praegune kellaaeg 21.11.2026 04:54:15
madisxxx
14.11.2026 12:36:51
M: 500GB, 1TB, 2TB kõvakettad; ÄÄ 4TB WD red veaga :: Asukoht: Tartu |
Kettad kontrollitud badblocks kirjutustestiga - veavabad, kui ketta juures pole teisiti märgitud.
Extended smart testid tehtud pärast badblocksi testi.
Iga ketta SMART raport spoileris.
Eelistan postiga mitte saata.
1. Western Digital Blue 500GB
Device Model: WDC WD5000AAKX-22ERMA0
Serial Number: WD-WCC2EXS15858
Töötunde: 3783
Hind: 15€
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Blue
LU WWN Device Id: 5 0014ee 2b48aa3a5
Firmware Version: 17.01H17
User Capacity: 500 107 862 016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Device is: In smartctl database 7.3/5528
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Nov 9 12:57:19 2026 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 8700) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 88) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3037) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 141 138 021 Pre-fail Always - 3933
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 631
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 3783
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 578
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 39
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 839
194 Temperature_Celsius 0x0022 108 100 000 Old_age Always - 35
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 30
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 3780 -
# 2 Extended offline Completed without error 00% 3764 -
# 3 Extended offline Completed without error 00% 3402 -
# 4 Short offline Completed without error 00% 3400 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
2. Western Digital Blue 500GB
Device Model: WDC WD5000AAKX-001CA0
Serial Number: WD-WCAYUA232654
Töötunde: 40017
Hind: 12€
LU WWN Device Id: 5 0014ee 158e84166
Firmware Version: 15.01H15
Local Time is: Mon Nov 2 10:58:15 2026 EET
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: ( 8160) seconds.
command.
power-saving mode.
recommended polling time: ( 83) minutes.
3 Spin_Up_Time 0x0027 140 136 021 Pre-fail Always - 3966
4 Start_Stop_Count 0x0032 088 088 000 Old_age Always - 12862
9 Power_On_Hours 0x0032 046 046 000 Old_age Always - 40017
12 Power_Cycle_Count 0x0032 088 088 000 Old_age Always - 12174
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 234
193 Load_Cycle_Count 0x0032 196 196 000 Old_age Always - 12627
194 Temperature_Celsius 0x0022 102 068 000 Old_age Always - 41
No Errors Logged
# 1 Extended offline Completed without error 00% 40004 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
3. Western Digital Blue 1TB
Device Model: WDC WD10EZEX-60ZF5A0
Serial Number: WD-WMC1S6446152
Töötunde: 4691
Hind: 25€
LU WWN Device Id: 5 0014ee 0ae4f0a9a
Firmware Version: 80.00A80
User Capacity: 1 000 204 886 016 bytes [1,00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Form Factor: 3.5 inches
ATA Version is: ACS-2 (minor revision not indicated)
Local Time is: Thu Nov 5 13:01:42 2026 EET
been run.
data collection: (10920) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
No Conveyance Self-test supported.
power-saving mode.
recommended polling time: ( 126) minutes.
SCT capabilities: (0x30bd) SCT Status supported.
SCT Error Recovery Control supported.
3 Spin_Up_Time 0x0027 184 173 021 Pre-fail Always - 1766
4 Start_Stop_Count 0x0032 097 097 000 Old_age Always - 3906
7 Seek_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
9 Power_On_Hours 0x0032 094 094 000 Old_age Always - 4691
10 Spin_Retry_Count 0x0033 100 100 051 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1785
184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 1
190 Airflow_Temperature_Cel 0x0022 064 056 040 Old_age Always - 36 (Min/Max 19/40)
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 130
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 3775
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
No Errors Logged
# 1 Extended offline Completed without error 00% 4691 -
# 2 Extended offline Completed without error 00% 4671 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
4. Western Digital Red 2TB
Badblocksis oli 8 errorit. SMART testi teeb ära
Raw_Read_Error_Rate ja Reallocated_Sector_Ct ei ole 0-d enam!
Device Model: WDC WD20EFRX-68EUZN0
Serial Number: WD-WCC4M0DK5DTE
Töötunde: 45530
Hind: 5€
Model Family: Western Digital Red
LU WWN Device Id: 5 0014ee 20c8877c0
Firmware Version: 82.00A82
User Capacity: 2 000 398 934 016 bytes [2,00 TB]
Rotation Rate: 5400 rpm
Local Time is: Thu Nov 5 21:06:09 2026 EET
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
been run.
data collection: (25980) seconds.
command.
power-saving mode.
recommended polling time: ( 263) minutes.
