Heineken
19.01.2011 08:16:19
Joppas siis.
| Kommentaarid: 24 loe/lisa |
23 |
ceemic
24/7@kalal
21.01.2011 15:19:16
ColorsIt 400W
Fortron BlueStorm 500W
Fortron Everest 800W
SilverStone OP1000-E
Corsair HX620
Corsair HX1000
Corsair VX550
Chieftec 450W GPS-450AA-101A
322 |
lolloom
28.01.2011 08:22:22
Codegen 400W
Antec 350W
LC-Power 550W
Fortron Bluestorm 500W
Antec TP 430W tappa
Corsair VX550
Corsair TX650
| Kommentaarid: 244 loe/lisa |
209 |
esseker
29.12.2011 19:08:55
| esseker kirjutas: |
Codegen 400W
Fortron BlueStorm II 500W
Chieftec 850w Turbo Series
Chieftec CFT-500-A12S
XILENCE 1000w :XP1000 |
CHIEFTEC PSU 850W 14CM ATX12 80+ CAB.MAN BPS-850C
110 |
Timo1337
29.12.2011 22:32:05
| Timo1337 kirjutas: |
päris algust ei mäletagi aga mingi viimase 5aasta omad
Compaq - 260W
Codegen - 400W
FSP650-80GLC - 650W |
Chifetec 600W 140mm
Seasonic 520W 80+
SeaSonic X series Modular 760W 80+ Gold Fully Modular. X-760
| Kommentaarid: 49 loe/lisa |
46 |
Drizzle
30.12.2011 00:17:45
Codegen 400w
Chieftec 450w
Chieftec 750w
Tagan Superrock 600w
Seasonic X-760
_________________ Sven Suigussaar Photography |
| Kommentaarid: 93 loe/lisa |
30.12.2011 01:09:21
| mikk36 kirjutas: |
Ports erinevaid Codegene
350W Zalman
480W Thermaltake
700W Chieftec |
Oleks peaaegu uue toiteka saanud, aga kolb aitas välja
| Kommentaarid: 85 loe/lisa |
heff
30.12.2011 01:39:00
300w powercolor vms
400w fortron
400w chieftec
650w chieftec
850w corsair
98 |
eXceed
20.01.2012 07:23:06
| eXceed kirjutas: |
Codegen 400W
Fortron BlueStorm II 500W-suri
Chieftec 1200W
Silverstone OP700 |
Corsair HX1000
| Kommentaarid: 190 loe/lisa |
153 |
Harald88
20.01.2012 09:28:02
codegen 350W
codegen 400W
Fortron BS II 500W
Corsair TX750 750W
| Kommentaarid: 22 loe/lisa |
22 |
SurfData
24.01.2012 14:31:18
| SurfData kirjutas: |
aastast 2001 on olnud siis nii:
300W Aopen
350W ColorsIT
580W Hiper
700W Fortron
1010W OCZ Gamer Extreme
Updateks seda siis parandustega:
300W Aopen
350W ColorsIT
580W Hiper modulaarne (kooles ära, kuid õnneks garantii ajal )
700W Fortron
1010W OCZ Gamer Extreme (kooles 2 nädalat tagasi ära, õnneks oli ainult 2,5 aastat vana ja garantii 3 aastat )
asemele võtsin kiiruga
850W Chieftec mis on kangem kui oli see 1010W OCZ , ainult et sata toiteid ja 4 pinniseid molekseid on kumbagi 9 asemel 6 võrreldes OCZ-iga Pluss poole pealt jällegi, et on modulaarne. |
no nüüd tuleb uude masinasse korralik enermax sisse :
Enermax Modulare PSU Revolution 85+, 1250 W (80PLUS Silver)/DXXI/ Modular/ ATX v2.3/ Magnetic Bearing 135mm FAN/ Active PFC/ Black
Power: Enermax Revolution85+ - power supply 1250 Watt
Dimensions: 17.5 cm x 15 cm x 8.6 cm
Connectors: 1 x power 24 pin ATX ¦ 1 x power 8 pin +12V with detachable 4 pin section ¦ 6 x 8 pin PCI Express power with detachable 2 pin section ¦ 6 x 4 PIN internal power ¦ 1 x 4 PIN mini-power connector ¦ 12 x 15 pin Serial ATA power ¦ Power 8 pin EPS12V
Features: Power supply - active Power Factor Correction (PFC) - internal
