uus teema   vasta Hinnavaatlus »  Kasulikud näpunäited »  MSN Messengeri lingid märgi kõik teemad loetuks
Taavi_R
Taavi_R
sõnum 04.01.2004 12:14:32 MSN Messengeri lingid vasta tsitaadiga
http://users.pandora.be/heavyk/ - Patch, mille abil saab sisse logitud olla mitu kasutajat.
Siia alla võite lisada veel linke...
raamatupidamine | laadakalender
Kommentaarid: 186 loe/lisa Kasutajad arvavad:  :: 2 :: 3 :: 166
Jägermeister
sõnum 04.01.2004 12:53:07 vasta tsitaadiga
KAhjuks on need patchid vananenud. icon_sad.gif MSN on juba versiooninumbriga 6.1 ja need patchid ei tööta icon_sad.gif aga seda Polygami asja kasutaks igatahes, kui töötaks.
Kommentaarid: 23 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 23
MatiKala
sõnum 04.01.2004 12:57:50 vasta tsitaadiga
link :: Kliki siia
Terve leht pühendatud sellele ju...
Kommentaarid: 28 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 25
ksl
sõnum 04.01.2004 13:05:37 vasta tsitaadiga
http://www.oxygen-inc.com/files/msn61207.exe on vähe uuem versioon ja lisanduvad veel erinevad skin'id.
tegija Amnesia juttu ka ühest foorumist
Update of the last MSN Skinner:
Some of you may be a familiar with a little add-on pack called Windows-X.
Now before running at the sight of 'windows' hang on a second.
ALOT of people have been asking The Unknown for mods of his msn skins since the update of MSN Messenger to 6.1.0207. It seems like they've done this in order to simply deter skinners and patchers from creating stuff.
Little do they know that WE DONT GIVE UP!
So.... the point is I host Windows-X as a mirror and here is a link.
Uninstall your msn messenger and then reinstall using the download I've provided.
You'll be given a HUGE amount of skins to choose from. INCLUDING "The Unknowns" skin, (credit given to him of course within Installer and next to his skin)!
The skins include a WHOPPING FOUR MAC Styled Skins THREE aqua-styled skins, and a rather neat idea of a 'Glass' MSN, where the windows look transparent and glassy. (Entitled Clean MSN)
So enjoy the download. I'll post updates to the download should MSN Messenger update yet again.
Now you guys dont need to bother
Oh and if you have a complete skin, let me know, and I'll try to get it into the Windows-X pack.
SCREENSHOTS
OSX http://www.oxygen-inc.com/images/msnskins/unknownosx.jpg
Clear http://www.oxygen-inc.com/images/msnskins/clear.jpg
ISWAG http://www.oxygen-inc.com/images/msnskins/iswag.jpg
Xero's Aqua http://www.oxygen-inc.com/images/msnskins/aqua.jpg
Jab's Aqua http://www.oxygen-inc.com/images/msnskins/jabaqua.jpg
Penguin http://www.oxygen-inc.com/images/msnskins/penguin.jpg
Futuristic http://www.oxygen-inc.com/images/msnskins/futuristic.jpg
Urban http://www.oxygen-inc.com/images/msnskins/urban.jpg
DarkShade http://www.oxygen-inc.com/images/msnskins/darkshade.jpg
There are other skins, but they are either simple mods or I couldn't be bothered lol. Plus I didn't make the screens look super cool as they probably will look better on your desktop.
NOTE:
You do NOT have to uninstall in order to try another skin. Simply run the installer and choose repair. It will give you the option to change the skin
NOTE2 UPDATE:
Alright all this is the update so that it works with the latest version of messenger. It includes Unknowns BRUSHED MSN, which alot of you I've noticed have been asking for, so thanks to WindowsX you've got it. It has additional themes such as Bubble, Zelda, etc.. So you'll be happy messing around to your hearts content.
Enjoy
http://oxyx.oxygen-inc.com/
KES SOOVIB, SEE PROOVIB
kakuke
sõnum 15.01.2004 19:01:44 vasta tsitaadiga
üks suurimaidKui sealt valida downloads, siis saad igast abiprogramme väega palju... =) be häppi
Kommentaarid: 18 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 14
thunder1
thunder1
sõnum 10.03.2004 00:58:19 vasta tsitaadiga
http://messengertricks.tk
igasugu stuffi...ka polygami
4rvut
sõnum 12.03.2004 19:49:26 vasta tsitaadiga
www.mess.be <- sealt otsige INFOPEN ning saate msn messengeris joonistada ning saata pilte vestluse ajal teistele. kuigi piiratud kasutusega ning see versioon mis seal oli oli vist 30days try'al kuid proovida tasub. õpris huvitav asjake thumbs_up.gif icon_lol.gif
O: a-open supertower h600A küljekaane icon_smile.gif võtta privas ühendust!
MelesMeles
sõnum 15.03.2004 01:02:13 vasta tsitaadiga
http://www.msgplus.net/index.php?view=news#4926326026 thumbs_up.gif saab msn's pilte joonistada
Allkiri
Kommentaarid: 268 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 194
Lemmy
sõnum 10.10.2006 18:20:04 Show song information vasta tsitaadiga
Kuidas panna MSN või WLM näitama Winamp'ist loo nime, ilma uue Media Playeri installimiseta.
1. Lasta Winamp'ile gen_msn.exe plugin. Sättida Winampis selle settingud. Winamp kinni.
2. Messenger kinni. Regedit. Avada registry's:
HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger\PerPassportSettings\<*user ID*>\ShowTransientPSM
ja muuta HEX väärtus: 1'ks.
Regedit kinni.
3. Avada Messenger, logida sisse, avada Winamp, panna mängima.. ja peakski olemas olema.
Plugin ja sama jutt üleval siin.
Vähem möla, pikem samm!
muda
muda
sõnum 22.10.2006 17:38:40 vasta tsitaadiga
WinAmpi plugin et MSN näitaks loo nime
http://www.xs4all.nl/~whaa/messengeramp/index.html
MSN patch multi login msn 7.5
http://www.mastaline.com/?pagina=msn/downloadinfo&id=45
-XD-
-XD-
sõnum 25.10.2006 08:49:28 vasta tsitaadiga
http://www.emol.silver.pri.ee/messenger/ - uuendused, lisad jne.
Kommentaarid: 114 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 103
Freeway
sõnum 25.10.2006 18:22:37 vasta tsitaadiga
-XD- kirjutas:
http://www.emol.be/messenger/ - uuendused, lisad jne.
Cheetah
Cheetah
sõnum 02.12.2006 15:19:26 vasta tsitaadiga
http://customizeyourmsn.com icon_rolleyes.gif
Kommentaarid: 91 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 84
DeCoder
DeCoder
sõnum 05.12.2006 13:03:54 vasta tsitaadiga
Kommentaarid: 34 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 31
tiirP
tiirP
sõnum 28.02.2007 10:01:25 vasta tsitaadiga
Messenger stuff
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 107
