praegune kellaaeg 03.10.2026 17:47:19
8jalg
03.10.2026 15:04:42
» M: Dell Pro Micro QCM1250 Ultra 5 235T, 16 RAM, pikk garantii, uus ja avamata pakendis :: Asukoht: Tallinn |
Intel(R) Core(TM) Ultra 5 235T (R) (13 TOPS NPU, 14 cores, u p to 5.0GHz)
16 GB, DDR5, up to 5600 MT/s, non-ECC
512GB
Wireless Driver, Intel(R) Wi-F i 6E AX211, 2x2, 802.11ax, Bluetooth(R) wireless card
Intel(R) Wi-Fi 6E AX211, 2x2, 802.11ax, Bluetooth(R) wireless card
Windows 11
Internal Speaker
Internal WiFi Antenna
90 Watt A/C Adapter
Tehasegarantii kuni juuli 2029
Kaal 1.1 Kg
Ports:
Front side
Power Button
Global Headset Jack
USB 3.2 Gen 1 (5 Gbps) Type-A Port
USB 3.2 Gen 2 (10 Gbps) Type-C Port
Rear side
Optional Wireless Antenna
RJ-45 Ethernet Port (1 Gbps)
Optional Module (choose 1):
- HDMI 2.1, up to 5120 x 3200 @60Hz with Intel® Core™ Ultra Processors (Series 2); up to 4096 x 2160 @ 60 Hz with Intel® Core™ Processors (14th Gen)
- DisplayPort 2.1, up to 7680 x 4320 @60Hz with Intel® Core™ Ultra Processors (Series 2); 1.4a, up to 5120 x 3200 @ 60 Hz with Intel® Core™ Processors (14th Gen)
- VGA, up to 1920 x 1200 @ 60 Hz
- USB Type-C with DisplayPort Alt mode, up to 5120 x 3200 @ 60 Hz & power delivery in up to 100W
- PS/2 Serial Port
- Serial Port
- 2 x USB 3.2 Gen 2 (10 Gbps) Type-A Ports
- 5GbE Optical Fiber (Peer-to-Peer)*
2x USB 2.0 Type-A Ports (480 Mbps)
USB 3.2 Gen1 (5 Gbps) Type-A Port
USB 3.2 Gen1 (5 Gbps) Type-A Port with SmartPower On
Kensington Security Cable Slot and Padlock Ring
HDMI 2.1, up to 4096 x 2160 @60Hz
DisplayPort 1.4a, up to 5120 x 3200 @60Hz with Intel® Core™ Ultra Processors (Series 2), up to 4096 x 2304 @60Hz with Intel® Core™ Processors (14th Gen)
Power-cord Connector Port
Width: 36.00 mm
Depth: 178.00 mm
Height: 182.00 mm
Starting weight: 1.16 kg
Hind 500
| Kommentaarid: 37 loe/lisa |
36 |