Fan: 140 mm fan
AC input voltage: AC 115-240 V
Other: 85PLUS ready! World's leading modular PSU series with 86-92.9% efficiency @ 20-100% load. Certified by 80 PLUS® organization. nVidia® SLI® certified. (ENERMAX REVOLUTION85+ 920W, ERV920EWT-00, NVIDIA, SLI are registered trademarks or trademarks of NVIDIA Corporation.) FUTURE CPU ready: Ready for most upcoming CPU generations by 12P sockets for possible connector changes, by complying to latest EPS12V PSU design guides for compatibility & by ZERO LOAD Design for C6 state functions. FUTURE GPU ready: Ready for most upcoming GPU generations by 12P sockets for possible connector changes, by four massive 12V rails for perfect load distribution & by ZERO LOAD Design for Hybrid Mode functions. 24/7 @ 50°C ready: Non-Stop industrial class performance at 50°C ambient. CordGuard: Fixing the AC cord tightly to avoid accidental shutdowns of your PC. HeatGuard: Keeping PSU fan running for 30-60 seconds after shut down to dissipate the remaining system heat and prolonging system lifetime. SafeGuard: Industry-leading octuple protection circuitry (OCP, OVP, AC UVP, DC UVP, OPP, OTP, SCP, and SIP). AirGuard: Patented air-inlet with optimal aero-dynamical design reducing noisy air turbulences. Silent ready: Ultra-quiet 13.9cm fan with intelligent RPM control guarantees cool performance and silent operation. 99% 12V Power: World's leading EPS12V PSU with 99% 12V output capability. SERVER ready: SSI PSDG 2008 v1.2 support for latest Intel® Core™ Extreme/i7, Xeon™ and AMD® Opteron™ and SLI® or CrossFireX™ and AMD GAME! or AMD GAME! Ultra systems and downward compatible with SSI PSDG 2008 v1.1, v1.0, EPS12V 2.92, 2.91, 2.8. DXXI ready: 100% 6+2P (8P) PCI-E connector to support new generation DXXI graphic cards.
Product code: ERV1250EGT
| Kommentaarid: 84 loe/lisa |
74 |
Scart
24.01.2012 16:12:08
Profiilimasinat toidab endiselt 2004 jõulud ostetud 480w Anteci Trupower
101 |
Evil
Hull
09.03.2013 15:22:38
| Evil kirjutas: |
Codegen 350W
Antec TruePower 550W
TT PurePower 680W
OCZ Powerstream 520W
FSP Epsilon 700W
TT Toughpower 750W
FSP Epsilon 1KW
Chieftec 1200W
Corsair HX850 |
Corsair CX600 Core 2 Extreme jaoks.
Mingeid odavamaid chieftec-i junne on ka aga neid ei viitsi üles lugeda.
202 |
Scart
09.03.2013 15:27:56
| Scart kirjutas: |
Profiilimasinat toidab endiselt 2004 jõulud ostetud 480w Anteci Trupower  |
Vanake läks lõpuks auga välja teenitud puhkusele. Kütet hoiab nüüd kontrolli all Zalmani ZM500-LE
101 |
Ramones
10.03.2013 02:29:23
| Ramones kirjutas: |
NoName 350W
Q-Tec 550W
Nexus NX-4000 400W
Hiper Type-R 580W
500W Chieftech GPS-500AB-A |
Seasonic X-Series SS-560KM 560W
| Kommentaarid: 76 loe/lisa |
75 |
von Wu
10.03.2013 03:22:36
Codegen xxxW
Fortron Blue Storm 500W
Corsair HX520 520W
Seasonic X-560 560W
_________________ Müüa igasugu asju
Müüa 4TB SSD
Müüa 55" OLED teler |
| Kommentaarid: 910 loe/lisa |
684 |
A-Circus.
