praegune kellaaeg 21.09.2026 06:21:04
1dumbpcuser
25.06.2026 21:44:04
Nvidia Says AI's Water Challenge Is Largely Solved |
unusualwhales
Nvidia is telling the market that one of AI's loudest environmental criticisms is about to fade. “The water consumption challenge for data centers is largely solved,” said Josh Parker, Nvidia's chief sustainability officer, in an interview last week ahead of his trip to London.
Nvidia announced Monday at London Climate Week that its latest AI system can be fully cooled with liquid warm enough to reduce the need for additional chilling equipment.
Nvidia's coolant, a recirculated liquid mixture that includes water and propylene glycol similar to automotive antifreeze, can run at 113 degrees Fahrenheit. Because the liquid can operate at higher temperatures than previous systems, data centers may be able to rely less on chilling equipment that uses large amounts of energy or water, or even eliminate it altogether.
Nii et siis varsti hakkavad auto jahutusvedelike hinnad ka tõusma
_________________ M: MSI B660M MORTAR
O: AM5 ITX emaplaat |
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
