praegune kellaaeg 07.09.2026 06:40:39
Glico
Uus kasutaja
07.09.2026 05:09:54
U4GM Monopoly go Guide: Why Railroad Points Matter |
Railroad spaces look tempting whenever Tycoon Class is active, but experienced Monopoly Go players know that the landing itself is only half the equation. The real question is whether the expected tournament points justify the Dice spent reaching it. This guide is especially useful for players building a reliable event routine, saving for a sticker album push, or checking Monopoly Go Stickers while deciding whether a short scoring session is worth the resources. Tycoon Class rewards patience because a carefully timed Railroad attempt can outperform several careless rolls made at a high multiplier.
Railroad Results Are Not Equal
A Railroad landing can trigger a Shutdown or a Bank Heist, and the result changes the value of the entire play. A blocked Shutdown awards 2 base points, while a successful Shutdown gives 4. Heists are more important for burst scoring: a small Heist gives 4 points, a large Heist gives 6, a bankrupt result gives 8, and a Mega Heist gives 12. Your Dice multiplier then scales the tournament reward. That spread explains why two players can spend a similar number of rolls and finish with completely different progress. A weak outcome at ×50 may be less useful than a strong outcome at ×20 if the first player had to chase the target across an unfavorable board.
Build Your Multiplier Around the Board
The safest approach is to treat the multiplier as a positioning tool rather than a permanent loadout. When Railroad is six to seven spaces away and the nearby tiles offer useful pickups, increase the multiplier for the approach. If the roll misses and the next Railroad window moves out of reach, drop back immediately. Continuing at ×100 after the board has turned cold is where most Dice disappear. I prefer a simple rhythm: approach with a moderate setting, raise the multiplier when the landing becomes realistic, collect the outcome, then return to a conservative setting. This keeps the grind controlled and leaves room for the next event.
Milestones Give You a Better Target
Leaderboard placement can be exciting, but milestone rewards are easier to measure and protect against sudden competition. The current structure includes 40 milestone levels and requires 36,000 points to complete the route. Rewards can include Dice, Flags, sticker packs, and short-term boosts. For comparison, the Farm Express tournament offered 5,735 total Dice and 2,160 Flags across its milestone track. That kind of predictable progression is valuable for players who are saving for a partner event or trying to improve endgame album progress. Check the next two rewards before spending heavily; a large point requirement paired with a minor reward is usually a signal to preserve resources.
Use Mega Heist as a Short Burst
Mega Heist changes the value of a good Railroad position, but it does not make every roll worthwhile. Save your higher multiplier for a board state where Railroad is close and your Dice balance can absorb one or two misses. Once the favorable window ends, stop rather than forcing another cycle. Tycoon Class works best as a conversion chain: Dice become a Railroad landing, the landing becomes a Heist or Shutdown, and that result becomes milestone progress. When the conversion weakens, your next best move is usually to save for Bumble Bounty or another event. A disciplined player can also track the next reward while comparing Mgo Stickers needs, ensuring that every Tycoon Class session supports a larger progression plan.
