MediaTek.. kui soov rootida, siis ei maksa hiljem nutta _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
mis selle mediaTeki ja rootimisega on siis? ei saa vms?
Jah, nad ei jaga oma source code:
Fortunately, Qualcomm, unlike MediaTek, makes developers' lives a little bit easier thanks to the CodeAurora Forums (CAF).
CAF is where Qualcomm uploads the kernel source code for their chipsets like the Snapdragon 845 as well as parts of their chipset specific code that makes it easier for developers to build for the platform without knowing how the underlying chipset features work. CAF is a service provided by Qualcomm for the community, one that developers appreciate because it makes AOSP ROM development a tad easier for them. The existence of CAF doesn't solve every problem for developers, though, because OEMs can still add non-standard hardware that isn't supported by the CAF release—in which case developers have to resort to dirty hacks. There's no CAF equivalent for MediaTek chipsets, unfortunately, which leads to a huge discrepancy in the custom ROM community as seen in the MediaTek versus Snapdragon Redmi Note 3 forums.
When asked about the possibility of releasing the source code for their products, TL Lee, general manager of MediaTek's mobile business unit, told AndroidAuthority that the company doesn't have a plan "in the near future" to release the source code for the public. “So far, we don’t have that kind of program. We just release our source code to our customers,” Lee told AndroidAuthority. MediaTek told AndroidAuthority that the company is still working to improve their GMS Express program, which helps speed up the certification process for new devices. While this gives OEMs more time to work on developing the software on their devices, it doesn't help the custom ROM community which some users rely on to provide software support well beyond what the device maker offers. If you plan on using custom ROMs to keep your device relatively up-to-date after the end-of-life of the device, then stick with Qualcomm Snapdragon devices for the foreseeable future.
Mõttetu üritaja kiibiõgija koos kaasa arvatud biosega ehk kiip ise
Võibolla aastate pärast on sellel eelis nagu nvidia vs. amd aga mitte praegu _________________ CH341A EEPROM Flash BIOS teenus.
Üks teema on rootimine, teine teema on custom rom'id. Vaid külgepidi kokku puutuvad teemad. _________________ Seisab keldris vana 386-486-Pentium1? Räägime! Ehk saan vanakesele uue elu anda.
Vaata siia, äkki müün midagi põnevat -> https://www.osta.ee/index.php?fuseaction=listing.seller&q[seller]=jnt
Ei ole.
Mõlemi tegevuse jaoks on source vajalik. _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
>> Root on võimalik ainult siis kui avastatakse mingi software bug, mis seda võimaldab.
Selle bug-i avastamiseks ega ära kasutamiseks pole mingit lähtekoodi vaja. _________________ Experience is what you get when you don't get what you want.
Seda ma ju kirjutasingi _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
Ei ole. Mõlemi tegevuse jaoks on source vajalik.
No pole ju rootimise jaoks alati lähtekoodi vaja
Rootimine - root ligipääsu saamine _________________ Experience is what you get when you don't get what you want.
Aga see, et jääda lootma, et selline bug eksisteerib või avastatakse... võibki tihti lootma jääda.
Mul on mitu väga populaarset MediaTek seadet, kus kasutajate huvi rootimise vastu on suur, kuid mida pole võimalik rootida ega midagi muud modifitseerimisega seotut teha, täiesti lukus. _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
Tegevus 1 - rootimine
Tegevus 2 - custom rom-d'
Sa kirjutasid et "Mõlemi tegevuse jaoks on source vajalik."
Mina ütlen, et rootimise jaoks pole source-t vaja.
source - lähtekood
Seda ma ju kirjutasingi, et MediaTek seadmete puhul on root võimalik ainult siis kui avastatakse mingi software bug, mis seda võimaldab. Aga see on õnn, mitte reegel, millele lootma jääda.
Näiteks see on tuntuim: https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-0069
Aga see on ammu kinni pandud, kasutu uutel seadmetel. _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
Ei ole.
Loll jutt. Ei ole.
Isegi ametlikult on võimalik telefon "lahti teha" ehk rootida teatud tootjate puhul ja seda kinnise mediatek'i soc'ide osas.
Puder ja kapsad, nagu mainisin.
Saad palun konkreetseid naiteid tuua?
Juhul kui telefoni tootja ise seda voimaldab, siis on see hoopis midagi muud. Neil ongi ligipaas ja voimalus seda loppkasutajale lubada. Tootjad, kes rootimist soosivad pole kahjuks eriti palju, OnePlus meenub ainukesena. _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
viimati muutis SKG 08.11.2022 12:46:40, muudetud 1 kord
Noh, xiaomi avas bootloaderi kui ametlike kanalite kaudu küsisin ja andmed kõik ära täitsin.
Et õige regiooni soft peale lasta.
Kas just rootimine on lubatud, selles ma küll kahtlen _________________ This message was sent from space using stargate
Mediatekiga telefonidele ja tahvlitele olen päris mitu korda uue ROMi peale pannud (jutt ainult uue ROMi paigaldamise kohta, mitte millegi muu kohta). Võib-olla on mul lihtsalt õnne olnud nende seadmetega, aga see on umbes nii lihtne nagu kohvi joomine.
Avad flash tooli, avad seal sobiva ROMi, vajutad kirjutamise nupule, ühendad telefoni USB kaudu arvutiga ning uue ROMi paigaldus hakkab automaatselt kohe pihta ja mõne aja pärast on sul uue ROMga seade. USB driver või ka vajalik olla. Mulle tundub, et Snapdragoniga asi lihtsam küll pole.
No jah, aga kõik ei taha/viitsi seda teha, mõni tahab lihtsalt rootida. Seda enam, et uue ROM'i korral pole mingit garantiid, et kogu raud normaalselt tööle hakkab.
Jah, sest selles nn. flash toolis on juba "MTK Easy SU/MTK-SU" voi moni muu analoogne utiliit sees, mis kasutab turvaauku ara
Google Pixel 7 Pro vs Xiaomi 12S Ultra: The two best smartphone cameras of 2022 battle it out https://www.xda-developers.com/google-pixel-7-pro-vs-xiaomi-12s-ultra/ _________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
Tere. Eile sai soetatud endale esimene Xiaomi telefon. Õhtul sai enamus andmetest ümber tõstetud Samsungi telefonist uude Xiaomi telefoni. Täna selgus ,et SMS-id ei toimi. Ki võtad sõnumid lahti tuleb ette tekst "Rakenduse Messages kasutamiseks määrake see oma SMS-ide vaikerakenduseks". Kus kohas menüüs seda teha saab?
