praegune kellaaeg 25.11.2026 23:57:33
riaak
14.11.2019 16:01:54
Ubiquiti ERX ja OpenVPN+Wireguard sild? |
Mitmele erinevale seadmele vaja saada kontori IP. Ligipääs kontori võrgule on antud üle OpenVPN, aga korraga saab ainult üks klient olla ühendatud. Kuna seadmeid, mida sinna ühendada tahan on tundmatu kogus, siis jääb välja võrguhalduri käest lisa ligipääsude küsimine.
Hankisin koju ERX ruuteri ning seadsin sinna üles Wireguard serveri (wg0, 192.168.33.0/24). Ühtlasi seadistasin OpenVPN kliendi (vtun0). Puudulik on ilmselt ruutimine, sest Wireguard ise töötab, OpenVPN saab ka endale IP, aga üheskoos nett läbi ei käi.
Ruutimise reeglid sain siit ja kohandasin natukene enda jaoks.
set service nat rule 5000 description PIA
set service nat rule 5000 log disable
set service nat rule 5000 outbound-interface vtun0
set service nat rule 5000 source address 192.168.33.0/24
set service nat rule 5000 type masquerade
set protocols static table 1 interface-route 0.0.0.0/0 next-hop-interface vtun0
set firewall modify pia_route rule 10 description 'PIA'
set firewall modify pia_route rule 10 source address 192.168.33.0/24
set firewall modify pia_route rule 10 modify table 1
set interfaces switch wg0 firewall in modify pia_route |
Liiklus välja justkui läheb, tagasi ei tule.
Lisan Ubi enda conf faili ka.
firewall {
all-ping enable
broadcast-ping disable
ipv6-name WANv6_IN {
default-action drop
description "WAN inbound traffic forwarded to LAN"
enable-default-log
rule 10 {
action accept
description "Allow established/related sessions"
state {
established enable
related enable
rule 20 {
action drop
description "Drop invalid state"
state {
invalid enable
ipv6-name WANv6_LOCAL {
default-action drop
description "WAN inbound traffic to the router"
enable-default-log
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
rule 30 {
action accept
description "Allow IPv6 icmp"
protocol ipv6-icmp
rule 40 {
action accept
description "allow dhcpv6"
destination {
port 546
protocol udp
source {
port 547
ipv6-receive-redirects disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
modify pia_route {
rule 10 {
action modify
description PIA
modify {
table 1
source {
name WAN_IN {
default-action drop
description "WAN to internal"
rule 10 {
action accept
description "Allow established/related"
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
name WAN_LOCAL {
default-action drop
description "WAN to router"
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
description WireGuard
destination {
port 51820
protocol udp
state {
invalid enable
send-redirects enable
source-validation disable
syn-cookies enable
interfaces {
ethernet eth0 {
description Internet
duplex auto
speed auto
ethernet eth1 {
description Local
duplex auto
speed auto
ethernet eth2 {
description Local
duplex auto
speed auto
ethernet eth3 {
description Local
duplex auto
speed auto
ethernet eth4 {
description Local
duplex auto
poe {
output off
speed auto
loopback lo {
openvpn vtun0 {
config-file /home/ubnt/mobi.openvpn.client.ovpn
switch switch0 {
description Local
mtu 1500
switch-port {
interface eth0 {
vlan {
pvid 1
vid 4
interface eth1 {
vlan {
pvid 4
interface eth2 {
vlan {
pvid 2
interface eth3 {
vlan {
pvid 2
interface eth4 {
vlan {
pvid 2
vlan-aware enable
vif 1 {
address dhcp
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
vif 2 {
address 192.168.1.1/24
description Local
vif 4 {
description IPTV
mtu 1500
wireguard wg0 {
description "WG VPN"
firewall {
in {
modify pia_route
listen-port 51820
peer kgR0d7bNR3ZPKXNWXCGGuAQrwdZZFg+PaAPY4y3zogE= {
allowed-ips 192.168.33.2/24
description U1
peer rc+qYkTQyFhtRFd1XetEoHUhTLDl+c7uicE2T0Kld0I= {
allowed-ips 192.168.33.3/24
description U2
private-key /config/auth/wg.key
route-allowed-ips true
protocols {
static {
table 1 {
interface-route 0.0.0.0/0 {
next-hop-interface vtun0 {
service {
dhcp-server {
disabled false
hostfile-update disable
shared-network-name LAN {
authoritative enable
subnet 192.168.1.0/24 {
default-router 192.168.1.1
dns-server 1.1.1.1
lease 86400
start 192.168.1.38 {
stop 192.168.1.243
static-arp disable
use-dnsmasq disable
dns {
forwarding {
cache-size 150
listen-on switch0.2
name-server 1.1.1.1
gui {
http-port 80
https-port 443
older-ciphers enable
nat {
rule 5000 {
description PIA
log disable
protocol all
source {
type masquerade
rule 5010 {
description "masquerade for WAN"
log disable
outbound-interface switch0.1
protocol all
type masquerade
ssh {
port 22
protocol-version v2
system {
host-name ubnt
login {
user ubnt {
authentication {
encrypted-password $1$zKNoUbAo$gomzUbYvgyUMcD436Wo66.
level admin
ntp {
server 0.ubnt.pool.ntp.org {
server 1.ubnt.pool.ntp.org {
server 2.ubnt.pool.ntp.org {
server 3.ubnt.pool.ntp.org {
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone UTC
traffic-analysis {
dpi disable
export disable
/* Warning: Do not remove the following line. */
/* === vyatta-config-version: "config-management@1:conntrack@1:cron@1:dhcp-relay@1:dhcp-server@4:firewall@5:ipsec@5:nat@3:qos@1:quagga@2:suspend@1:system@4:ubnt-pptp@1:ubnt-udapi-server@1:ubnt-unms@1:ubnt-util@1:vrrp@1:webgui@1:webproxy@1:zone-policy@1" === */
/* Release version: v2.0.6.5208541.190708.0508 */
_________________ ¯\_(ツ)_/¯ |
105 |
