praegune kellaaeg 20.11.2026 01:27:22
LessThanSlow
15.11.2026 11:19:32
M: TB3 / USB4 dokk (dual 4K 60Hz, daisychain support, 85W PD) :: Asukoht: Võrumaa |
Müüa heas korras multifunktsionalne dokk.
Tehnilised andmed:
• Thunderbolt 3 – kuni 40 Gbit/s
• Kahe 4K 60 Hz monitori tugi (DP + Thunderbolt 3)
• Sülearvuti laadimine kuni 85 W (Power Delivery)
• 2 × USB-A 3.0 ja 1 × USB-C 3.0
• Gigabit Ethernet (RJ45)
• 3,5 mm heliühendused
• Ühildub Windowsi, macOS-i ja Linuxiga
Tootja info: https://www.startech.com/en-eu/docking-stations-multiports/tb3dk2dppdue
AH: 60€
OK: 100€
Komplektis: dokk, toiteadapter, TB kaabel (vajadusel kaasa DP kaabel)
Dev Grex
17.11.2026 09:21:19
Peaks toetama päris palju erinevaid resolutsiooni ja hz kooslusi:
• 1080p (1920 × 1080). Supports up to 240Hz on both single and dual-monitor setups within DisplayPort 1.2 bandwidth limits.
• 1440p (2560 × 1440). Supports up to 144Hz (and up to 165Hz at 8-bit color) on single or dual monitors.
• Ultrawide 1440p (3440 × 1440). Supports up to 100Hz on a single or dual display setup.
• 4K UHD (3840 × 2160) & DCI 4K (4096 × 2160). Capped at 60Hz for both single and dual-monitor configurations.
• 5K (5120 × 2880). Capped at 60Hz on a single monitor. This requires combining both the DisplayPort and downstream Thunderbolt 3 ports into one display.
| Kommentaarid: 363 loe/lisa |
304 |
