praegune kellaaeg 11.08.2026 11:34:58
GuidoS
05.08.2026 20:47:16
6» M: Salvestid ja kaamerad :: Asukoht: Tartu |
1. HikVision IP NVR salvesti 16 kanalit 8MP 4K, DS-7616NI-K2
https://www.hikvision.com/mena-en/products/IP-Products/Network-Video-Recorders/Pro-Series/ds-7616ni-k2/
Up to 16-ch IP camera inputs
H.265+/H.265/H.264+/H.264 video formats
Up to 2-ch@8 MP or 4-ch@4 MP or 8-ch@1080p decoding capacity
1 HDMI and 1 VGA interfaces, both interfaces support independent video output
2 SATA interfaces for HDD connection (up to 16 TB capacity per HDD)
Up to 160 Mbps incoming bandwidth
AH : 50€
OK: 150€
2. IP salvesti 16-ne Dahua NVR4216-4KS2
https://www.dahuasecurity.com/asset/upload/product/20180224/DHI-NVR4216_4232-16P-4KS2_datasheet_20180224.pdf
Dahua NVR4216-4KS2/L
16 kanalit
salvestamine kuni 8MP ja 160 Mbps
VGA ja HDMI kuni 4K
Onvif ja RTSP tugi
koodekid: H.264(+)/.H265(+)/MJPEG
Salvestuse otsing sihtklassifikatsiooni järgi 12ch: inimene ja auto (peab olema WizSense/Mind kaamera)
2xUSB
Kuni 20TB (2xSATA)
RJ45 1000Mbps
VGA pesa roostes, sata kaablid puudu
AH: 40€
OK: 122€
3. IP camera Hikvision iDS-2CD7547G0/P-XZHSY(2.8-12mm) 4MP DeepinViewANPR Moto Varifocal Dome Camera 2.8-12mm
https://bkeesti.ee/en/ip-camera-ids-2cd7547g0-p-xzhsy-2-8-12mm-4mp-deepinview-anpr-white-311322200.html
High quality imaging with 4 MP resolution
Excellent low-light performance via DarkfighterS technology
Efficient H.265+ compression technology to save bandwidth and storage
Clear imaging against strong back light due to 140 dB true WDR technology
5 streams to meet a wide variety of applications
Water and dust resistant (IP67) and vandal proof (IK10)
Unique PTRZ capability for efficient installation
AH: 250€
OK: 600€
4. kaamera Dahua IPC-HFW5442E-ZE-2712-S3 4MP IP torukaamera • ePoE WizMind-S IR60m I/O audio 2.7-12mm
https://www.videovalve.ee/ip-torukaamerad/ipc-hfw5442e-ze-2712-s3?srsltid=AfmBOooW61jK3JP6Y-4D6zZbE50ORVxTmCelulN2T5pemO8FdAZmD-1u
Sensor • 1/1.8” 4MP progressive scan CMOS 2688 × 1520 (V)
Mälu • 1GB muutmälu (RAM), 4GB püsimälu (ROM)
Valgustundlikkus • 0.0007 lux@F1.8 (Color, 30 IRE); 0.0004 lux@F1.8 (B/W, 30 IRE)
Öövalgus • Smart funktsiooniga IR LED kuni 60m (Auto; manual)
Objektiiv • Mootorsuum 2.7-12mm, vaatenurk horisontaalsuunas 115°–47°
AH: 75€
OK: 200€
5. kaamera Dahus DH-IPC-HDW2100
https://www.ipcam.com.mx/PDFs/IPCHDW2100.pdf
1/3” 1.3Megapixel progressive scan Aptina CMOS
H.264 & MJPEG dual-stream encoding
Max 15fps@1.3M(1280×960)&25/30fps@720P(1280×720)
Day/Night(ICR), 2DNR, AWB, AGC, BLC
Multiple network monitoring: Web viewer, CMS(DSS/PSS) & DMSS
3.6mm fixed lens (2.8mm,6mm optional)
Max. IR LEDs Length 20m
IP66, PoE
AH: 10€
OK: 20€
6. 5MP Lite IR Fixed-focal Eyeball Network Camera Dahua IPC-HDW2531T-AS - valge
https://www.dahuasecurity.com/tr/products/All-Products/Network-Cameras/Lite-Series/5-MP/IPC-HDW2531T-AS-S2=S2
5MP, 1/2.7” CMOS image sensor,low illuminance, high image definition
Outputs max. 5MP (2592 × 1944) @20 fps, and supports 2688 ×1520 (2688 × 1520) @25/30 fps
H.265 codec, high compression rate, ultra-low bit rate
Built-in IR LED, max IR distance: 40 m
ROI, SMART H.264+/H.265+, flexible coding, applicable to various bandwidth and storage environments
AH: 40€
OK: 75€
Kõik seadmed on kasutatud, toimivad. Tehase seaded taastatud.
Soovi korral saab arvega, siis lisandub KM
Teema lukku 12.08 päeva lõpuks
Tartus toon kohale, mujale saadan peale ettemaksu laekumist ostja vastutusel ja kuluga.
| Kommentaarid: 34 loe/lisa |
30 |
DVBGod
06.08.2026 20:55:53
3 ja 4 AH
_________________ Never loose your dreams! |
| Kommentaarid: 124 loe/lisa |
8 :: |
96 |
snake_one
10.08.2026 23:06:09
| 1 ja 5 AH + Post ( Tallinn )
| Kommentaarid: 10 loe/lisa |
10 |
