7 :: |
364 |
arny
04.10.2018 16:52:46
ei lugenud välja, et kust ta neid faile kustutab. Kas ainult user/kasutaja kaustast või kogu süsteemist, mis tundub ebaloogiline, et teiselt kettalt peaks asju kustutama. Kui ainult user/kasutaja kausta alt siis neid inimesi vist palju ei ole kes olulisi asju süsteemi driveiga ühes hoiab.
| Kommentaarid: 11 loe/lisa |
10 |
.:MDK:.
04.10.2018 17:21:26
| arny kirjutas: |
| ei lugenud välja, et kust ta neid faile kustutab. Kas ainult user/kasutaja kaustast või kogu süsteemist, mis tundub ebaloogiline, et teiselt kettalt peaks asju kustutama. Kui ainult user/kasutaja kausta alt siis neid inimesi vist palju ei ole kes olulisi asju süsteemi driveiga ühes hoiab. |
Haha, enamus inimesi just seal hoiabki.
_________________ Experience is gained immediately after it is needed. |
96 |
posthuman
04.10.2018 17:22:57
| tekkis täpselt sama küsimus, et kust need failid kustutatakse. variante ju üüramatuma palju. desktop, useri default kaustad "my picutures" jne (seal vist tõesti 99% inimestest midagi ei hoia), kogu "c" ketta sisu või siis jah koguni juba teised füüsilised kõvakettad?
| Kommentaarid: 69 loe/lisa |
67 |
04.10.2018 17:24:48
https://www.reddit.com/r/Windows10/comments/9l128k/warning_1809_upgrade_misplaceddeleted_files_in/
Yesterday evening I was checking Windows Update to see if 1809 was available. It wasn't. So being the tech savy and impatient person I am I decided to use the upgrade assistant instead. I downloaded the assistant and it started downloading. When i woke up this morning the download AND the install had finished (might be a bit scary to some, but okay - I was going to upgrade anyway).
I then proceeded to go about my daily routine. Upon opening my music mixing program I noticed something strange. Some of the packaged content had disappeared and so had my user library. Upon further inspection of the containing folders ("C:\Users\Public\Documents" and "C:\Users\<user>\Documents") the files had suddenly completely vanished. On a side-note my user folders ("Desktop", "Documents", "Downloads", etc) have all been moved to my secondary drive by changing their "locations" in their properties.
I went a'Googling and tried the usual suspects. I checked "C:\Windows.old\Users" and even tried to read some upgrade logs in "C:\Windows\Panther". The migration log (or "MisLog.xml") mentioned some of the files and folders missing, pointing directly to the files and folders original paths. |
7 :: |
364 |
211 |
posthuman
04.10.2018 20:46:58
olgu, siis õnneks kõik hästi kõigil
67 |
maddog
04.10.2018 21:43:36
Ma just üpris kindel et 99% tava kasutajatest just hoiavad seal oma asju. Köik kes ei ole osavad HV kasutajad.
| Kommentaarid: 25 loe/lisa |
24 |
LKits
| Kommentaarid: 13 loe/lisa |
sama123
05.10.2018 04:55:34
Kas juba väljas?
Ja nagu ikka (kui ei viitsi jamada) siis vägisi surub peale?
| Kommentaarid: 23 loe/lisa |
22 |
05.10.2018 07:02:39
| sama123 kirjutas: |
Kas juba väljas?
Ja nagu ikka (kui ei viitsi jamada) siis vägisi surub peale? |
On väljas ning on ka kenasti MS-i enda Download-keskusest allalaetavad.
Saadaval nii 32bit kui 64bit versioonid.
211 |
arny
05.10.2018 07:11:50
ju ma siis imelik sest pole mitte kunagi hoidnud pildi faile või dokumente süsteemikettal, alati eraldi füüsilisel kettal. See vist tulnud sellest, et ennemuiste tuli pahatihti süsteemikettale formatit teha kui väga peesse läks ja siis jäid kõigest ilma, sellest saigi hakatud asju teistel ketastel hoidma.
10 |
ehtne
05.10.2018 10:10:52
| Näen, et changelogis on "Storage Sense" uuendused mainitud. Eeldan, et too feature neid kustutabki.
| Kommentaarid: 12 loe/lisa |
d3t
05.10.2018 11:29:23
ehtne, nope. Storage sense kustutab su prügikasti ja ajutised failid. By default on väljas Download kausta kustutamine. Lisaks on option kaua aega mitte kasutatud faile OneDrive lükata ja kohalikust kettast kustutada (see on vaikimisi väljas). Lisaks eemaldab see tööriist nüüd varasema versiooni windowsist milleks enne Clean Up utiliit oli.