10.03.2013 12:48:00
Codegen 400W
Sunbeamtech 450W (hea toide oli, aga ütles lõpuks üles)
Chieftec 500W APS-500S
Seasonic 620W M12II
| Kommentaarid: 50 loe/lisa |
48 |
esseker
24.03.2013 18:41:09
| esseker kirjutas: |
Codegen 400W
CHIEFTEC PSU 850W 14CM ATX12 80+ CAB.MAN BPS-850C |
Corsair AX 1200i
110 |
ceemic
24/7@kalal
28.01.2014 11:15:36
ColorsIt 400W
Corsair HX620
Corsair HX1000
Corsair VX550
Corsair VS450
Üks hea tootja on meeldivas ülekaalus
322 |
1dumbpcuser
97 |
ceemic
24/7@kalal
28.01.2014 15:07:58
1dumbpcuser, esimesed 4 tundi on hea mulje jätnud
322 |
Jaan
29.01.2014 16:10:00
| Scart kirjutas: |
Ja mul on üks Antec TruePower 550W aastast 2002, mida ma ei suutnudki ära tappa, töötab siiamaani ja on üleelanud ligi tuhat erinevat setupi, nendest üsna suur protsent ekstreemselt ülekiirendatult.
124 |
Evil
Hull
29.01.2014 23:20:41
| Jaan kirjutas: |
| Ja mul on üks Antec TruePower 550W aastast 2002, mida ma ei suutnudki ära tappa, töötab siiamaani ja on üleelanud ligi tuhat erinevat setupi, nendest üsna suur protsent ekstreemselt ülekiirendatult. |
Legendaarne.
Endal saab 5 aastat sügisel Corsair HX850-ga. Raske arvata mis brändi ma järgmisena ostan.
202 |
1dumbpcuser
97 |
TauC
29.07.2014 16:30:57
1. Ei mäleta
2. Codegen 400W
3. OCZ ZT-550 Bronze
4. SeaSonic X-850 Gold
Viimane on ikka super, suurema osa ajast ei käi ventilaator üldse ringi, täismodulaarsusest rääkimata
Tulevikus on plaan mõni Corsair platinum plokk ära proovida.
| Kommentaarid: 328 loe/lisa |
272 |
KillerXP
30.07.2014 09:20:16
| KillerXP kirjutas: |
Tundmatu, midagi 200-250W vahele, ei huvitunud veel siis ajast (esimene arvuti) - müüdud
Codegen 300W - müüdud
Chieftec 360W - müüdud
Chieftec 420W - müüdud
Corsair HX 620W - kasutusel
*Lähima paari aasta jooksul küll uuendada ei plaani, kui siis ainult mõne uue standardi või surma pärast (ptui ptui ptui). |
Pea 5a on HX620W mul jooksnud masinas veatult, nüüdsest jookseb ta elutoa masinas ja põhiliselt kasutusel olev raal sai uue
Corsair HX620W - kasutusel
Corsair AX760 - kasutusel
| Kommentaarid: 98 loe/lisa |
93 |
heretic666
31.07.2014 00:23:38
| heretic666 kirjutas: |
Esimest ei tea
300W Codegen
Chieftec GPS-500AB A
Corsair TX850
Corsair AX860 |
Corsair AX1600i
viimati muutis heretic666 04.03.2022 16:47:33, muudetud 1 kord |
| Kommentaarid: 73 loe/lisa |
Driftmoon
31.07.2014 07:48:06
| Konks kirjutas: |
Enlight 250w
Codegen 300w
ColorsIT 400w (ei kurda)
Chieftech 560w
Enermax 400w (pole veel probleeme tekkinud) |
aeg oleks vana posti täiendada
2012aastast tiksub see asi sees: SeaSonic M12II series Modular 520W 85+
| Kommentaarid: 41 loe/lisa |
40 |
traksid
16.10.2014 17:48:31
FSP Epsilon 80Plus 600W, 7 aastat truu.
Pole vaja vist teist vahetada
| Kommentaarid: 14 loe/lisa |
14 |
RKsilver
20.10.2014 21:54:50
| traksid kirjutas: |
Pole vaja vist teist vahetada  |
Pean nõustuma, viies aasta jookseb ilma probleemideta
| Kommentaarid: 172 loe/lisa |
140 |
Evil
Hull
09.03.2016 01:11:49
| Evil kirjutas: |
Codegen 350W
TT PurePower 680W
FSP Epsilon 700W
TT Toughpower 750W
FSP Epsilon 1KW
Chieftec 1200W
Corsair HX850
Corsair CX600 |
Fractal Design Edison M 450W
202 |
Syncmahv
20.03.2016 20:00:13
| Syncmahv kirjutas: |
Algul mingi Codegenid 350W ja 450W vms
Siis tuli peale Fortron BSII 500W
korra julgesin osta ka ühe Chiefteci 750W mingi 14Cm vendiga oli. aga kaua see ei olnud kuna ilgelt lõugas.
