Fury HBM mäludega kus oli üldse 4096 bit variant.
Zonerman
Zonerman
sõnum 01.04.2024 11:52:42 vasta tsitaadiga
Mina isiklikult olen siiski skeptiline, et gaming GPU tuleb 512bit. Kui 512 tõele vastab, siis vb 5090Ti ehk aga sellise configa kaart oleks väga väga kallis. See võiks tulla millalgi hiljem, kui rDNA5 ilmub. Nvidia sisuliselt konkureerib endaga halo kaartide segmendis.
Optimist
Optimist
sõnum 01.04.2024 15:17:02 vasta tsitaadiga
Zonerman kirjutas:
Mina isiklikult olen siiski skeptiline, et gaming GPU tuleb 512bit. Kui 512 tõele vastab, siis vb 5090Ti ehk aga sellise configa kaart oleks väga väga kallis...
Chipletitega on seda way lihtsam kokku lappida, kui monoliitset. nVidia ja kallid kaardid on ju sünonüüm praegu icon_biggrin.gif
sõnum 08.04.2024 01:37:27 vasta tsitaadiga
- londiste
Kommentaarid: 238 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 213
One
sõnum 06.05.2024 18:28:51 vasta tsitaadiga
https://www.techpowerup.com/322139/nvidia-to-only-launch-the-flagship-geforce-rtx-5090-in-2024-rest-of-the-series-in-2025
Tea mis hinnaga tuleb kui tuleb, pakuks, et eu-s 2.5k+ reaalseks hinnaks. MRSP võib muidugi lambi panna, et paremaid ülevaateid saada..
Zonerman
Zonerman
sõnum 06.05.2024 18:43:56 vasta tsitaadiga
Esimene kuu aega mina pakuks Eestis, kui need siia jõuavad ligi 3k eur. Püsiv hind tõenäoliselt sinna jah 2.5k kanti.
sukelduja
sukelduja
sõnum 07.05.2024 15:19:20 vasta tsitaadiga
Winterwind kirjutas:
Teised pakuvad jälle, et 5080 tuleb enne.
https://videocardz.com/newz/nvidia-geforce-rtx-5080-reportedly-launches-before-rtx-5090
Kui TDP veel suuremaks läheb kui praegustel kaartidel, siis tuleb juba eraldi tuba jahutama hakata. Vähemalt suvel.
Scart
Scart
sõnum 07.05.2024 15:24:57 vasta tsitaadiga
sukelduja kirjutas:
1dumbpcuser
sõnum 07.05.2024 15:34:12 vasta tsitaadiga
Kommentaarid: 96 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 91
sukelduja
sukelduja
sõnum 07.05.2024 15:41:51 vasta tsitaadiga
Scart kirjutas:
sukelduja kirjutas:
4090 on 450w
Scart
Scart
sõnum 07.05.2024 15:43:54 vasta tsitaadiga
sukelduja kirjutas:
Scart kirjutas:
sukelduja kirjutas:
4090 on 450w
4090 ei kasuta mängides mitte kunagi 450w ja piirdub tavaolukorras ~250-300w vahemikus pendeldamisega. Vähemkoormavate mängude puhul, näiteks EVE Online, tiksub üldse 120-140w kandis.
Zonerman
Zonerman
sõnum 07.05.2024 17:25:56 vasta tsitaadiga
Teeme nii, et jätame 4090 teise teema jaoks ja ei hakka siin diskuteerima.
ot:
defaultis võtab 4090 AIB mängudes keskmiselt 350-370w vahele techpowerup erinevate kaartide review andmed. Igasugu kätsisi modimised on fine tuning ja seda saab teha pea iga kaardiga ning tootjast sõltumata
486
sõnum 07.05.2024 17:28:05 vasta tsitaadiga
Scart kirjutas:
sukelduja kirjutas:
Scart kirjutas:
sukelduja kirjutas:
4090 on 450w
Ja muidugi inimesed ostavad selliseid kaarte, et eve online mängida. Kaart peaks oma max j6udlusega jahe olema mitte kaableid sulatama. Ainuke viis kuidas neid depiilsusi kasutada on k6ik mängud 60fps piirata. Isegi doomi mängides lähevad need 4080d kuumaks.
zero
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) mine lehele 1, 2  järgmine
