praegune kellaaeg 07.11.2026 17:55:47
ykshuntka
02.09.2019 18:03:33
Printeri HP Laser MFP 135a tööle häälestamine |
Tere.
Ei oska printerit õigesti tööle seadistada.
Hetkel prindib mingeid sümboleid.
Mageia 6 ja HP Laser MFP 135a USB kaabliga.
HPLIP-3.19.5 ei leia ühtegi seadet.
CUPS saab aru, et tegu on HP_Laser_MFP_131_133_135-138
kasutab valet draiverit, sest nimekirjas õiget ei ole:
Description: HPprinter
Driver: HP 910, hpcups 3.19.5 (color, 2-sided printing)
Connection: usb://HP/Laser%20MFP%20131%20133%20135-138?serial=CNB3M429KW&interface=1
Defaults: job-sheets=none, none media=iso_a4_210x297mm sides=two-sided-long-edge |
CUPS jaoks PPD faili?
HP koduleht pakub sellele printerile kõigile Linux versioonidele ühte faili: Link
Kas jooksutada seda skripti?
Mida veel proovida?
usb-devices
Bus=02 Lev=01 Prnt=01 Port=03 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=03f0 ProdID=f22a Rev=01.00
S: Manufacturer=HP Inc.
S: Product=HP Laser MFP 135a
S: SerialNumber=CNB3M429KW
C: #Ifs= 3 Cfg#= 1 Atr=c0 MxPwr=2mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 1 Alt= 0 #EPs= 2 Cls=07(print) Sub=01 Prot=02 Driver=usblp
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=04 Prot=01 Driver=(none)
lsusb
Bus 002 Device 004: ID 03f0:f22a Hewlett-Packard
hp-makeuri 03f0:f22a
HP Linux Imaging and Printing System (ver. 3.19.5)
Device URI Creation Utility ver. 5.0
Created directory: /var/lib/net-snmp
Created directory: /var/lib/net-snmp/mib_indexes
error: Device not found
lpinfo -v
network ipps
network https
network lpd
network beh
network http
network socket
network ipp
direct usb://HP/Laser%20MFP%20131%20133%20135-138?serial=CNB3M429KW&interface=1
direct hp
direct hpfax
| Kommentaarid: 54 loe/lisa |
48 |
kaabakas
02.09.2019 22:24:21
Ppd failid on sinu lingitud zipis ju ometi olemas. Kas nendest piisab, on omaette küsimus - seal on ka mingi .so pudi jms, mis võib tähendada et nad on mingi oma aretise teinud, et sitem oleks. Sel juhul, jah, jooksutad skripti.
96 |
ykshuntka
03.09.2019 11:07:54
Tänan.
Sain tööle printimise ja skaneerimise
Ise ei märganud seda PPD faili.
Üritasin faili kasutada, aga CUPS viskas rastertospl faili ei leia.
Selle HP zip seest leidsin ka rastertospl faili, aga CUPS ei teinud midagi: Idle - "Rendering completed"
Lõin install-printer.sh ja install-scanner.sh käima(tahtsid root õigusi )
pakkus tulemüüri seadistust - keeldusin
CUPS printeri listi ilmus juurde HP_Laser_MFP_13x
48 |
