praegune kellaaeg 19.06.2025 14:57:17
don
15.06.2025 23:38:03
3» M: HP Active Pen G2 x3 :: Asukoht: Tartu |
Müüa 3x HP Active Pen G2
Korraks kasutatud, kuid täiesti uueväärsed, HP originaaltooted
Hind 15.- tk või 40.- 3 tükki
Inglise keelne kirjeldus:
The HP Active Pen G2: your intuitive and customizable stylus for taking notes, drawing on the screen, and naturally navigating your applications.
Technical specifications:
Tip diameter: 1.8 mm; 2.7 mm
Pen pressure sensitivity: 4096 levels
Rechargeable battery/battery type: Rechargeable lithium-ion battery
Battery life: Up to 7 days (normal use)
Dimensions (W x D x H): 148 x 1.2 mm
Weight: 15 g
Compatible operating systems: Windows 11, Windows 10, Windows 8
Warranty: 1 year manufacturer warranty
Compatibility: The pen is compatible with the following devices:
HP Elite x2 1013 G3
HP EliteBook x360 1030 G3
HP EliteBook x360 1030 G2
HP EliteBook x360 1040 G5
HP EliteBook x360 1020 G2
HP Pro x2 612 G2
It offers a latency of 30-35 milliseconds, no tilt detection or tilt sensitivity adjustment, 2048 levels of pressure sensitivity, and a report rate of 133-200 Hz (depending on whether the simultaneous pen and touch mode is enabled).
Kommentaarid: 56 loe/lisa |
51 |
lisa lemmikuks |
