praegune kellaaeg 25.10.2026 11:05:10
CnZ
25.02.2004 20:43:27
Emaplaat millel on SDR Pc -133 Ramm sees kas suppordib DDR'i ? |
Motherboard Properties
Motherboard ID 51-2300-000000-00101111-030199-$HV845
Motherboard Name Intel Winnipeg D845WN
Front Side Bus Properties
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 100 MHz (QDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties
Bus Type SDR SDRAM
Bus Width 64-bit
Real Clock 133 MHz
Effective Clock 133 MHz
Bandwidth 1067 MB/s
Chipset Bus Properties
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1
Expansion Slots 6 PCI, 1 AGP
RAM Slots 3 DIMM
Integrated Devices Audio
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset i845
Motherboard Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/design/motherbd/index.htm
BIOS Download http://www.intel.com/design/motherbd/genbios.htm
Et siis kas sellisele sobiks Pc -2700 333mhz 512 panna ? Kas on võimalik...
| Kommentaarid: 14 loe/lisa |
Plin500
HV piljardihai
25.02.2004 20:52:14
läheb ainult PC133 SDRAM
| Kommentaarid: 79 loe/lisa |
77 |
clocker
25.02.2004 21:01:21
| Muidugi mitte. PC66-PC133 SDRAM läheb sinna.
| Kommentaarid: 29 loe/lisa |
26 |
pealuu
| Kommentaarid: 213 loe/lisa |
172 |
