huvitav mapist kõik avastatud ja ütleb mäng ise ,et 98% world open...
ma ei leia ülesse kus see kadund 2% siis jäänd on:D
ise teen kindlalt kõik achivmentid ära pole palju jäänd enam:D
vee all teema oli kõige tüütum achivment.
ise olen mingi questi juures kus pean mingi metssea maha lööma see on mingi eriti kange kuju .ma ei saa tast üldse jagu ja vibu ei võta ka eriti elusi vähemaks,vahepeal teeb ta imelikku häält ja siis tuleb veel neid notsusi juurde ja siis ma saan juba surma Ma ei saa aru miks peab sellises assasinsi mängus olema mingi võitlus metsseaga ?
Google Project Stream
Ameerika kodanikele pakutakse kuni 15/01/2019 tasuta mängida, kui veab
play Assassin’s Creed Odyssey for free via Chrome browser, US only, invite only
What is Project Stream?
Project Stream is your chance to participate in an exclusive Google technology test. Through Project Stream, you will have limited time access to the brand new game, Assassin’s Creed Odyssey, and have the ability to stream the game to a supported Chrome browser on a laptop or desktop. We’re very eager to hear from you about your experience with Project Stream.
What do I need to play Project Stream?
Here’s what you need to play Project Stream:
A Google account
An Ubisoft account
A computer with a recent version of Chrome (version 69 and higher)
A reliable internet connection (25 Mbps is recommended)
(Optional) A wired USB controller or external mouse (A laptop's trackpad isn't recommended)
Signing up for Project Stream
For a chance to join Project Stream, follow the steps listed below. Make sure that you're 17 or older, live in the U.S., and meet the above requirements.
How often will invitations be sent out?
We’ll be sending out invitations in rounds over the next two months. If you haven’t received one, don’t fret, you may still have a chance to join the fun.
What happens after the program ends?
After Project Stream ends, you’ll no longer be able to access the game or your saved progress and achievements. But until then, you can play as often as you want, subject to capacity limits. We still encourage you to submit feedback about your experience and provide suggestions to our team for improvements after your access has ended.
sa ei pea toda questi ära tegema ja võin öelda ,et see on pikk quest chain ehk seal tuleb veel loomadega sõdida.
lõpuks saad selle seti mis on suht mõttetu set annab seda loomade taming damaget vaevalt ,et sa seda üldse kasutama hakkad.
sul midagi siis ikka väga valesti vibuga pähe lastes kasuta devastating shot skilli see peaks ikka väga palju haiget tegema.
võimalus on veel ka easy panna ja siis on kindlasti väga kerge.
Mul laseb nooli ikka väga palju võssa. Ei tea mis teema on, aga näitab et on elude joon punane aga nool lendab enamusajast mööda.
Loomadega üldse huvitav. Sigadele pean ainult pähe laskma, kuna kerest laseb läbi. Või see koht kus dmg teeb vilksatub korraks ja kadunud.
Story sai mängul ikka jube kiirelt läbi või nii et ei saanud arugi.
Mul veel Cultis palju tegelasi kõrvaldada ja pole ühtegi setti koos.
Quest all vähemalt ei näita nagu midagi mis oleks veel main teema vms.
Kükloobiga fight kestis ikka päris kaua, raisal palju elusid.
omg lootsin mingit epic fighti aga ma ei tea mu build vist liiga OP see cyclops oli nii nõrk:S
devastating shot tegi iga litt pähe talle 140k hunter damage on mul ainult 8333
ja siis heroric strike pani 180k assasians damage on mul 116238
ma isegi ei kasutand warriori ability battlecrys mis annab extra 50% damage.
muidugi relval passive poison damage ja siis skill treest võetud see ,et armorit maha võtaks .
sellise buildiga on see mäng ikka mega kerge.
terve mäng olen tapnud teisi merce 1 shotiga cricital assasination skilliga:D
kas kellelgi veel orichalcum achivment bugis? ütleb ,et korda 50 endal üle 70 korjataud juba ja ikka ei saa kätte.