Siis tuli peale üks vaikne kast kus oli sees Anteci toiteplokk, vist oli 420W, ja Ülimalt vaikne oli.
võimalik et siin vahel oli veel üks Bluestorm kah, ei mäleta.
ja nüüd siis Corsair HX620 CMPSU-620HXEU  |
Vahepeal Corsair CX500 mis peale garantii aja läbi saamist otsad andis.
Selle peale võtsin SeaSonic SS-750KM3 750W
102 |
Evil
Hull
29.11.2016 22:12:33
| Evil kirjutas: |
Codegen 350W
TT PurePower 680W
FSP Epsilon 700W
TT Toughpower 750W
FSP Epsilon 1KW
Chieftec 1200W
Corsair HX850
Corsair CX600
Fractal Design Edison M 450W |
Corsair CX750
Seasonic X850
Esimene Seasonic
202 |
andrez3d
26.03.2017 19:59:41
2008 - 2016 Chieftec 400w
2017 - ... Chieftec GPS-700A8
| Kommentaarid: 97 loe/lisa |
91 |
Mask
28.03.2017 18:54:39
| Mask kirjutas: |
300W noname
350W codegen
400W colorsit
400W codegen
480W Hiper type r
400W forton
630W Hiper type m
15.04.2008 |
Corsair cx500W
Enermax naxn 850W
Seasonic G 550W
| Kommentaarid: 523 loe/lisa |
435 |
ceemic
24/7@kalal
24.10.2017 18:29:44
ColorsIt 400W
Corsair HX620
Corsair HX1000
Corsair VX550
Corsair VS450
Seasonic Focus Plus Gold 750W
Corsair AX1000
viimati muutis ceemic 22.01.2022 11:14:12, muudetud 1 kord |
322 |
NATAS999
24.10.2017 18:41:18
mingi aopeni korpusega kaasa tulnud aopen 300W junn
fsp/fortron bluestorm 500W
gigabyte odin 1200W (380V ülepinge vooluvõrgus, rip)
mingi suvakas chieftec 500W
homme peaks kätte saama corsair HX1000
39 |
Driftmoon
22.01.2022 10:00:25
| Konks kirjutas: |
| Konks kirjutas: |
Enlight 250w
Codegen 300w
Chieftech 560w
2012aastast tiksub see asi sees: SeaSonic M12II series Modular 520W 85+ |
2021 vahetasin Seasonicu BitFenix Whisper M 650W Gold vastu.
40 |
Ramones
22.01.2022 12:53:36
| Ramones kirjutas: |
NoName 350W
Q-Tec 550W
Nexus NX-4000 400W
Hiper Type-R 580W
Seasonic X-Series SS-560KM 560W |
Corsair RM750x
75 |
eXceed
02.03.2022 10:40:22
| eXceed kirjutas: |
Codegen 400W
Chieftec 1200W
Silverstone OP700
Corsair HX1000 töös
CORSAIR CX750F RGB töös |
Aorus P850W 80 Plus Gold
_________________ Endast uuematele/vähem tehinguid teinud inimestele, ei saada raha ega kaupa ette...
Seda enam kui pole isegi ID-kaardiga autentimist. |
153 |
Evil
Hull
16.03.2022 20:01:25
| Evil kirjutas: |
Codegen 350W
TT PurePower 680W
FSP Epsilon 700W
TT Toughpower 750W
FSP Epsilon 1KW
Chieftec 1200W
Corsair HX850
Corsair CX600
Corsair CX750
Seasonic X850 |
Seasonic Focus GX750
Seasonic Focus GX850
202 |
andrez3d
09.08.2022 08:53:19
| andrez3d kirjutas: |
2017 - 20222 Chieftec GPS-700A8 |
2022 Chieftec BPS-850C2 80 bronze
91 |