Enda masin on üle elanud mitmeid upgrade ja pole seda konkreetset viga kohanud. Küll aga ei saanud minu masin sysprepist mööda (esimene reboot, 42% update appling) ilma USB hubi installimise ajaks eemaldamata.
Mis puutub kustutamisesse, siis minu kõhutunne ütleb, et see on osaliselt tingitud tooli ja klaveri vahelisest errorist. Ma pole päris kindel kuidas seda uut installi nii teha, et \Users\USERNAME\OneDrive\Documents saab sinu vaikimisi folderiks kuid osadel on see õnnestunud. Nüüd kui sa otsustad seda ignoreerida ja teed nt. \Users\USERNAME\Documents kausta tagasi ja hoiad seal sees oma asju, siis upgradimise ajal loetakse su profiili konfiguratsioonist välja, et sa oled oma Documentsi liigutanud asukoha poolest OneDrive alla, seega see mis on nüüd \Users\USERNAME\Documents on mingisugune legacy pask mille võib rahuliku südamega maha lasta. Õigemini see asendatakse lingiga OneDrives olevale kaustale, et salvestamisel ja otsimisel vigu vältida. Ma ütleks, et rumal lähenemine mitte kontrollida kas seal on faile sees või mitte, kuid arendajana pakun, et bugi kusagil seal asub.
_________________ IsAiUseful.com - tee oma esimesed sammud kohaliku AI suunas
| Kommentaarid: 85 loe/lisa |
72 |
05.10.2018 12:05:20
| d3t kirjutas: |
Mis puutub kustutamisesse, siis minu kõhutunne ütleb, et see on osaliselt tingitud tooli ja klaveri vahelisest errorist. Ma pole päris kindel kuidas seda uut installi nii teha, et \Users\USERNAME\OneDrive\Documents saab sinu vaikimisi folderiks kuid osadel on see õnnestunud. Nüüd kui sa otsustad seda ignoreerida ja teed nt. \Users\USERNAME\Documents kausta tagasi ja hoiad seal sees oma asju, siis upgradimise ajal loetakse su profiili konfiguratsioonist välja, et sa oled oma Documentsi liigutanud asukoha poolest OneDrive alla, seega see mis on nüüd \Users\USERNAME\Documents on mingisugune legacy piix mille võib rahuliku südamega maha lasta. Õigemini see asendatakse lingiga OneDrives olevale kaustale, et salvestamisel ja otsimisel vigu vältida. Ma ütleks, et rumal lähenemine mitte kontrollida kas seal on faile sees või mitte, kuid arendajana pakun, et bugi kusagil seal asub. |
Igatahes - ühe kättesaamisena soovitatakse Recuva-t kasutada.
Kuid karta on, et SSD Trim korral pole seal enam midagi olemas.
How to restore your files deleted by the Windows 10 October 2018 update
https://mspoweruser.com/how-to-restore-your-files-deleted-by-the-windows-10-october-2018-update/
211 |
06.10.2018 12:36:54
Hoiatuseks:
MS võttis selle vigase 1809 maha ning asendas vanema versiooniga 1803:
211 |
Dijital
06.10.2018 14:46:08
Läksin ka siis vaatama allalaadimise lehele ja tõepoolest:
Windows 10 April 2018 Update on nüüd saadaval
Värskendusabiline Update Assistant saab teid Windows 10 uusimale versioonile värskendamisega aidata. Alustamiseks klõpsake valikut Värskenda kohe. |
| Kommentaarid: 41 loe/lisa |
arny
07.10.2018 08:06:02
Mul ühel vanal tillukesel läpakal tuli see uuendus sunniviisiliselt kui läpaka üle pika aja järgi ühendasin siis tegi oma uuenduse ära ja kõik. Ühtegi pilti ega faili mis enne restarti üle vaatasin kaustades ei kadunud kuhugi, et selles osas nagu probleeme ei ole.
10 |
| Kommentaarid: 1161 loe/lisa |
726 |
seeru
07.10.2018 10:24:35
no see beetatestija insider programm.. kui sa oma igapäevase töömasina sinna annad, pead ikka lausidioot olema.. ja netimasinates ei ole kasutaja faile rohkem kui tempkaustad. sealt ei saagi aru kui midagi puudu on..
selliste uudiste pärast ma ei panegi oma töömasinaid w10 peale: nõrgalt ei viitsi debugima hakata kui selle ajaga tööd on vaja teha.
