uus teema   vasta Hinnavaatlus »  Naljakad juhtumised arvutimaailmast »  Microsoft help desk :D märgi kõik teemad loetuks
fredd
sõnum 04.02.2004 13:58:57 Microsoft help desk :D vasta tsitaadiga
leidsin sellise huvitava teksti icon_biggrin.gif Ikka naerma ajab icon_razz.gif
Here are some conversations, from Microsoft, which had actually taken place between help desk people and their customers:
Customer: "You've got to fix my computer. I urgently need to print a document, but the computer won't boot properly."
Tech Support: "What does it say?"
Customer: "Something about an error and non-system disk."
Tech Support: "Look at your machine. Is there a floppy inside?"
Customer: "No, but there's a sticker saying there's an Intel inside."
Tech Support: "Just call us back if there's a problem. We're open 24 hours."
Customer: "Is that Eastern time?"
Tech Support: "Ok, now click your left mouse button."
Customer: (silence) "But I only have one mouse."
Tech Support: "I need you to right-click on the Open Desktop."
Customer: "Ok."
Tech Support: "Did you get a pop-up menu?"
Customer: "No."
Tech Support: "Ok. Right click again. Do you see a pop-up menu?"
Customer: "No."
Tech Support: "Ok, sir. Can you tell me what you have done up until this point?"
Customer: "Sure, you told me to write 'click' and I wrote'click'."
Customer: "I received the software update you sent,but I am still getting the same error message."
Tech Support: "Did you install the update?"
Customer: "No. Oh, am I supposed to install it to get it to work?"
Customer: "I'm having trouble installing Microsoft Word."
Tech Support: "Tell me what you've done."
Customer: "I typed 'A:SETUP'."
Tech Support: "Ma'am, remove the disk and tell me what it says."
Customer: "It says '[PC manufacturer] Restore and Recovery disk'."
Tech Support: "Insert the MS Word setup disk."
Customer: "What?"
Tech Support: "Did you buy MS word?"
Customer "No..."
Customer: "Do I need a computer to use your software?"
Tech Support: ?@#$ < mailto:?@#$ > ?
Tech Support: "Ok, in the bottom left hand side of the screen, can you see the 'OK' button displayed?"
Customer: "Wow. How can you see my screen from there?"
Tech Support: "What type of computer do you have?"
Customer: "A white one."
Tech Support: "Type 'A:' at the prompt."
Customer: "How do you spell that?"
Tech Support: "Is your computer on a separate telephone line?"
Customer: "No." (clicks the button to log on to our service)
Tech Support: "Well then we can't-"
Customer: "It says 'no dial tone'."
Tech Support: "That's because you're on the line with me right now.You need to-"
Customer: "No, that's not it. It does this all the time. I just have to try a few times, and it will let me through."
Tech Support: "No, ma'am. It's not even trying to dial right now because you're on the phone with me."
Customer: "It must be busy. I'll try again later."
Tech Support: "What's on your screen right now?"
Customer: "A stuffed animal that my boyfriend got me at the grocery store."
Tech Support: "What operating system are you running?"
Customer: "Pentium."
Customer: "My computer's telling me I performed an illegal abortion."
Customer: "I have Microsoft Exploder."
Customer: "How do I print my voicemail?"
Tech Support: "What does the screen say now?"
Customer: "It says, 'Hit ENTER when ready'."
Tech Support: "Well?"
Customer: "How do I know when it's ready?"
Customer: "I have a long distance modem."
Customer: "I don't have a space bar."
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 29
Cyberlord
sõnum 04.02.2004 14:02:29 vasta tsitaadiga
Kuigi selliseid tekste on netis lademes, paneb inimeste lollus ikka ja jälle imestama icon_lol.gif
Kommentaarid: 546 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 449
argo
argo
sõnum 04.02.2004 14:48:04 vasta tsitaadiga
Kommentaarid: 22 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 19
Elof
Elof
sõnum 04.02.2004 15:12:34 vasta tsitaadiga
Alguses arvuti lihtsalt ülbitseb, varsti tekib AI, ning siis pole juba kaugel ka Terminator III
tanelp
sõnum 04.02.2004 15:37:42 vasta tsitaadiga
t2iega naljakas, ma naersin küll ikka p2ris k6vasti. icon_biggrin.gificon_biggrin.gificon_biggrin.gificon_biggrin.gificon_biggrin.gif
Kommentaarid: 4 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 2
Negative
Negative
sõnum 04.02.2004 16:27:36 vasta tsitaadiga
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 42
Caveman
Caveman
sõnum 05.02.2004 22:45:47 vasta tsitaadiga
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 4 :: 10 :: 41
itimees
itimees
sõnum 06.02.2004 03:34:21 vasta tsitaadiga
need juhtumised on vist siit pärit. see link peaks olema siit juba läbi käinud..
Kunagi pole aega korralikult teha, aga alati on aega ümber teha
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 85
kotmarjak
kotmarjak
sõnum 06.02.2004 23:08:41 vasta tsitaadiga
lademetes küll, aga arvatavasti on kõik ameerikas tehtud. on ikka lollakad hamburgeri õgijad küll
Ole tore !
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 5 :: 8 :: 117
fredd
sõnum 07.02.2004 10:09:14 vasta tsitaadiga
itimees kirjutas:
Max Powers
sõnum 07.02.2004 10:11:33 vasta tsitaadiga
A Friend: "There's an icon on my desktop that won't go away."
Me: "Did you click on the icon once and hit 'delete'?"
A Friend: "I haven't tried that yet."
Taun0
Taun0
sõnum 10.02.2004 23:56:26 vasta tsitaadiga
Kommentaarid: 68 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 62
reimers66
reimers66
sõnum 11.02.2004 00:03:42 vasta tsitaadiga
pole nagu väga naljakas kui arvesse võtta kui palju inimesi leidub icon_biggrin.gif aga nohh mäletan isegi kui esimese arvuti 386 ostsin ja küsiti siis et
mis arvuti on ma vastasin rahulikult et COMPAQ
Kommentaarid: 65 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 60
HDD
HDD
sõnum 11.02.2004 00:08:46 vasta tsitaadiga
thumbs_up.gif see on hea
The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it icon_smile.gif
Kommentaarid: 62 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
arm2004
arm2004
sõnum 11.02.2004 00:10:14 vasta tsitaadiga
Caveman kirjutas:
nooope!
one
one
sõnum 11.02.2004 07:27:52 vasta tsitaadiga
Taun0 kirjutas:
Kommentaarid: 168 loe/lisa Kasutajad arvavad:  :: 3 :: 3 :: 129
