praegune kellaaeg 21.12.2025 19:41:49
8jalg
16.12.2025 21:31:24
» M: UUS Poly Trio C60 IP Conference Phone Avamata pakend :: Asukoht: Tallinn |
The Polycom Trio C60 is a SIP compatible IP conference phone that connects to your IP PBX or compatible hosted service provider. It provides natural flowing conversations with no clipping or interruptions. The Trio C60 features a large touchscreen, integrated Bluetooth and Wi-Fi, Gigabit Ethernet, 20 foot microphone pickup range, and wideband audio for crystal clear conversations. With the addition of optional expansion microphones, it can accommodate longer conference tables and larger conference rooms.
Hinnasoov 250
USER INTERFACE FEATURES
• Gesture-based, multitouch-capable
capacitive touch screen
• 5-inch color LCD (720 x 1280 pixel), 9:16
aspect ratio
• On-screen virtual keyboard
• One USB 2.0 Type A-compliant port
• One USB 2.0 Micro-B device port for use as
USB audio device and content sharing
• Integrated Bluetooth 5.01
• Three multi-colored mute indicators and
three sets of capacitive touch volume and
mute buttons.
• User interface localized in Arabic, Chinese,
Danish, Dutch, English (Canada/US/UK),
French, German, Italian, Japanese, Korean,
Norwegian, Polish, Portuguese, Russian,
Slovenian, Spanish and Swedish
AUDIO FEATURES
• Three MEMS microphones for 360 degree
mic pick up
• Loudspeaker
- Frequency: 100—22,000 Hz
- Volume: 92 dB at 0.5-m peak volume
• 6.1 m/20 ft microphone pickup range
• Supported codecs:
- G.711 (A-law and μ-law)
- G.719
- G.722, G722.1, G722.1C
- G.729AB
- Poly Siren 7, Siren 14
- iLBC (3.33 Kbps and 15.2 Kbps)
- Opus (8 Kbps–24 Kbps)
- SILK
- Poly Acoustic Clarity technology provides
full-duplex conversations, acoustic
echo cancellation and background noise
suppression–Type 1 compliant (IEEE 1329
full duplex)
• Poly NoiseBlockAI
• Voice activity detection
• Comfort noise generation
• DTMF tone generation (RFC 2833 and in-band)
• Bluetooth® device pairing1
• Low-delay audio packet transmission
• Adaptive jitter buffers
• Packet loss concealment
CALL HANDLING FEATURES
(MAY BE DEPENDENT ON CONFIGURATION AND ECOSYSTEM)
• Up to three lines (max. one Skype for
Business)
• Shared call/bridged line appearance
• Distinctive incoming call
treatment/call waiting
• Call timer and call waiting
• Call transfer, hold, divert (forward), pickup
• Called, calling, connected-party information
• One-touch speed dial and meeting join
• Local five-way audio conferencing
• Daisy-chain up to three
• Do-not-disturb function
• Local configurable digit map/dial plan
• Corporate directory access using LDAP
• Visual conference management
NETWORK
• Open SIP
• Skype for Business (certification pending)
• Microsoft Teams (certification pending)
• IETF SIP (RFC 3261 and companion RFCs)
• SDP
• Two-port gigabit Ethernet switch
- 10/100/1000Base-TX across LAN IN
and LAN OUT
- LAN OUT port supports IEEE 802.3af PSE
• Wi-Fi network connectivity (MIMO)1
- 2.4–2.4835 GHz (802.11b, 802.11g,
802.11n HT-20)
- 5.15–5.825 GHz (802.11a, 802.11n HT-20,
HT-40; 802.11ac HT-20, HT-40, HT-80)
MANAGEMENT
• Poly Lens
• PDMS-E, PDMS-SP
• RealPresence Resource Manager (v. 10.9 or
above) based provisioning
• Manual or dynamic host configuration
protocol (DHCP) network setup
• Poly Zero Touch Provisioning
• FTP/TFTP/HTTP/HTTPS server-based
central provisioning
• Provisioning and call server redundancy support
• Time and date synchronization using SNTP
SECURITY
• 802.1X authentication and EAPOL
• Media encryption via SRTP
• Transport layer security (TLS) v 1.2
• Encrypted configuration files
• Digest authentication
• Password login
• Support for URL syntax with password for
boot server address
• HTTPS secure provisioning
• Support for signed software executables
• Wi-Fi encryption1
: WEP, WPA-Personal,
WPA2-Personal, WPA2-Enterprise with
802.1X (EAP-TLS, PEAP-MSCHAPv2)
POWER
• LAN IN: Built-in auto-sensing IEEE 802.3at.
PoE Device (Class 4) (requires full Class 4
power input on LAN IN for operation Class
0 if no PSE). Backward compatibility with
IEEE 802.3af
• LAN OUT: Built-in auto-sensing IEEE
802.3af power sourcing equipment
(requires full Class 4 power input on
LAN IN for operation)
| Kommentaarid: 31 loe/lisa |
30 |
