praegune kellaaeg 04.07.2025 10:43:06
Amdfan
04.07.2025 08:43:43
6» M: 16TB, 18TB SATA kettad, 2x 3.5" USB kettaboksid :: Asukoht: Tallinn |
1. QNAP Qnap TL-D800C
The TL-D800C JBOD storage enclosure allows you to back up and expand your QNAP NAS. The TL-D800C features eight 3.5-inch SATA 6Gb/s drive bays with USB 3.2 Gen2 (10 Gbps) Type-C connectivity to provide a fast and smooth expansion solution
https://www.qnap.com/en/product/tl-d800c
Kaks usb kaablit, kruvid, kettaraamid kaasas. Ainult ühe raami plastikust kiirkinnitust ketta jaoks ei leidnud kohe, seal peab siis lihtsalt ketta kruvidega fikseerima.
AH/OK: 350€/400€
2. FANTEC QB-35US3-6G - 4x3.5" SATA kettaboks, USB´ga.
https://www.fantec.de/en/products/storage-devices/ssd-hard-drive-cases/35-inch-hard-drive-cases/produkt/details/artikel/1695_fantec_qb_35us3_6g/
Korpusel mõned kriipsud, täkked.
AH: 80 EUR
3. 18TB Seagate Exos X18 ST18000NM000J
Seagate garantii kuni October 20, 2026
AH: 230€
4. 16TB Seagate IronWolf NAS ST16000VN001
AH: 180€
5. 16TB TOSHIBA MG08ACA16TE
AH: 190€
6. 16TB TOSHIBA MG08ACA16TE
SMART korras, töötunde ca2000h, täpse seisu lisan natuke hiljem.
AH:200€
Kettaid postiga ei saada, kettaboksid liiguvad ostja kulul.
Kommentaarid: 334 loe/lisa |
309 |
lisa lemmikuks |
