praegune kellaaeg 07.09.2026 06:40:38
Glico
Uus kasutaja
07.09.2026 04:37:27
U4GM Guide to Diablo 4 Spiritborn Ultimates |
Wushe Nak Pa asks more of a Diablo 4 Spiritborn build than a typical weapon slot. Players looking through Diablo IV Items should treat this Ancestral Unique Glaive as a rotation piece, not a simple stat upgrade. Its real question is whether your Primary Spirit Hall bonus becomes powerful enough during Ultimate windows to outweigh a slower weapon profile.
What Wushe Nak Pa Actually Brings to a Build
The glaive carries 2,173 Damage per Second, 1,739-2,607 Damage per Hit, and 1.00 Attacks per Second, alongside a 10% All Damage Multiplier. Those base numbers matter, but they are not why a player builds around it.
After casting an Ultimate Skill, Wushe Nak Pa grants the matching Primary Spirit Hall bonus at 300% increased potency for 15 seconds. That turns the Spirit Hall selection into a major gearing decision. A strong Primary Spirit bonus is no longer background value; for those 15 seconds, it becomes a central part of your output.
◆ The weapon rewards a Primary Spirit Hall bonus that directly improves your active damage sequence.
◆ The 15-second effect favors builds that can spend that window attacking rather than repositioning.
◆ An Ultimate cast is both a skill activation and the start of your main amplified period.
This is why Wushe Nak Pa can feel excellent in one Spiritborn setup and merely acceptable in another. The glaive does not supply a universal answer. It magnifies the value already present in your chosen Spirit Hall.
Plan Your Ultimate Around Real Damage Time
A common mistake is pressing an Ultimate the moment a boss encounter begins. That can be fine when the target is ready and vulnerable, but it can also burn valuable seconds while you are moving into range, waiting for the target to settle, or dealing with incoming pressure.
With Wushe Nak Pa equipped, the best Ultimate timing is usually the moment when you can commit to sustained damage. Think of the Ultimate as the switch that starts your 15-second work phase. If your build has a reliable cooldown cycle, each cast creates a repeatable offensive rhythm rather than a random burst opportunity.
For difficult encounters, pay attention to how much meaningful damage you deal before the effect ends. If large parts of the window disappear into movement or defensive play, the weapon may not be delivering its full value for your playstyle.
Ultimate Tags Can Open Useful Synergies
Wushe Nak Pa also changes the classification of each Spiritborn Ultimate. This detail is easy to miss, yet it can influence how the Ultimate connects with effects tied to other skill categories.
◆ The Explorer is treated as a Focus Skill.
◆ The Hunter is treated as a Mobility Skill.
◆ The Devourer is treated as a Potency Skill.
◆ The Protector is treated as a Defensive Skill.
These classifications give players another reason to inspect their build carefully instead of viewing the Ultimate as isolated from the rest of the skill bar. If an effect cares about one of these categories, the altered tag may create a relevant interaction. The practical lesson is simple: check category-based bonuses before deciding which Ultimate best supports the glaive.
Do Not Judge It Only by Attack Speed
At 1.00 Attacks per Second, Wushe Nak Pa is slower than many Spiritborn weapon options. That is a legitimate tradeoff, particularly for players whose damage depends heavily on rapid attacks. Still, attack frequency alone is the wrong measure for this item.
The better comparison is damage earned across repeated 15-second amplified windows. If the 300% Primary Spirit Hall potency meaningfully raises your burst and you can trigger it often, the slower pace can be worthwhile. If your build gains little from the selected Spirit Hall bonus, a faster weapon may fit more naturally.
For Diablo 4 endgame Spiritborn players, Wushe Nak Pa is best chosen after testing your Ultimate cadence, Primary Spirit Hall value, and actual uptime in demanding fights. Players comparing cheap Diablo 4 Items should prioritize a weapon that supports their full rotation, because this glaive shines when its 15-second window is used with purpose.
