martin_kivi
19.03.2004 13:18:31
Web Server Error Messages |
Kusagil oli juba sarnane teema, kuid ei leia seda üles
Et siis vaja sellist lehekülge, kus seletataks erinevate errorite (404 page not found, 502 proxy error jne) hingeelu.
Edit: muutsin pealkirja vastavalt soovitusele.
viimati muutis martin_kivi 20.03.2004 21:08:51, muudetud 1 kord |
| Kommentaarid: 52 loe/lisa |
37 |
lunatic
| Kommentaarid: 20 loe/lisa |
19 |
Siegfried
20.03.2004 02:47:26
100 Continue
101 Switching Protocols
200 OK Action complete successfully
201 Created Success following a POST command
202 Accepted The request has been accepted for processing, but the processing has not been completed.
203 Partial Information Response to a GET command, indicates that the returned meta information is from a private overlaid web.
204 No Content Server has received the request but there is no information to send back.
205 Reset Content
206 Partial Content The requested file was partially sent. Usually caused by stopping or refreshing a web page.
300 Multiple Choices
301 Moved Permanently Requested a directory instead of a file. The web server substituted the index.html file.
302 Moved Temporarily
303 See Other
304 Not Modified The cached version of the requested file is the same as the file to be sent.
305 Use Proxy
400 Bad Request The request had bad syntax or was impossible to be satisfied.
401 Unauthorized User fail to provide a valid user name / password required for access to file / directory.
402 Payment Required
403 Forbidden Access to a protected folder was attempted (i.e.) domain.com/cgi-bin
404 Not Found The requested file was not found. (Seda teadet hakkad ka tihti nägema)
405 Method Not Allowed
406 Not Acceptable
407 Proxy Authentication Required
408 Request Time-Out
409 Conflict
410 Gone
411 Length Required
412 Precondition Failed
413 Request Entity Too Large
414 Request-URL Too Large
415 Unsupported Media Type
500 Server Error The server encountered an unexpected condition which prevented it from fulfilling the request
501 Not Implemented The server does not support the facility required.
502 Bad Gateway
503 Out of Resources The server cannot process the request due to a system overload. This (should) be a temporary condition.
504 Gateway Time-Out The service did not respond within the time frame that the gateway was willing to wait.
ehk on abi
martin_kivi
20.03.2004 21:09:24
| lunatic, Siegfried, tänud teile.
37 |
Spott
11.04.2004 10:03:30
Kuna teemas suht kasulik inf, siis paigaldasin ta Kasulikesse Näpunäidetesse.
_________________ Kingitused internetist - NetiKink - tellige endale näiteks HV avatariga ja kasutajanimega tass, t-särk või mõni muu huvitav kingitus sünnipäevaks või muuks tähtpäevaks. |
| Kommentaarid: 162 loe/lisa |
6 :: |
134 |
