praegune kellaaeg 16.09.2026 21:03:28
lynxfelinae
13.09.2026 17:43:43
M: Raspberry Pi 500+ :: Asukoht: Tallinn |
Müüa väga heas korras ja vähe kasutatud Raspberry Pi 500+. https://www.raspberrypi.com/products/raspberry-pi-500-plus/
2.4GHz quad-core 64-bit Arm Cortex-A76 CPU, with cryptography extensions, 512KB per-core L2 caches and a 2MB shared L3 cache
16GB LPDDR4X-4267 SDRAM
Internal 256GB Raspberry Pi SSD M.2
Support for M.2 NVMe SSDs up to 2280 form factor
84-, 85- or 88-key mechanical keyboard (depending on regional variant)
Gateron KS-33 Blue low-profile switches
Dual-band (2.4GHz and 5.0GHz) IEEE 802.11b/g/n/ac Wi-Fi®
Bluetooth 5.0, BLE
Gigabit Ethernet
2 × USB 3.0 port and 1 × USB 2.0 port
Horizontal 40-pin GPIO header
2 × micro HDMI® port (supports up to 4Kp60)
H.265 (4Kp60 decode)
OpenGL ES 3.1 graphics, Vulkan 1.3
SD card support: microSD card slot for operating system and data storage
Power: 5V DC via USB-C connector
Minu müüdav Raspberry Pi 500+ on US klahvipaigutusega. Alles on originaalpakend.
Sisse on paigutatud Raspberry Pi RTC patarei. https://www.raspberrypi.com/products/rtc-battery/
Kaasas on:
1. Raspberry Pi valget värvi 27W USB-C vooluadapter. https://www.raspberrypi.com/products/27w-power-supply/
2. Rasberry Pi valget värvi Micro HDMIst HDMIsse kaabel. https://www.raspberrypi.com/products/micro-hdmi-to-standard-hdmi-a-cable/
Pildid: https://1drv.ms/f/c/7fcbf992ac77d069/IgCnGbZYWLfATZ02rRC5xl74AYKdS_GvyxGkNVXUuyCrYDw?e=l3Ym0c
Raspberry Pi 500+, vooluadapter ja HDMI kaabel on ostetud The Pi Hutist 09.11.2025. (https://thepihut.com/).
Raspberry Pi RTC patarei on ostedu electro:kitist (https://www.electrokit.com/).
Vajadusel saan ostjale saata arvete pdf failid.
Raspberry Pi 500+ asub Tallinnas Lasnamäel. Võimalik on käest-kätte tehing või ostja kulul pakiautomaati saatmine.
OK hind: 315 €
Teie pakkumised on oodatud.
| Kommentaarid: 257 loe/lisa |
216 |
archieb0ld
15.09.2026 15:31:41
| mingi AH on ka?
| Kommentaarid: 34 loe/lisa |
34 |
lynxfelinae
16.09.2026 09:32:58
| AH on 250 €.
216 |
archieb0ld
16.09.2026 19:10:38
| oeh, ebay.de müüb neid 200-ga
34 |
lynxfelinae
16.09.2026 19:35:29
| archieb0ld kirjutas: |
| oeh, ebay.de müüb neid 200-ga |
Jaga linki plaun.
Minu kiire otsing näitas, et ebay.de on Raspberry Pi 500 müügis natuke alla ja natuke üle 200 €.
Mina müün Raspberry Pi 500+ mudelit, mida ebay.de müüakse umbes 300 € ja rohkem.
216 |
