praegune kellaaeg 24.10.2026 15:39:46
Maximus_991
11.01.2004 21:54:30
Raleka |
| Kuidas kõrvaldada arvutist Raleka w32.HLLW uss-viirus, NAV 2003 leiab, aga ei kõrvalda. Mis programm seda teeks???
| Kommentaarid: 8 loe/lisa |
aX
11.01.2004 22:08:41
| updated äkki ära nortoni ?
84 |
Maximus_991
12.01.2004 01:32:22
kõik up- dated on tehtud...aga ikka ei aita (
darzik
12.01.2004 01:36:45
| loe symanteci lehelt.. minuarust võis need viiruseks tunnistatud failid ära kustutada lihtsalt. Kindlalt ei mäleta ja otsida ei viitsi.
| Kommentaarid: 73 loe/lisa |
Raiku
12.01.2004 09:41:51
http://securityresponse.symantec.com/avcenter/venc/data/w32.hllw.raleka.html
3. Scanning for and deleting the infected files
Disconnect the computer from all external sources. This includes local area networks and all internet connections.
Start your Symantec antivirus program and make sure that it is configured to scan all the files.
For Norton AntiVirus consumer products: Read the document, "How to configure Norton AntiVirus to scan all files."
For Symantec AntiVirus Enterprise products: Read the document, "How to verify that a Symantec Corporate antivirus product is set to scan all files."
Run a full system scan.
If any files are detected as infected with W32.HLLW.Raleka, click Delete.
_________________ Честных психов можно не лечить... |
| Kommentaarid: 58 loe/lisa |
45 |
