praegune kellaaeg 11.04.2026 21:58:26
TT
10.04.2026 09:50:54
H» M: Cisco 16 port PoE switch :: Asukoht: Harju-Risti |
link :: Cisco CBS250-16P-2G-EU
Racki kõrvad ja toitekaabel kaasa.
AH: 180
OK: 200
_________________ Things ThaT You own end up Owning you! |
| Kommentaarid: 310 loe/lisa |
274 |
10.04.2026 10:28:57
half-width racki jaoks jääb veidi laiaks?
_________________ - londiste
217 |
TT
10.04.2026 20:01:07
Mõõdud:
Width: 268 mm (10.56 inches)
Depth: 297 mm (11.69 inches) or 272 mm (10.69 inches)
Height: 44 mm (1.73 inches)
Weight: 2.38 kg (5.25 lb)
Form Factor: Rack-mountable (1 RU) or Desktop.
274 |
