eof
16.04.2004 10:34:37
Igasugused ametlikud küsimused ja vastused neile |
nimelt siis uursin siinseid kommentaare ja otsisin omale ketast....sai otsustatud samsung spinpointi 80g(2mb) kasuks...samuti leidsin HV's, et neil ketastel pidavat olema 3 aastat garantiid...(rõhk sõnal 'pidavat'), niisiis, küsisin ametlikust allikast järgi ja vastus tuli järgnev:
(tsenseerisin igaksjuhuks e-mailid välja)
Hello!
All Samsung HDD have 3 years warranty.
Best Regards,
Richard Keiran
IT Product Marketing Manager
Samsung Electronics Co.,LTD
Baltic office
J. Alunana 2, Riga, Latvia
Phone: +371 750 8491
GSM: +371 923 2201
FAX: +371 750 8480
e-mail: xxx@yyy.com
-----Original Message-----
Sent: ceturtdiena, 2004. gada 15. aprīlī 19:23
To: xxx@yyy.com
Subject: [SN1bfd3800]about warranty
--------------------------------------- Notice
This is a customer's email received through Samsung Electronics website
E-mail system,
which needs your reply.
Please click "Customer
<http://mail.samsungelectronics.com/secmail/servlet/EmailDispatcher?mode
=N&no=1834296&sub_no=0&email=xxx@yyy.com> Center" and write
down your answer in "Answer box"
to reply to the customer.
In order to complete replying, you should check one of "Question Type
Level 2" of
the customer's mail from the list box.
Thank you very much for your cooperation.
Hello!
I was considering between maxtor's 80g hdd and spinpoint 80g (2mb
model)...the only thing i'd like to confirm, is if spinpoints hold a 3y
warranty time?
Thank You
*Don't Delete Serial Number(SN) in Title
[[ Question Information ]]
Product : Hard Disk Drive
Model Name : SP0802N
Question Type : Product Information
Country : Estonia
<ostab omale spinpoint'i!>
_________________ Shot with an overpriced lens. |
| Kommentaarid: 49 loe/lisa |
47 |
Eser
16.04.2004 10:41:28
Tähendab sa pead ikkagi uurima kauplusest või müügikohast
kuidas nemad seda võimaldavad. Oleneb aga ikkagi edasimüüjast,
et kuidas ja mis tingimustel on lepingud tehtud jne.
_________________ Must, ja karvane ! |
| Kommentaarid: 23 loe/lisa |
22 |
Max Powers
16.04.2004 11:12:28
| Eser kirjutas: |
et kuidas ja mis tingimustel on lepingud tehtud jne. |
Just.
Siin tuleb meelde, et kui ma endale käekella ostsin siis tootja kirjade järgi on selle garantii
10 aastat, aga edasimüüja Eesti annab aint 3 aastat
182 |
Henrik
16.04.2004 11:17:10
| Ükskõik misuugusel maaletoojal või edasimüüjal on õigus anda garantii pikkus oma äranägemise järgi (muidugi ei tohi ta olla vastuolus seadustega). Niisiis kui Eestis firma annab garantiiks 1 aasta või 2 aastat siis on see tema õigus. Edasi võid vabalt samsungiga ise edasi tegeleda.
eof
16.04.2004 16:43:28
vähemalt ma tean, et mul on see võimalus kui ketas ära kärssama peaks ...krt, praeguse 40g maxtori vilinast ja kõrinast nii villand
a teema mõte oli tegelt selles, et võiks olla mingi thread kusagil, kuhu pandaks ametlikult kinnitatud vastuseid küsimustele vaimus, et kas x jubin tunneb featuuri y...vähendaks mujal spekulatsioone
47 |
RCC
27.04.2004 02:07:56
ma sellise "vürtspoodniku" käest ei ostakski kes garantiid oma äranägemise järgi väänab kuidas tahab
toode on toode ja kui näiteks scäsi vindil on 5a siis mind ei huvita mingi 1 või 2 aastat
9 :: |
147 |
