praegune kellaaeg 11.11.2026 04:34:18
Lauri76
28.11.2020 13:19:13
Edge aeglane |
Windows10 ja nüüd see uus Edge on aeglaseks jäänud...ajalugu on küll puhastatud,aga ei midagi.
Miks ta aeglaseks muutub?
0 |
Mnator
28.11.2020 13:40:45
Õpetus Edge kordategemiseks, kui see on mingil põhjusel riknenud (igasugustes järjehoidjatest jms. pead endale tegema koopiad) :
Completely Reset – Reinstall Edge Browser
If All Above methods Fail Then Reset – Reinstall the Edge Browser is Last and most Working Solution To Fix Different Edge Browser Problems and Fix Edge not responding, Crashes At startup, Microsoft Edge running Slow Etc.
To Reset -Reinstall Edge Browser first Press Win + R, Type %USERPROFILE%\AppData\Local\Packages and hit the enter key.
Scroll down and Navigate to the folder “Microsoft.MicrosoftEdge_8wekyb3d8bbwe“.
Now delete everything inside the folder. (Note: If you can’t remove the file, you can right-click on the folder Select Properties, and then uncheck the Read-only option.)
Now Restart your computer. After that we have to Re-register the Edge Browser. For This Open Powershell ( Admin ) by right click on the Start menu And Select it. Here on Power Shell Type command Below And hit Enter key to execute the same.
Get-AppXPackage -AllUsers -Name Microsoft.MicrosoftEdge | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register “$($_.InstallLocation)\AppXManifest.xml” -Verbose}
After complete, the re-register process simply Reboot the PC to take effect the Changes. Now you can launch the Microsoft Edge browser. I hope This time working properly with Well Speed.
