praegune kellaaeg 13.11.2026 19:36:25
Markspoiss
10.08.2018 13:22:52
Soovin abi koodiga (arduino uno) temp sensor ja 4 digit display |
Tere!
Olen arduino maailmas alles täielik võhik. Üksikult suudan need netiust allalaetud koodid kuvama panna neid vigureid mida vaja aga muuta ja kokku kompunnida veel ei oska.
Leidsin siis sellise asja:
#include <dht.h>
#include "TM1637.h"
//{0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
//0~9,A,b,C,d,E,F
#define dht_pin 2 // Pin sensor is connected to
#define CLK 3//Pins for TM1637
#define DIO 4
TM1637 tm1637(CLK,DIO);
dht DHT;
void setup(){
tm1637.init();
tm1637.set(BRIGHT_DARKEST);
//BRIGHT_TYPICAL = 2,BRIGHT_DARKEST = 0,BRIGHTEST = 7;
delay(500);
void loop(){
DHT.read11(dht_pin);
int temp = DHT.temperature;
int humidity = DHT.humidity;
int digitoneT = temp / 10;
int digittwoT = temp % 10;
int digitoneH = humidity / 10;
int digittwoH = humidity % 10;
tm1637.display(1,digitoneT);
tm1637.display(2,digittwoT);
tm1637.display(3,12); // put a C at the end
delay (3000);
tm1637.display(1,25);
tm1637.display(2,digitoneH);
tm1637.display(3,digittwoH);
//Wait 3 seconds before accessing sensor again.
//Fastest should be once every two seconds.
delay(3000);
aga mul on see senosor teine:
kood käivitamiseks selline:
// First we include the libraries
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
// start serial port
Serial.begin(9600);
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print(" Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperature readings
Serial.println("DONE");
Serial.print("Temperature is: ");
Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
// You can have more than one DS18B20 on the same bus.
// 0 refers to the first IC on the wire
delay(1000);
ühesõnaga sooviksin esimeses skriptis ajsa ära muuta nii, et mulle kuvatakse temp sinna 4 digit display peale.
Tänan!
