praegune kellaaeg 25.09.2026 04:44:35
easyman
17.04.2004 23:09:07
palun abi lahendamaks viiruse w32.Jeefo mõrvamisel |
sain kazaast jama arvutisse ja Norton ei suuda seda lahendada iseseisvalt.Viiruse nimi on w32.Jeefo .
Äkki keegi teab kuidas sellest lahti saab?SOS
_________________ "tulen,et jääda,olen,et olla ja lähen,et minna" |
| Kommentaarid: 9 loe/lisa |
TzigaLind
17.04.2004 23:26:57
Keela system restore, uuenda anti viiruse definitsioone, buudi safe modesse ja käivita antiviirus.
_________________ Piix! |
| Kommentaarid: 16 loe/lisa |
14 |
Troll
18.04.2004 00:54:30
Manual removal
Please follow the instructions below if you would like to remove W32.Jeefo manually. Please notice that you must follow the instructions very carefully and delete everything that is mentioned. In most cases the removal will fail if one single item is not deleted. If W32.Jeefo remains on your system after stepping through the removal instructions, please double-check by stepping through them again.
Start your computer in safe mode.
Start the registry editor. This is done by clicking Start then Run. (The Run dialog will appear.) Type regedit and click OK. (The registry editor will open.)
Browse to the key:
'HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ RunServices'
In the right pane, delete the value called 'PowerManager"="%windir%\svchost.exe", if it exists.
Exit the registry editor.
Start Windows Explorer and delete:
%WinDir%\svchost.exe
Note: %WinDir% is a variable . By default, this is C:\Windows (Windows 95/98/Me/XP) or C:\WINNT (Windows NT/2000).
P.s Norton saab sellest jagu küll, aga pead teda updatema.
_________________ TÜMPA, TÜMPA...EEST ÄRA, TROLL TULEB!!!
viimati muutis Troll 18.04.2004 22:38:02, muudetud 1 kord |
121 |
easyman
18.04.2004 13:41:02
Tänan kõiki kes võtsid vaevaks mind mu mures aidata - abi igati profesionaalne.Tänaseks viirus nagu vupsti läinud ja arvuti koos kasutajaga õnnelik.
