praegune kellaaeg 07.09.2026 06:40:39
Glico
Uus kasutaja
07.09.2026 05:51:31
MLB The Show 26 Infield Tips with U4GM Stott Guide |
Roster spots are expensive in MLB The Show 26, especially when a lineup needs both dependable defense and enough offense to survive long online games. The 99 OVR Spotlight Bryson Stott addresses that problem through flexibility rather than one overwhelming attribute, and players managing MLB 26 stubs should consider what his card adds to the entire infield before spending on another specialist.
Stott's Value Comes From Roster Construction
Stott can cover second base, shortstop, and third base while bringing 120 Contact against right-handed pitching, 109 against lefties, 100 Vision, and 120 Discipline. Those numbers create a reliable at-bat in situations where weaker contact hitters often become easy outs.
He is most useful for a roster that already has one premium infielder but lacks a dependable backup plan. Instead of carrying a separate replacement for every position, you can use Stott to protect against fatigue, substitutions, and awkward matchup decisions. His 81 Speed also gives him value when a late-game pinch runner is needed.
1) Save resources for flexible players who cover multiple lineup problems.
2) Test Stott at second base before committing him to third.
3) Keep faster bench options available for late-game substitutions.
Why Second Base Is Usually the Best Fit
Stott owns 99 Fielding and 87 Reaction, so routine plays rarely define his defensive performance. The concern is his 66 Arm Strength. That limitation matters less at second base, where throws are generally shorter and the position allows his reactions to carry more of the workload.
Third base exposes the arm issue more often, particularly on slow rollers and deep corner plays. Shortstop is workable when your surrounding infield has strong arm strength, but it requires more careful evaluation. If your shortstop already handles difficult throws comfortably, placing Stott at second gives the lineup his bat without creating unnecessary defensive stress.
Build the Lineup Around Contact Pressure
Stott's 70 Power against righties and 80 against lefties makes him better suited to extending innings than ending them with one swing. Hit early when the count favors you, use the whole field, and let the middle of the order handle the heavier power responsibility.
His 99 Stealing and 99 Baserunning Aggression create pressure after he reaches base, but constant steal attempts are a poor use of that advantage. A controlled lead can influence pitch timing, force quicker decisions, and improve the next hitter's at-bat without risking an unnecessary out.
Use Stott near the top when you need contact and disciplined at-bats.
Place him lower when stronger hitters need runners in scoring position.
Choose aggressive baserunning only when the count and game state support it.
Quirks, Matchups, and Resource Planning
First-Pitch Hitter, Breaking Ball Hitter, Bad Ball Hitter, and Situational Hitter give Stott useful answers against varied pitching plans. He can attack an opponent who starts with strikes, punish predictable breaking-ball usage, and remain relevant when runners are already in scoring position.
Do not treat the card as an automatic upgrade at every infield position. Compare him with your current starters, account for arm strength across the defense, and consider whether your lineup truly needs another contact bat. For players building toward the endgame, Stott becomes especially valuable when one roster slot must cover defense, speed, and matchup flexibility.
The smartest approach is to farm efficiently, avoid replacing a proven starter without testing the defensive animations, and reserve resources for cards that improve several areas at once. Stott is a practical solution for players who value stable innings, flexible substitutions, and efficient roster management, making MLB The Show 26 Stubs for sale easier to evaluate when planning the rest of the lineup.
