praegune kellaaeg 17.11.2026 23:16:04
Terror
12.03.2020 15:55:52
Väike teksti manipuleerimine exceliga |
Arduino baasil programm treipingi telgede etteandele. Excelis on kalkulaator, et arduino koodi õiged parameetrid arvutada.
Excelis saadud tulemused:
thread: Z X
0,25 45,0000 36,0000
0,3 37,5000 30,0000
0,35 32,1429 25,7143
0,4 28,1250 22,5000
Peaks saama sellisesse formaati, et oleks mugab kogu sellest tabelist copy paste teha (tabel ise on suht pikk).
{ 45, 0, 36, 0, "0.25mm", 0.250, 4, " 750rpm" },
{ 37, 5000, 30, 0, "0.30mm", 0.300, 4, " 750rpm" },
{ 32, 1429, 25, 7143, "0.35mm", 0.350, 4, " 750rpm" },
{ 28, 1250, 22, 5000, "0.40mm", 0.400, 4, " 750rpm" },
{ 21, 2665, 17, 132, "48tpi ", 0.529, 4, " 750rpm" },
Lisa nüanss: 45,0000 muutub 45, 0, 'ks, kuid 37,5000 jääb 37, 5000, 'ks. 17,0132 muutub 17, 132, 'ks.
4, " 750rpm" - sellele ei pea tähelapnu pöörama, jätame selle staatiliseks.
Alguse tegin nii: =CONCATENATE("{ ";INT(H3);" , ";H3-INT(H3)) kuid see peale komakohta õige formaat tekitab probleeme.
91 |
infidel
12.03.2020 16:34:36
Eeldusel, et veerud on A, B ja C:
| vb:
="{ "&VALUE(LEFT(B1;FIND(",";B1)-1))&", "&VALUE(RIGHT(B1;LEN(B1)-FIND(",";B1)))&", "&VALUE(LEFT(C1;FIND(",";C1)-1))&", "&VALUE(RIGHT(C1;LEN(C1)-FIND(",";C1)))&", "&CHAR(34)&TEXT(A1;"0.00")&"mm"&CHAR(34)&", 4, "&CHAR(34)&"750rpm"&CHAR(34)&" },"
| Kommentaarid: 36 loe/lisa |
Terror
13.03.2020 08:02:15
TEXT(A1;"0.00") annab #VALUE! errori. Kui regiooniliselt on komakohaks "," mitte "." excelis, siis vist ei saagi seal formaadis seda punktiga asendada nii?
Susserdasin muidu vist töötava lahenduse kokku: =CONCATENATE("{ ";INT(H3);", ";ROUND((H3-INT(H3))*10000;0);", ";INT(I3);", ";ROUND((I3-INT(I3))*10000;0);", """&INT(G3)&"."&ROUND((G3-INT(G3))*100;0);"mm""";", "; ""&INT(G3)&"."&ROUND((G3-INT(G3))*1000;0);", ";"4, ";CHAR(34)&" 750rpm"&CHAR(34);" },")
91 |
infidel
13.03.2020 11:40:38
Kui annab errori, siis niimoodi:
| vb:
="{ "&VALUE(LEFT(B1;FIND(",";B1)-1))&", "&VALUE(RIGHT(B1;LEN(B1)-FIND(",";B1)))&", "&VALUE(LEFT(C1;FIND(",";C1)-1))&", "&VALUE(RIGHT(C1;LEN(C1)-FIND(",";C1)))&", "&CHAR(34)&SUBSTITUTE(TEXT(A1;"0,00");",";".")&"mm"&CHAR(34)&", 4, "&CHAR(34)&"750rpm"&CHAR(34)&" },"
