uus teema   vasta Raud »  Protsessorid »  Pentium 3 (368Mhz) kolokkamine märgi kõik teemad loetuks
birgit123
birgit123
sõnum 15.01.2004 17:50:57 Pentium 3 (368Mhz) kolokkamine vasta tsitaadiga
mure siis järgmine kuna segastel põhjustel oli vaja panna kogu system default'iks siis avastasin et mu arvuti klokatud
nii tegemist on siis
Processor
Model : Intel® Pentium® III
Speed : 368MHz
Performance Rating : PR442 (estimated)
Type : Standard
Package : SECC(2) Slot1 Cartridge
Rated Speed/FSB : 550MHz / 1x 100MHz
Multiplier : 11/2x
Generation : G6
Name : P6K (Katmai) Pentium III 450-600MHz 2-2.05V
Revision/Stepping : 7 / 3 (0)
Stepping Mask : kC0
Microcode : MU06730E
Core Voltage Rating : 2.050V
Maximum Physical / Virtual Addressing : 36-bit / 32-bit
Serial Number : 0000-0673-0003-2EBE-1413-7A77
Mainboard
Bus(es) : ISA AGP PCI USB i2c/SMBus
MP Support : No
MP APIC : No
System BIOS : Award Software International, Inc. 6.00 PG
Mainboard : <<http:\\www.abit.com.tw>> I440BX-W977(BE6-II v1.1 / BF6)
Total Memory : 127MB SDRAM
Chipset 1
Model : Intel Corporation 82443BX/ZX 440BX/ZX CPU to PCI Bridge (AGP Implemented)
Front Side Bus Speed : 1x 67MHz (67MHz data rate)
Total Memory : 128MB SDRAM
Memory Bus Speed : 1x 67MHz (67MHz data rate)
Video System
Monitor/Panel : Plug and Play Monitor
Adapter : Matrox Graphics Millennium G200 AGP
Imaging Device : Hewlett-Packard ScanJet 2200C #2
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : ST340014A
CD-ROM/DVD : BTC BCE2410IM
CD-ROM/DVD : V386 STEALTH DVD SCSI CdRom Device
Logical Storage Devices
1.44MB 3.5" (Aicon_smile.gif : N/A
Hard Disk (Cicon_smile.gif : 9.8GB (5.0GB, 51% Free) (FAT32)
Hard Disk (Dicon_smile.gif : 27.5GB (3.0GB, 11% Free) (FAT32)
Audio cd (Eicon_smile.gif : 0MB (0MB, 0% Free) (CDFS)
CD-ROM/DVD (Ficon_smile.gif : N/A
Peripherals
Serial/Parallel Port(s) : 2 COM / 1 LPT
USB Controller/Hub : Intel® 82371AB/EB PCI to USB Universal Host Controller
USB Controller/Hub : USB Root Hub
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : PS/2 Compatible Mouse
MultiMedia Device(s)
Device : ES1869 Control Interface (WDM)
Device : ES1869 Plug and Play AudioDrive (WDM)
Device : Standard Game Port
Printers and Faxes
Model : Lexmark Z23/Z33 Color Jetprinter
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600
Network Services
Network Drivers Enabled : Yes
Adapter : Realtek RTL8139/810x Family Fast Ethernet NIC
biosist avastasin veel sellised asjad
CPU Operating Frequency 233/66
(mida saab muuta
266/66
333/66
300/66
300/100
350/100
400/100
450/100
433/100
466/100
533/66
566/66 ) (neid nr saab ainult muuta )
CPU FSB Clock /(Mhz) 66
CPU Multiplier Factor x 3.5
Sel 100/66# signed default
Mul oleks vaja uuesti prose kuidagi 550 jooksma saada või 600 Mhz peal , see nagu ma olen aru saanud maksimum.. ise ei oska ja keegi tuttavatest ka ei oska kuna see niivõrd vana protsessor
Ise ei julgenud kohe käisi kylge toppida seega ootan teilt mõistvat suhtumist ja näpunäiteid icon_smile.gif
Kommentaarid: 94 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 80
tomz
tomz
sõnum 15.01.2004 18:49:09 vasta tsitaadiga
siin vast mingi segadus... default ikka 550MHz aga antud juhul sama asi nagu näiteks minu bartoniga, mis peale clear cmos läheb 1100MHz peale. 368MHz p3 ei anna ju mingil juhul 550MHz peale kellata või mis.
sant
sõnum 15.01.2004 18:54:36 vasta tsitaadiga
Imelik jutt,ma saan aru,et cpu jookseb aeglasema kiiruse peal?(downclokitud).Aga need P3 protsessorid hakkavad ju 450-est mhz-ist pihta.
