uus teema   vasta Ärifoorumid »  Arvutitehnika ja tarkvara müük/vahetus »   M: 8TB kõvakettad WD Red Plus :: Asukoht: Tallinn märgi kõik teemad loetuks
sõnum 18.02.2026 00:35:52  M: 8TB kõvakettad WD Red Plus :: Asukoht: Tallinn vasta tsitaadiga
Kettad on kontrollitud ja testitud, SMART on puhas:
HDD1:
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Red Plus
Device Model:     WDC WD80EFAX-68KNBN0
Serial Number:    VDJ1UUHK
LU WWN Device Id: 5 000cca 0bbdd0450
Firmware Version: 81.00A81
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Feb 15 16:38:37 2026 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x84)   Offline data collection activity
               was suspended by an interrupting command from host.
               Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)   The previous self-test routine completed
               without error or no self-test has ever
               been run.
Total time to complete Offline
data collection:       (   87) seconds.
capabilities:           (0x5b) SMART execute Offline immediate.
               Auto Offline data collection on/off support.
               Suspend Offline collection upon new
               command.
               Offline surface scan supported.
               Self-test supported.
               No Conveyance Self-test supported.
               Selective Self-test supported.
SMART capabilities:            (0x0003)   Saves SMART data before entering
               power-saving mode.
               Supports SMART auto save timer.
Error logging capability:        (0x01)   Error logging supported.
               General Purpose Logging supported.
Short self-test routine
recommended polling time:     (   2) minutes.
Extended self-test routine
recommended polling time:     ( 877) minutes.
SCT capabilities:           (0x003d)   SCT Status supported.
               SCT Error Recovery Control supported.
               SCT Feature Control supported.
               SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME                                                   FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate                                              0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance                                           0x0004   128   128   054    Old_age   Offline      -       108
  3 Spin_Up_Time                                                     0x0007   155   155   024    Pre-fail  Always       -       527 (Average 522)
  4 Start_Stop_Count                                                 0x0012   100   100   000    Old_age   Always       -       84
  5 Reallocated_Sector_Ct                                            0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate                                                  0x000a   100   100   067    Old_age   Always       -       0
  8 Seek_Time_Performance                                            0x0004   128   128   020    Old_age   Offline      -       18
  9 Power_On_Hours                                                   0x0012   093   093   000    Old_age   Always       -       50442
10 Spin_Retry_Count                                                 0x0012   100   100   060    Old_age   Always       -       0
12 Power_Cycle_Count                                                0x0032   100   100   000    Old_age   Always       -       82
192 Power-Off_Retract_Count                                          0x0032   099   099   000    Old_age   Always       -       1947
193 Load_Cycle_Count                                                 0x0012   099   099   000    Old_age   Always       -       1947
194 Temperature_Celsius                                              0x0002   144   144   000    Old_age   Always       -       45 (Min/Max 21/54)
196 Reallocated_Event_Count                                          0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector                                           0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable                                            0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count                                             0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     50289         -
# 2  Short offline       Completed without error       00%     50121         -
# 3  Extended offline    Completed without error       00%     50040         -
# 4  Short offline       Completed without error       00%     49953         -
# 5  Short offline       Completed without error       00%     49785         -
# 6  Short offline       Completed without error       00%     49617         -
# 7  Short offline       Completed without error       00%     49449         -
# 8  Extended offline    Completed without error       00%     49286         -
# 9  Short offline       Completed without error       00%     49113         -
#10  Short offline       Completed without error       00%     48945         -
#11  Short offline       Completed without error       00%     48777         -
#12  Short offline       Completed without error       00%     48609         -
#13  Extended offline    Completed without error       00%     48564         -
#14  Short offline       Completed without error       00%     48441         -
#15  Short offline       Completed without error       00%     48273         -
#16  Short offline       Completed without error       00%     48105         -
#17  Short offline       Completed without error       00%     47937         -
#18  Extended offline    Completed without error       00%     47819         -
#19  Short offline       Completed without error       00%     47769         -
#20  Short offline       Completed without error       00%     47600         -
#21  Short offline       Completed without error       00%     47432         -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
HDD2:
Serial Number:    VDHZE77K
77KLU WWN Device Id: 5 000cca 0bbdbec50
Local Time is:    Sun Feb 15 16:38:42 2026 EET
               been run.
               command.
               power-saving mode.
recommended polling time:     ( 922) minutes.
  2 Throughput_Performance                                           0x0004   127   127   054    Old_age   Offline      -       112
  3 Spin_Up_Time                                                     0x0007   150   150   024    Pre-fail  Always       -       539 (Average 540)
  4 Start_Stop_Count                                                 0x0012   100   100   000    Old_age   Always       -       80
  9 Power_On_Hours                                                   0x0012   093   093   000    Old_age   Always       -       50133
12 Power_Cycle_Count                                                0x0032   100   100   000    Old_age   Always       -       78
192 Power-Off_Retract_Count                                          0x0032   099   099   000    Old_age   Always       -       1915
193 Load_Cycle_Count                                                 0x0012   099   099   000    Old_age   Always       -       1915
194 Temperature_Celsius                                              0x0002   144   144   000    Old_age   Always       -       45 (Min/Max 25/50)
No Errors Logged
# 1  Short offline       Completed without error       00%     49980         -
# 2  Short offline       Completed without error       00%     49813         -
# 3  Extended offline    Completed without error       00%     49734         -
# 4  Short offline       Completed without error       00%     49644         -
# 5  Short offline       Completed without error       00%     49476         -
# 6  Short offline       Completed without error       00%     49308         -
# 7  Short offline       Completed without error       00%     49140         -
# 8  Extended offline    Completed without error       00%     48978         -
# 9  Short offline       Completed without error       00%     48804         -
#10  Short offline       Completed without error       00%     48636         -
#11  Short offline       Completed without error       00%     48468         -
#12  Short offline       Completed without error       00%     48300         -
#13  Extended offline    Completed without error       00%     48256         -
#14  Short offline       Completed without error       00%     48132         -
#15  Short offline       Completed without error       00%     47964         -
#16  Short offline       Completed without error       00%     47796         -
#17  Short offline       Completed without error       00%     47628         -
#18  Extended offline    Completed without error       00%     47511         -
#19  Short offline       Completed without error       00%     47460         -
#20  Short offline       Completed without error       00%     47291         -
#21  Short offline       Completed without error       00%     47123         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Käimamineku garantii saab minu poolt kaasa.
OK: 99€ tk.
Asuvad Põhja-Tallinnas, eelistatud on käest-kätte tehing.
Mujale liigub ainult ostja kulul ning vastutusel ja ettemaksuga.
Vaata kasutaja äripakkumisi
O: Skänner 073
Kommentaarid: 234 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 196
