praegune kellaaeg 16.11.2026 19:06:36
blackrider
13.02.2019 17:35:56
Kõlar "mürtsub" kui võim sisse/välja lülitada |
Saatsin selle probleemiga võimendi remonti. Öeldi, et see on korras. Kas on võimalik, et kõlaritel on midagi viga?
Kõlarid Dali 6006
Võim NAD 3020i
_________________ ämmaemand keevitaja |
| Kommentaarid: 4 loe/lisa |
Wordmc9
13.02.2019 18:43:47
see tuleb ikka võimendist, soft start ei toimi või puudub
googleda seda
| Kommentaarid: 346 loe/lisa |
287 |
13.02.2019 20:10:42
Siin sama probleemi üle arutletud. Ehk siis viga on võimendis kinni. Kõlar ilma võimendita ei liiguta oma membraani ise kuidagi kohe.
http://audiokarma.org/forums/index.php?threads/nad-3020-power-on-thump.576089/
http://www.audiokarma.org/forums/index.php?threads/nad-3020-thoughts.200084/
ja täpsemalt.
I've recapped / rebuild several 3020's, including the A/B models, and can confirm that your 3020A does have the muting circuit (that's where the red/white wires on the front section of the power switch go to), although I doubt that the FET muting is the problem.
I suspect you probably have a worn/dirty mains switch, which is likely arcing when you turn the unit off. Have you tried just turning the amp off at the mains socket where it's plugged in ? If you don't get the loud pop, then it's switch related. Solution would be to replace the switch (if possible), or more likely to completely remove, strip, and clean / replace the switch contacts - it's quite fiddly, but can be done. I think there's a detailed procedure somewhere on the Audiokarma forum. Replace the 2 suppression caps in your photos at the same time - as Ian said, they're to suppress arcing within the switch, and are likely to be worn after 23 - 30 years use.
Do you also experience any loud 'thump' (or other noises) when you turn the unit on ? if so, it sounds like it's due for recapping and a good overhaul generally.
Finally, if you need detailed schematics or help with it, feel free to pm me (I'm in S. Lincs.). |
https://www.diyaudio.com/forums/solid-state/178436-nad-3020a-loud-pop-switch-3.html?s=0322d93f23634ad4cc18b969dd6a10ac
131 |
blackrider
14.02.2019 15:56:20
Tänan info eest!
Kuna mürtsub nii sisse- kui ka välja lülitades, tellisin recap kit-I ning kavatsen suurema tinutamise ette võtta
