praegune kellaaeg 19.11.2026 21:06:01
b0uncyfr0
19.11.2026 20:56:55
M: TCL 34R83Q :: Asukoht: Tallinn |
Tere tere tere,
I have a TCL 34R83Q i want to upgrade from, i need more hz as i got into shooters recently. It's bought from Elisa roughly a year ago so should be under warranty. In great condition as well, no marks, scratches, issues whatsoever.
Spec page: https://www.tcl.com/eu/en/monitors/34r83q
- Its basically a HDR gaming monster. If you're into HDR without the risks of OLED burn in - this is the best atm. Its a VA panel so it smears abit when youre gaming under 60 fps and its dark content. You can completely mitigate with a lower response time but that blurs the image abit so thats the tradeoff. Gaming anywhere above 70+ is perfectly fine imo, you wont notice it.
- SDR is also solid, about 550ish nits. Bright enough to use in direct sunlight (_insert your sunlight + estonia joke here_)
- The contrast is top tier too (about 75000:1) last i checked. Second best, only beaten by OLEDS. its very good when the dimming zones are fully utilised with the full brightness. Its punchy.
AH:350
OK:425
Pickup only, im in the nautica area. I have a DP 1.4 cable but no box (unfortunately).