SCT capabilities: (0x703d) SCT Status supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 512
3 Spin_Up_Time 0x0027 174 173 021 Pre-fail Always - 4283
4 Start_Stop_Count 0x0032 081 081 000 Old_age Always - 19875
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 2
9 Power_On_Hours 0x0032 038 038 000 Old_age Always - 45530
12 Power_Cycle_Count 0x0032 082 082 000 Old_age Always - 18612
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 17
193 Load_Cycle_Count 0x0032 193 193 000 Old_age Always - 21442
194 Temperature_Celsius 0x0022 115 105 000 Old_age Always - 32
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 5
No Errors Logged
# 1 Extended offline Completed without error 00% 45486 -
# 2 Extended offline Completed without error 00% 45147 -
# 3 Short offline Completed without error 00% 45129 -
# 4 Short offline Completed without error 00% 44410 -
# 5 Short offline Completed without error 00% 43664 -
# 6 Short offline Completed without error 00% 42945 -
# 7 Short offline Completed without error 00% 42203 -
# 8 Short offline Completed without error 00% 41567 -
# 9 Short offline Completed without error 00% 41460 -
#10 Short offline Completed without error 00% 40743 -
#11 Short offline Completed without error 00% 40001 -
#12 Short offline Completed without error 00% 39282 -
#13 Short offline Completed without error 00% 38538 -
#14 Short offline Completed without error 00% 37124 -
#15 Short offline Completed without error 00% 36381 -
#16 Short offline Completed without error 00% 35664 -
#17 Short offline Completed without error 00% 34919 -
#18 Short offline Completed without error 00% 34199 -
#19 Short offline Completed without error 00% 33455 -
#20 Short offline Completed without error 00% 32716 -
#21 Short offline Completed without error 00% 32018 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
5. ÄÄ: Western Digital Red 4TB
NB! Selle ketta badblocks annab errorit (sadu erroreid).
Extended smart testi lõpuni ei tee, läheb errorisse.
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E6NFNXL1
LU WWN Device Id: 5 0014ee 2b8544b74
User Capacity: 4 000 787 030 016 bytes [4,00 TB]
Local Time is: Thu Nov 5 15:35:06 2026 EET
was never started.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: (52320) seconds.
command.
power-saving mode.
recommended polling time: ( 523) minutes.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 231
3 Spin_Up_Time 0x0027 177 170 021 Pre-fail Always - 8125
4 Start_Stop_Count 0x0032 092 092 000 Old_age Always - 8649
9 Power_On_Hours 0x0032 046 046 000 Old_age Always - 39659
12 Power_Cycle_Count 0x0032 093 093 000 Old_age Always - 7927
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 15
193 Load_Cycle_Count 0x0032 195 195 000 Old_age Always - 15247
194 Temperature_Celsius 0x0022 116 107 000 Old_age Always - 36
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
No Errors Logged
# 1 Extended offline Completed: read failure 90% 39657 29391384
# 2 Short offline Completed without error 00% 39650 -
# 3 Short offline Completed without error 00% 39649 -
# 4 Short offline Aborted by host 10% 39622 -
# 5 Short offline Aborted by host 10% 39621 -
# 6 Extended offline Completed: read failure 90% 39602 9453290
# 7 Short offline Completed: read failure 40% 39602 9453290
# 8 Short offline Completed without error 00% 39600 -
# 9 Short offline Completed without error 00% 38414 -
#10 Short offline Completed without error 00% 37673 -
#11 Short offline Completed without error 00% 36953 -
#12 Short offline Completed without error 00% 36209 -
#13 Short offline Completed without error 00% 35490 -
#14 Short offline Completed without error 00% 34747 -
#15 Short offline Completed without error 00% 34004 -
#16 Short offline Completed without error 00% 33288 -
#17 Short offline Completed without error 00% 32545 -
#18 Short offline Completed without error 00% 31826 -
#19 Short offline Completed without error 00% 31083 -
#20 Short offline Completed without error 00% 29669 -
#21 Short offline Completed without error 00% 28926 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
102 |
amd phenom
15.11.2026 01:35:12
| nr 4-5 6e
| Kommentaarid: 565 loe/lisa |
7 :: |
439 |
madisxxx
102 |
