praegune kellaaeg 23.09.2026 08:48:17
Wilts
21.12.2003 13:25:43
Corrupted or Missing \WINDOWS\SYSTEM32\CONFIG |
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Enter in the administrator password when requested
cd \windows\system32\config
Depending on which section was corrupted:
ren software software.bad or ren system system.bad
copy \windows\repair\system
copy \windows\repair\software
Take out the CD ROM and type exit
( "cd" taga on tühik, nagu ka "copy" järel)
toimib
_________________ L.A.M.P/ LAMP "Loose Association of Mercenaries & Privateers" |
| Kommentaarid: 31 loe/lisa |
30 |
Nganasan
11.01.2004 18:22:48
| seda ütleb vist arvuti siis kui oled mälu üle klokkinud, vähemalt mul oli nii, panin mälu korraks 100 MHz peal tööle ja ei mingit sellist kirja enam, siis uuesti restsart ja mälu õigele sagedusele.
| Kommentaarid: 25 loe/lisa |
23 |
xtr
16.01.2004 00:07:01
ütleb ka siis, kui ketas peetis on
_________________ M: Magic Mouse + Keyboard, MX Master 3S
M: 16GB DDR4, 1TB SSD |
| Kommentaarid: 330 loe/lisa |
272 |