726 |
Kristoferr
07.10.2018 11:01:59
Tänan, oli hea meeldetuletus, et tähtsatest asjadest igaks juhuks uus backup teha. Olgu see siis w10 bugi või riistvaraline probleem mis tulla võib.
Aga üldiselt ma w10'ga rahul. Igasugu probleeme on kordades vähem kui vanemate W'dega.
_________________ Liitu Z.ai coding plaaniga ja saa 10% soodust!
Liitu Wise'ga! |
| Kommentaarid: 270 loe/lisa |
220 |
libu
Aeg Maha 1k
07.10.2018 11:26:18
| Kristoferr kirjutas: |
Aga üldiselt ma w10'ga rahul. Igasugu probleeme on kordades vähem kui vanemate W'dega. |
Neid vigu tuleb veel. Ikkagi nüüd ju üks Windows 10.
seeru
07.10.2018 11:35:45
Selle ma saan seina peale kirjutada.
Sinna samma kus on:
"Pole mingit põhjust, miks igaüks peaks koju arvutit tahtma"
Ken Olson,
Digital Equipment Corp
asutaja, president
ja nõukogu esimees.
1977
olavsu1
külaline
08.10.2018 01:11:02
kuidas sa julged piiksuda, kui see asi hävitab sinu pirafaile.
| libu kirjutas: |
"HOIATUS! Windows 10 uuendus võib kustutada kasutaja faile"
Selline pealkiri peaks ju viima kliendid teise OS-i peale. |
Ettevaatust! MUG foorumis võib sellise jutueest väga kergesti bänni saada.
kurv
08.10.2018 08:06:35
| Sai ndv ka ühte arvutit uuendatud, jätsin meelega staffi alles ning peale uuendust oli kõik samal kohal.
| Kommentaarid: 28 loe/lisa |
26 |
olavsu1
külaline
08.10.2018 11:28:57
minul on siiski juhtunud, et win10 kustutab teiselt kettalt kasutajakonto varunduse.
win2k.sp4 ja win7 pole kunagi sellist nalja teinud.
Dijital
maty
| Kommentaarid: 82 loe/lisa |
7 :: |
364 |
15.10.2018 09:05:51
See tegelikult ei ole uus ega tundmatu probleem - kuna MS millalgi, vist aasta või rohkem tagasi, teatas ametlikult, et koos Redstone 5 (seesama uuendus), siis hakatakse vanemaid arvuteid "IT-turult välja viskama, nendele tuge enam mitte pakkudes".
Ja nii ka on,vähemalt osade arvutitega.
Lähipäevil läheb üks 8 aastat vana Samsung üle konkurendi-liivakasti kuna sama asi, inimestel pole praegu raha, et seda Samsungi uuema Windows 10 arvuti vastu vahetada. Ning Redstone 5 (1809) sellel vanakesel enam korralikult ei tööta.
211 |
726 |
libu
Aeg Maha 1k
15.10.2018 09:55:49
| tahanteada kirjutas: |
Lähipäevil läheb üks 8 aastat vana Samsung üle konkurendi-liivakasti kuna sama asi, inimestel pole praegu raha, et seda Samsungi uuema Windows 10 arvuti vastu vahetada. Ning Redstone 5 (1809) sellel vanakesel enam korralikult ei tööta. |
Ega ubuntu ka samamoodi viskab kernelitest ära vanemad arvuti toetused ja vana arvuti kohta (linuxi peale pannes) pead uurima, kas 3,3a ja 4 viga üldse lapib
viimati muutis libu 18.10.2018 09:33:09, muudetud 1 kord |
726 |
libu
Aeg Maha 1k
02.11.2018 10:32:39
https://thehackernews.com/2018/10/windows-defender-antivirus-sandbox.html
Oluline võit windowsi enda antiviiruse kasutajatele! Kuid peab ise käsitsi turvakasti sisse lülitama.
Turvakasti põhimõte on, et ükski teine seadistus, teek või binaar ei saa sandboxi ligi.
MA EI SAA UUDISI TEHA, seega siia panin!
NB! Ma tegelen turvakastiga viimased pool aastat linuxis ja ütlen, et see on küllalt hea lahendus tänapäeva turvariskide vähendamisel..