ainuke achivment mis on tegemata:(
ok Tänud sulle mängin hard raskusastmega,et ma seda nüüd küll allapoole ei hakka tõmbama ,küll ma hakkama saan aga jah mul seda devastating shot skill ehk tõesti veel pole,siis kui ei ole siis ma järgmisena hangin selle. ma saan aru et seal skill trees on 3 erinevat,siis hunter,warrior ja assasin... ega tegelt ei teagi ju mida oleks alguses mõttekam kõige rohkem arendada,momendil olen ise lvl19 alles et olen neid skille avades kõike nagu vaheldumisi võtnud,rohkem ehk tõesti assasins skilli arendanud kuna meeldib vaiken hiilimine,aga alati ei tule seal kuskil kindlust vallutades see hästi välja ja läheb madinaks Samas ma olen tähele pannud et võrrreldes orignsiga kui tõuseb sinu lvl tõuseb ka questide ja vaenlaste lvl....selles mõttes on see hea... vahepeal sattusin mingi selliste vendadega kogemata kokku kellel on mingi punane surnupealuu märk,see lõid mind ühe hoobiga surnuks... ma mõtlen et vabsee et mis levelist alates neid nottima saab hakata aga jah mäng on vägev,endale raskelt meeldib ja ei kahetse üldse.ahjaa see sparta kick on ikka megalahe asi,...mingi sattusin 2 levelit kõrgema mercenaryga kokku ja jooksin kuhugi kõrgema kalju serva äärde ja lõin jalaga vendi kaljult alla ja 2 levelit kõrgem vend sai ka hoobi,pudenes alla ja oligi kutu ,selles mõttes on see ikka kasulik asi
Nats üle 60 tunni magama pannud. Vägagi nauditav mäng. Pole stooriga kiirustanud, see umbes poole peal. Ainuke asi mis tõsiselt närvidele käib, on lollakad loomad metsas. No ei ole eriti immersive, kui lähed metsa ja seal kihab põtradest, kes enamvähem omavahel peadpidi kokku jooksevad Loomi võiks vähem olla ja jaht raskem.
1080ti Ryzen 1700 1440p kõik põhjas jookseb umbes 65-75fps. Udus läheb nats alla. Prose koormus 50% kandis.
nujah seekord mäng ju hakkab amd ryzen logoga siis jooksebki paremini, mul ka 1440p ja kõik põhjas va anti aliasing on high ja fps on seal 50-60 vahel kaart ka 1080ti. oleks amd kaart ma ei tea mis kaart amd kõige kõvem on praegu kui on midagi ? Vega ?
oodake ikka esimene performance patch ka ära ennem kui arvutit uuendama tormate:D
originis oli ju alguses samamoodi kohvutav perf.
viimati kui proovisin jooksis ikka mega hästi.
minu teada pole ühtegi performance patchi veel olnud ja teada on ,et asi on veits vigaselt kodeeritud ja kui mingi lambi vello githubis suutis fixi teha siis küll ubi ka lõpuks teeb:D
Jah parem oleks jube ebastabiilne see fps. _________________ Special boy
mul jookseb nvidia DSR'iga 1440p ja 45+fps
sitemini, kui origins jooksis
Proovisin ka Geforce Now game streaming platvormil seda
seal jookseb sitemini, kui 1080ti peal
Eile õhtul mängides sattusin mingi selliste elukatega kokku kes sulle lausa selga hüppavad,mina ei tea mis loomad need on natuke ehk ilvese moodi aga ma ei usu et ilvesed on ,pigem mingid metskassid... need on väga tülikad... metsades on jah metsikult igasuguseid põtru ja hirvi jooksmas,mind need väga ei sega jooksen neist mööda ja nad ise väga ei tülita sind.pigem rohkem karud ja hundid segavad,ei viitsi nendega väga madistada .võimalusel jooksen ära või kui on lähedal mingi kalju siis saab ronida kõrgmeale ja sinna nad juba järgi ei tule ....aga loomi võiks veits vähem olla küll,ega metsas ka ju reaalselt ei ole koguaeg niipalju loomi
stoori osas ma jõudsin nüüd mingi culti teema juurde ja nüüd pean hakkama neid tegelasi seal maha võtma,et kas kui need kõik maha võtan kas siis on peastoori läbi juba või ? mäng näitab küll et story on alles 26% vms ? neid kõrvalmissioone on ka metsikult ikka,annab ikka neid teha ....
Läks 85h aega et main story lõppu teha ja lisaks et kõik cultistid mättasse lüüa. Väga hea mäng, soovitan
EDIT - kui pole väga võimas arvuti siis soovitan mängida kas konsoolil või oodata patchi PC versiooni peal. Internetiavarustest loen et nii paljudel on kohutavad perf probleemid.
