uus teema   vasta Raud »  Protsessorid »  Aidake leida sobivat mälu ühele Compaq-ile märgi kõik teemad loetuks
sõnum 19.01.2004 17:17:52 Aidake leida sobivat mälu ühele Compaq-ile vasta tsitaadiga
On mingi 4a vana Compaq DeskPro, CPU P-II 300MHz. Hetkel on seal sees 64MB mälu millel peal sildike SEC KMM366S823CTS-GLQ. Kividel on kiri KM48S8030CT-GL. Tundub, et tegemist on SEC (Samsung) ECC mäluga?
Oleks vaja nüüd mälu juurde lisada, aga ei suuda kuidagi sobivat leida. icon_rolleyes.gif
The computer comes with synchronous dynamic random access memory (SDRAM) dual inline memory modules (DIMMs) installed and supports up to 256 MB of memory.
The memory sockets on the system board can be populated with 8-, 16-, 32-, 64-, or 128-MB DIMMs. Self-refresh DIMMs are required.
For proper system operation, the DIMMs must be industry standard 168-pin, 100-MHz or faster, unbuffered SDRAM DIMMs. The SDRAM DIMMs must support CAS Latency 2 or 3 (CL = 2 or CL = 3). They must also contain the mandatory Joint Electronic Device Engineering Council (JEDEC) Serial Presence Detect (SPD information. DIMMs constructed with x4 SDRAM are not supported; the system will not start using unsupported DIMMs.
If your system processor has a bus speed of 66 MHz, Compaq recommends that any additional DIMMs also be 66 MHz. If the system bus speed is 100 MHz, the use of 100-MHz DIMMs is required.
See mälu ei sobi seega kindlalt? st. proovisin ja ei töötanud.
http://www.valueram.com/datasheets/KVR133X64C3_128.pdf
Viitsib keegi maakeeli ära seletada, milline see sobiv mälu olema peaks? icon_smile.gif
HDD
HDD
sõnum 19.01.2004 23:37:12 vasta tsitaadiga
Noo see plaat toetab DIMM mälusid aga neid ei ole enam myygil.
Aga kasutatud peaks saama veel...
The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it icon_smile.gif
Kommentaarid: 62 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
pppp
sõnum 20.01.2004 11:52:55 Re: Aidake leida sobivat mälu ühele Compaq-ile vasta tsitaadiga
Nii. Proovime siis inimest natuke aidata ka.
bladerunner kirjutas:
Ehk viitsid selle Deskpro mudelinumbri ka siia visata - teeb ehk aitamise vähe lihtsamaks.
Millest seda järeldad?
Muidu pakuks, et 8 (või ka 16) kiviga 128 MB DIMM-id võiksid sellised olla, mis töötavad. Ning 16 kiviga 256 MB isendid. Ja mälud võiksid mingi vähe korralikuma tootja omad olla (see peaks välistama selle, et mingi x4 kividega DIMM-i saad).
sõnum 20.01.2004 15:31:22 Re: Aidake leida sobivat mälu ühele Compaq-ile vasta tsitaadiga
pppp kirjutas:
Täpne mudel on Compaq DeskPro SFF 6300/3.2. Peale Compaq-HP ühinemist on nende web paras segapudru. Selle mälu kohta käiva jutu kaevasin siiski välja.
pppp kirjutas:
Jäi nagu kusagilt otsingust silma, võin muidugi ka eksida.
pppp kirjutas:
Nojah, eks ma siis otsin. See Kingston mille lingi ma panin oligi siis x4? icon_rolleyes.gif
pppp
sõnum 20.01.2004 16:36:16 Re: Aidake leida sobivat mälu ühele Compaq-ile vasta tsitaadiga
No siis peaks mälude osas see minu eelmises postituses kirjas olev jutt enam-vähem kehtima (nende väikeste kastide slot1 plaadid peaks kõik BX chipsetiga olema). Võin muidugi igaks juhuks õhtul üle ka kontrollida (endal vedeleb ka üks selline pisike Compaq kodus; mälu pole sinna siiani rohkem kui 64 MB sisse pannud.)
Loe üle, mitu mälukivi DIMM-i peal on.
Eip. x4 kivisid peab ühe DIMM-i peal kokku 16 olema, et 64 bitti (mälusiini laius) kokku saada. Too Kingston paistis x16 (128 Mbit mahuga) kividega olevat.
sõnum 20.01.2004 18:37:46 Re: Aidake leida sobivat mälu ühele Compaq-ile vasta tsitaadiga
pppp kirjutas:
Pead ei julge anda, sest arvuti pole hetkel käepärast, aga justkui oli 4 tk kummalgi pool.
pppp kirjutas:
Sellel Kingston-l on 4 kivi ja sellega see Compaq pilti igatahes ette ei võtnud. Katsun siis leida mõne 8 kiviga isendi ja sellega proovida? icon_rolleyes.gif
pppp
sõnum 21.01.2004 02:34:05 vasta tsitaadiga
Niih. Sai siis oma Deskpro-rondile (täpset marki ei suutnudki tuvastada; igal juhul Deskpro EN SFF ta on, slot1 plaat BX chipsetiga on sees) 256MB Microni 16 mälukiviga PC133 CL2 DIMM sisse topitud. Masin tundis mälu ilusti ära ning Debian tuli üles. Rohkem ei viitsinud proovida. Küllap töötab teiste sarnaste mäludega ka.
