zyyx
09.01.2026 13:15:38
M: DDR4 RAM, RX570, CPU ja muud -kapipuhastus :: Asukoht: Tallinn |
Tere!
Müün kraami mis seisnud mõnda aega.
2 x Toshiba 1 TB 7200 HDD.
AH: 15 (per ketas)
OK: 30 (per ketas)
RX570 8GB GPU.
AH 25
OK 45
MOBO + CPU
ASrock H310CM-HDV + I5 9400F
AH: 40
OK: 65
1X HYPER X FURY DDR4 8GB 3200Mhz
AH:25
OK:40
1X G.SKILL AEGIS DDR4 3200Mhz
AH: 25
OK: 40
| Kommentaarid: 7 loe/lisa |
rewer
09.01.2026 13:26:06
MOBO + CPU
AH
| Kommentaarid: 1305 loe/lisa |
920 |
p33rs6
09.01.2026 13:30:45
On see 8gb pulk?
Kui jah, siis AH leiaks käest kätte.
| Kommentaarid: 446 loe/lisa |
7 :: |
376 |
commer
| Kommentaarid: 914 loe/lisa |
706 |
Diesel157
09.01.2026 19:27:00
RX570 8GB GPU.
Mis mudel täpsemalt?
| Kommentaarid: 159 loe/lisa |
144 |
Jman
09.01.2026 20:21:50
Toshiba 1 TB 7200 2tk 30.-
_________________ Its just a plant! It grows like that, but if you happen to set it on fire... there are some effects  |
| Kommentaarid: 225 loe/lisa |
197 |
zyyx
10.01.2026 14:12:25
| commer kirjutas: |
ASrock H310CM-HDV + I5 9400F OK
1X HYPER X FURY DDR4 8GB 3200Mhz 20.- |
MOBO Ja prose annaks.
RAM ikkagi tahaks vähemalt AH.