Craft
sõnum 15.01.2004 18:56:37 vasta tsitaadiga
See on sul kuidagi FSB 66 peale läinud. Tegelikult on su protsessor 5.5x100 ehk 550MHz. Tõsta fsb 100 peale ja saadki defaulti + palju kiiremaks.
Kommentaarid: 41 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 39
sant
sõnum 15.01.2004 19:23:11 vasta tsitaadiga
Jajah,kasutaja Craftil on õigus: 5,5*66=363mhz ja 5,5*100=550mhz icon_wink.gif
Pane oma fsb 100mhz peale,siis peaks kõik korras olema.
sõnum 15.01.2004 19:56:33 vasta tsitaadiga
birgit123
birgit123
sõnum 15.01.2004 22:32:00 vasta tsitaadiga
hea öelda aga kuidas ma seda teostan kuna mina küll biosist sellist asja
see osa väga keeruline mida ma manualist leidsin
We strongly suggest that you use our default settings for each processor speed when you
want to configure your CPU settings. We meticulously and repeatedly test these default
settings. Adopting these settings will give you the optimum system for stability. The
following table lists all of the CPU default settings.
CPU Speed FSB Clock PCI Clock / CPU FSB Clock AGP Clock / CPU FSB Clock
233 66 1/2( 33 ) 1/1 (66)
266 66 1/2 ( 33 ) 1/1 (66)
300 66 1/2 ( 33 ) 1/1 (66)
333 66 1/2 ( 33 ) 1/1 (66)
300 100 1/3 (33.3) 2/3 (66.67)
350 100 1/3 (33.3) 2/3 (66.67)
400 100 1/3 (33.3) 2/3 (66.67)
450 100 1/3 (33.3) 2/3 (66.67)
366 66 1/2 ( 33 ) 1/1 (66)
400 66 1/2 ( 33 ) 1/1 (66)
433 66 1/2 ( 33 ) 1/1 (66)
466 66 1/2 ( 33 ) 1/1 (66)
500 66 1/2 ( 33 ) 1/1 (66)
533 66 1/2 ( 33 ) 1/1 (66)
533 133 1/4 (33.25) 2/3 (88.67)
500 100 1/3 (33.33) 2/3 (66.67)
550 100 1/3 (33.33) 2/3 (66.67)
600 100 1/3 (33.33) 2/3 (66.67)
600 133 1/4 (33.25) 2/3 (88.67)
650 100 1/3 (33.33) 2/3 (66.67)
667 133 1/4 (33.25) 2/3 (88.67)
700 100 1/3 (33.33) 2/3 (66.67)
750 100 1/3 (33.33) 2/3 (66.67)
800 100 1/3 (33.33) 2/3 (66.67)
733 133 1/4 (33.25) 2/3 (88.67)
800 133 1/4 (33.25) 2/3 (88.67)
pppp
sõnum 16.01.2004 00:56:05 vasta tsitaadiga
birgit123 kirjutas:
Kui BIOS-i sisse lähed, siis vasakult esimene peaks kohe olema Softmenu III Setup. Seal alt peaks saama kõik vajaliku paika panna.
sant
sõnum 16.01.2004 01:16:13 vasta tsitaadiga
Selle peadki valima: 550 100 1/3 (33.33) 2/3 (66.67)
birgit123
birgit123
sõnum 17.01.2004 01:02:19 vasta tsitaadiga
sant kirjutas:
suur aitähh sulle sain asja korda teema võib lukku panna kui siin selline asi olemas icon_wink.gif
